Old 08-19-2010, 12:26 AM   #1
Steve G. OP
Steve G.'s Avatar
Oddometer: 7,135
Non-synthetic oil options
While my girlfriend's F650/800 engine breaks in, I'd like to change the oil more than the factory. What kind of oil are you guys using?
Steve
Steve G. is offline   Reply With Quote
Old 08-19-2010, 03:41 PM   #2
FlatBroke
No Guts No Gravel
FlatBroke's Avatar
Oddometer: 21
Shell Rotella 15/40. I use it in my 800gs,Kingpin, and my KLR. Reasonable cost,easy to find (WalMart) and has worked great in everything I've used it in. On a road trip once me and a buddy changed our oil in a WalMart parking lot! You can spend more for "Botique" oils if it makes you feel better, but I have never found any advantage over the Rotella in real world applications. You can check for yourself on the Rotella web site.
http://www.shellusserver.com/ubbthre...Board=9&page=1
Facts are meaningless. You could use facts to prove anything that's even remotely true! "Homer Simpson"
If the facts don't fit the theory,change the facts. "Albert Einstein"
2009 BMW F800GS---backroad bomber
2004 Victory Kingpin---Sat. night & 2 up cruiser
2000 Kawasaki KLR 650---Daily beater
FlatBroke is offline   Reply With Quote
Old 08-20-2010, 09:53 AM   #3
WvMoto
WvMoto's Avatar
Oddometer: 102
Castrol
BMW seems to recommend Castrol (think it's mentioned in the owner's manual) so the Castrol motorcycle-specific 10W-40 should be a good choice. Auto Zone stores around here have it for about $5/qt.
WvMoto is online now   Reply With Quote
Old 08-21-2010, 02:03 AM   #4
RAD800
RAD800's Avatar
Oddometer: 895
I saw the non synthetic motul 10w40 for 35au a gallon, cheap as shit. Maybe i should run it.
RAD800 is offline   Reply With Quote
Old 08-22-2010, 08:51 AM   #5
vtbob
wanderer
Oddometer: 592
+1 Have long settled Castrol in my motorcycles. I have found in superior to others.
vtbob is offline   Reply With Quote
Old 08-23-2010, 09:09 AM   #6
SCVGS
Oddometer: 72
Steve
How many miles are on the engine?
SCVGS is offline   Reply With Quote
Old 08-23-2010, 09:52 AM   #7
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,359
The HDEOs are excellent oils. They are very low ash, keep the engine spotlessly clean and provide a robust additive package. Oh, and they can usually go 10,000 miles between changes.
Rotella, Delo400 and Delvac 1300 are very simjilar and at less that $10.00/gallon, economical. Also, when travelling, they are available at truck stops. Truckers use these oils in their 500 HP diesel engines and get 20,00-30,00 mile OCIs...sometimes more...Oh, and those diesel engines go 500,000 miles between overhauls...'nuf said.
def is online now   Reply With Quote
Old 08-23-2010, 09:44 PM   #8
Steve G. OP
Steve G.'s Avatar
Oddometer: 7,135
Almost 5000kms [3000 miles].
Steve
Old 08-23-2010, 09:55 PM   #9
Steve G. OP
Steve G.'s Avatar
Oddometer: 7,135
I was under the impression that because this engine has the shared oil with gearbox/engine/clutch, that it would be a prime candidate for a high sheer visciosity oil to deal with the sheering effects of meshing gears. My last bike restoration, a CBX, I used diesel spec 15-40, API spec CC/CD, you are right, very good oil, which has a high zinc additive package for high pressure top end lubrication. Thing is, it last about 800 miles before the gearbox has reduced it to the consistancy of water. Not knocking diesel spec oil, great stuff, but I wouldn't run a bike on it for 10,000 miles, unless it had the 14 gallon oil pan that a CAT or Cummins engine has. This little twin Beemer engine should use a 'designer oil' as you call it, API Spec SG. After all, all oils are 'designer oils', different additive packages based on the application it is being made for.
Steve
Old 08-24-2010, 02:46 AM   #10
Tor
Native Viking
Tor's Avatar
Oddometer: 805
Steve
Put a good full synth. in there, like M1 10W40 4T. But that's just me .
"Be Always Sure You Are Right - Then Go Ahead"
2005 Honda ST1300 / 2010 BMW F800 Gelände-Straße
Tor is offline   Reply With Quote
Old 08-25-2010, 06:01 PM   #11
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
I run Amsoil 10w-40 full synth. I have to say, after a couple thousand miles I am thoroughly impressed.
If, however, I were to run a non-synth standard minereal oil, it would be Motul 3100 10w-40 or the standard BMW brand (Spectro) 10w-40.
Times are GMT -7.   It's 04:19 PM.
