Old 08-23-2010, 08:50 AM   #16
Flanny
Flanny-it-up!
Flanny's Avatar
Location: Ottawa, Ontario, Canada, the World, the Universe
Oddometer: 2,738
Originally Posted by Pete640
Pete
It would be really nice if you could use the original factory hardware for the main tanks (rubber grommets and al. busings), with the 8mm hex head hardware...all sanno...)
Flanny is offline   Reply With Quote
Old 08-23-2010, 09:40 PM   #17
Pete640 OP
I hate sand.......
Pete640's Avatar
Oddometer: 1,762
Hi Flanny
Thats the plan so no other tools will need to be carried to R+R them other than whats in the baggie already. Ive got some OEM 690 Rallye tanks coming over this week to have a look at to compare/weigh which should be interesting.
Unfortunately the fab is on the go slow atm - doing a CF bashie to protect the low header - cant find one in CF that'll suit or mount up to the OEM points.
Pete
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 08-30-2010, 11:10 AM   #18
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 9,900
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 08-30-2010, 12:33 PM   #19
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,287
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 08-30-2010, 06:31 PM   #20
Pete640 OP
I hate sand.......
Pete640's Avatar
Oddometer: 1,762
I know, I know. Aust safari is just around the corner and there a couple of things I have to make for some friends.
Gas caps - what are your thoughts, keep it original looking or go flush mount like the main tanks?
Pete
Pete
Old 08-30-2010, 06:41 PM   #21
Flanny
Flanny-it-up!
Flanny's Avatar
Oddometer: 2,738
Pete
Acerbis.
Factory flush mounts are really complicated in terms of moulding/venting compared to standard Acerbis-type cap.
Old 08-30-2010, 07:48 PM   #22
Pete640 OP
I hate sand.......
Pete640's Avatar
Oddometer: 1,762
So something like this:
http://www.justgastanks.com/store/in...oducts_id=1132
With a plastic screw cap - as against something like:
http://www.justgastanks.com/store/in...roducts_id=988
I think the 2nd would look better and are vented internally. I understand the OEM parts are a PITA.
Pete
Pete
Old 08-31-2010, 03:36 AM   #23
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 9,900
I'd say flush mount if the venting doesn't complicate things.....on the other hand it sort of takes away from the "replica" look......tough call. If it were me I'd stay true to the replica.
Roaming Rally 2015
Old 08-31-2010, 03:44 AM   #24
KTMatt
KTMatt's Avatar
Oddometer: 792
Hay Pete Ive just made this tank for my 640 Adv and I used a flush mounted cap from a boat shop and there only about $12 each and for the vent I just turned up a nipple and weldered it on.
Cheers Matt
DSMRA Member # 1309
ROCK HARD RALLY GEAR
KTMatt is offline   Reply With Quote
Old 08-31-2010, 05:13 AM   #25
rcniss
Not that way!!
rcniss's Avatar
Oddometer: 399
Looking forward to following this build!!
rcniss is offline   Reply With Quote
Old 08-31-2010, 05:51 PM   #26
Pete640 OP
I hate sand.......
Pete640's Avatar
Oddometer: 1,762
Thanks Matt - ive been to a couple o chandleries but couldnt find exactly what im after. The screw caps have it - small as per the main on the 640A - can get the acerbis units as per OEM - but now looking for a source for the filler bung if anyone has any contacts. Prefer stainless over ally if possible.
No petcocks - banjo bolts leading to dry break connectors which will "T" before a fuel tap isolating both rears from the fronts. Will intersect the balance tube between the 2 fronts with a small filter inline.
Now back to the shed.
Pete
Pete
Old 08-31-2010, 06:17 PM   #27
Oz Nutter
Oddometer: 1,272
Quality Aussie Manufactered Goods.....
Bring it on.....
I'll support a local manufacturer everytime...
I know i'll probably pay more but thats the price for old mate's shed hours/r&d,(at least I get good old Aussie quality tried and tested for this enviroment.)
I've got a 950, and i'm a potential customer....
Oz Nutter is offline   Reply With Quote
Old 08-31-2010, 09:19 PM   #28
Pete640 OP
I hate sand.......
Pete640's Avatar
Oddometer: 1,762
Thanks OZ - I guarantee they wont cost more than the Africa Queens tanks and will fit and be a more authentic replica.
Back to work......
Pete
Pete
Old 09-05-2010, 04:47 AM   #29
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 9,900
Roaming Rally 2015
Old 09-07-2010, 03:59 AM   #30
Pete640 OP
I hate sand.......
Pete640's Avatar
Oddometer: 1,762
Deadly
Pete
Times are GMT -7.   It's 08:36 PM.
