Old 06-17-2011, 02:06 AM   #31
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,059
Well technology moved on since this thread was initiated.
http://www.advrider.com/forums/showthread.php?t=650046
The new solution is optical sensor operating the fp solenoid.
Everything is stock but the weak link of the fp. The contacts are replaced with an electronic circuit. Cheers.
Old 06-17-2011, 02:06 AM   #32
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
Originally Posted by MY ADV View Post
Less trouble trying to get all the parts and bits and best of all, there are no modifications needed to the fuel system. The OEM pump is what the bike was designed with and has the proper pressures and all of that. My pumps on average have lasted a bit longer than the water pump shaft and seals. So I would recommend replacing the pump contacts and the water pump shaft and seals at the same interval.
What interval are you having to change the water pump shaft and seals.
Opinions are like butt holes. Everyone has one and there's is the only one that doesn't stink.
Xmoto is offline   Reply With Quote
Old 06-17-2011, 01:23 PM   #33
MY ADV OP
"ZERO.. POINT.. ZERO"
MY ADV's Avatar
Oddometer: 492
New points with New water pump.
I had changed my water pump at 60K miles and the fuel pump points at 70K miles. I just finnished my 80k mile service and replaced my water pump and the points on the fuel pump looked good. I think I'm going to go with the DR Bean fix for my next fuel pump repair.
20K miles between water pump service. Seals and shaft were worn but not leaking.
15 to 20K miles for fuel pump.
MY ADV
You can't make dirt clean, so well just lemon scent it. (Modest Mouse)
2012 KTM 990R ADV (20.0K Miles and growing)
2005.5 KTM 950A ADV (106K Miles to its death by way of truck)
2005 KTM 450 EX-G (Plate)
MY ADV is offline   Reply With Quote
Old 06-18-2011, 02:38 PM   #34
keener
Speed changes you.
keener's Avatar
Oddometer: 978
Whats wrong with Facet 40171?
This was going to be my 4th fuel pump replacement and I didn’t want to buy a new one for $155.00 or go down the Facet pump fix. So I did some research and thanks to some fellow inmates I found a set of replacement contacts for the OEM fuel pump. It took me less than 1/2 of an hour to replace them and it only cost me $50.00.
Whats wrong with Facet solution (Facet #40171)?
its a tried and true pump that works for airplanes and has worked just find on 950. Its cheaper too,one third to be exact , $50 (http://www.aircraftspruce.ca/catalog...facetpumps.php)
04 ADV 950
keener is offline   Reply With Quote
Old 06-19-2011, 11:34 AM   #35
MrJakson
KTM 950 Convert
Oddometer: 27
Linky for points priced at $24.31
Just thought I would pass this along as I read before that folks were paying north of $40 for the points.
http://powersport-superstore-inc.ama...B0034ZMVKU.htm
Well a simple google search on the PN Showed $24.31. Going to order a set today.
Thanks for all of the info and the suggestions. I am going with just replacing the points myself. I want the simplest solution. Will plan on replacing the whole pump at 50K.
Kent
MrJakson is offline   Reply With Quote
Old 06-19-2011, 12:03 PM   #36
crazybrit
crazybrit's Avatar
Oddometer: 8,559
Kent
I'd install the Dr Bean kit then. It's barely harder than new points.
crazybrit is offline   Reply With Quote
Old 06-19-2011, 12:12 PM   #37
MrJakson
KTM 950 Convert
Oddometer: 27
Not for me.
Thanks for the advice. After reading through several threads, I have concluded that replacing the contacts is the route for me. Heading out for the Continental Divide Ride this year with 6 friends and I just don't want to try something new. Even with the documented flaws in the contacts, I have 20K on the original pump and am happy with it.
For me, everything else requires some modification that I don't want to make and I a concerned with a circuit board and optical sensor being submerged in water. Maybe it wouldn't be an issue, but not for me. Simple and standard is better in my book.
Kent
Old 06-19-2011, 05:05 PM   #38
cpmodem
Orange Caveman
cpmodem's Avatar
Location: masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
Oddometer: 7,103
Nothing hard about installing the Bean Mod. I compare the difference to the OEM points to the difference between the old mechanical breaker distributors to the modern breakerless ignitions. I still have one of those dinosaurs and get to replace them every 8k miles. Refreshing to upgrade the Mitsu pump to modern specs. Not problem with water getting in if the upgrade is done properly. If not, the points will fail too anyway.
-cp
DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt.
cpmodem is offline   Reply With Quote
Old 06-20-2011, 06:25 AM   #39
1stiski
Ride that nasty thing
1stiski's Avatar
Oddometer: 1,650
Originally Posted by Bronx View Post
I have replaced my 950 fuel pump after 37000 ks. I still have the old one so I will repair it as a spare.
I am glad someone told me about this particular thread.
Bruce
Going the same route here, Have a new spare under the seat and I will rebuild my old one that I have for a secondary spare. Hey I've got 3 pumps now, that should last me a couple years.
"04" 950 Adventure S 37,000+ miles
2003 Harley XL883 converted to CAFE (2013-14)
"Grim Brother" #1
1stiski is offline   Reply With Quote
Old 01-20-2013, 11:04 AM   #40
mrmrva
wannabe adventurer
mrmrva's Avatar
Oddometer: 90
Bump :)
Can anyone point me to the MOSFET mod for fp? Tried searching but no luck
mrmrva is offline   Reply With Quote
Old 01-20-2013, 01:51 PM   #41
Katoom72
Katoom72's Avatar
Oddometer: 910
Originally Posted by mrmrva View Post
Bump :)
http://www.ktm950.info/how/Orange%20...itsubishi.html
Katoom72 is offline   Reply With Quote
Old 01-20-2013, 03:16 PM   #42
mrmrva
wannabe adventurer
mrmrva's Avatar
Oddometer: 90
Thanks a lot for this
Times are GMT -7.   It's 11:08 AM.
