Old 08-19-2010, 11:54 AM   #1
dogdoc1 OP
Oddometer: 22
Talking New dl650 v strom !! Best skid plate/crash bar??
I pulled the trigger yesterday on a new 2009 dl650 after going back and forth betwwen it and a klr 650. I immediately took it down a 2 track farm road with rocks, gravel, potholes and washes in it. It does just fine. I even crossed a pretty good ditch with it. I wanted to prove to myself I made the right choice and I think I did.It is not hard for me to handle on fairly rough dirt roads. I see more aggressive tires on it in the future, however. On the street, it was really sweet of course. I am going to need a skid plate and crash bars and was wanting to hear suggestions. Any other suggestions or info on the bike is welcome as well. Thanks dogdoc1
dogdoc1 is offline   Reply With Quote
Old 08-19-2010, 02:31 PM   #2
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,610
i have a patwalsh which i like (i don't ride nasty offroad w/ my strom. will say i've lifted my bike on a atv lift w/ no issues). i also have frame sliders added on mine which also helps protect a sideway bike. most of the other crashbar designs utilize the upper engine through bolt as a mounting point or cover that area so an additional slider can't be used. patwalsh is open in the area, but his design has less sideways support imo because of this. i also have his hiway pegs because the strom is more of a street bike for me and dr is my offroad bike.
...but i really like what this guy produces
http://www.advrider.com/forums/showthread.php?t=577802
http://www.advrider.com/forums/showt...rom+skid+plate
i'd match that w/ motech bars. i think they are the strongest (reinforced/gusseted the most) and come up nice and high .
http://www.sporttour.com/VStrom.htm
(650 is the black bike on right)
others are
-patwalsh http://www.patwalshdesigns.com/guard.html
-givi bars, hepco becker bars, adv moto stuff plate
http://www.amotostuff.com/Merchant2/...ory_Code=dl650
-altrider bars/plate http://www.altrider.com/product/cate...e/Suzuki/cid/2
-motech plate http://www.twistedthrottle.com/trade/productview/5232/
-touratech stuff http://www.touratech-usa.com/Store/1373/Protection
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins screwed with this post 08-19-2010 at 07:11 PM
Old 08-19-2010, 02:37 PM   #3
YukonTracker
Ride your Way
YukonTracker's Avatar
Oddometer: 249
I can vouch for the quality and functionality of the Givi's bars and Amoto stuff bash plate.
MotoDrifters Rentals & Tours
ryan@motodrifters.com
http://www.motodrifters.com
YukonTracker is offline   Reply With Quote
Old 08-19-2010, 02:51 PM   #4
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,610
as far as tire check into the new radial shinko 705s or if you have $ to spend the more agressive heindau k60. i'm thinking about a k60 front and 705 rear.
http://www.advrider.com/forums/showthread.php?t=443226
http://www.advrider.com/forums/showthread.php?t=443958
Alaska
Old 08-19-2010, 03:19 PM   #5
xDownSetx
U WOT M8?
xDownSetx's Avatar
Oddometer: 116
If I had the choice again I would skip the givi stuff and get the pat walsh bars and skidplate. Only setup I know of that's strong enough to be able to use a bike jack. The givi bars add a lot of vibration to the bike too.
xDownSetx is offline   Reply With Quote
Old 08-19-2010, 03:34 PM   #6
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,610
i've read givi does that and also cracks (but that might be older generation design)
some like givi some don't.
most seem to like the newest design from motech. i like how they've reinforced the design.
hepco becker are also well received.
...i think that's because the patwalsh setup bolts together as a complete package vrs the others which are crash bars with a skid plate bolted to the crossbar portion. patwalsh also has a very large flat surface on the bottom of the skid plate vrs the narrowed design of the others.
i think another factor is patwalsh's skidplate design does not use additional rear brackets to connect to the bike. his plate angles up at the rear and bolts directly to the bike. i assume this is stronger here. where i see a weakness in patwalsh design is he only has 1 attachment at the top so a sideway drop might tweak his bars more sideways. this is the reason i added sliders. they provide additional support if the bike goes on it's side. will say i've read reports of em being dropped with no issues though.
if you had a center stand, lifting the bike might not be a needed issue.
i use a motech center stand which i like.
like i said i've also completely lifted the bike.
Alaska
eakins screwed with this post 08-19-2010 at 03:40 PM
Old 08-19-2010, 03:41 PM   #7
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,610
so dogdoc,
this getting you any closer? everyone always has a different opinion.
Alaska
Old 08-19-2010, 04:35 PM   #8
YukonTracker
Ride your Way
Oddometer: 249
Originally Posted by eakins
so dogdoc,
...and Mr Bill Eakins... if I may add, different tastes and experiences.
Old 08-19-2010, 06:25 PM   #9
dogdoc1 OP
Oddometer: 22
Yes i am closer. I like the skid plate on strom-trooper in that I could use my motorcycle jack with it in place. I appreciate everyones input and references. i have not had time to research everything provided but I am on it. dogdoc
Old 08-19-2010, 07:05 PM   #10
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,610
agreed.
let's not forget dan vesel's
http://community-2.webtv.net/CHERDAN...ies/page2.html
or the greek one
http://www.motoagora.com/podia650.html
or hyde's thermoplastic one
http://www.hyderacing.com/store/adve...suzuki/650.htm
b&b (oz) which could be the strongest out there
http://www.bboffroad.com.au/dl650_v_strom.htm
Alaska
eakins screwed with this post 08-19-2010 at 07:18 PM
Old 08-20-2010, 01:15 PM   #11
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,791
Pat Walsh
Not only did the bike do several trips around death valley with multiple drops.
But is also held up to a side swipe by a cager on the freeway at 45mph. Totaled the bike but the bars and plate held up. I would recommend these to anyone looking for a crash-bar, skid plate setup.
After the crash...
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 08-20-2010, 10:23 PM   #12
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,610
that's easily weldable.
cheaper than trashing plastic.
After the crash...
Alaska
Old 08-21-2010, 01:34 AM   #13
wingnut11
generally strange
wingnut11's Avatar
Oddometer: 692
Narcosis junky?
if that's the one you're talking about I have it on my vee. It's attached to givi crash bars (never had vibe problems from them) and it's great. It is a little heavy (steel so less chance of fatuige cracking) but it's low so it doesn't upset things. Frankly I wouldn't buy a different one. I've bottomed my bike out on big rocks many times (and a culvert tube once) and it didn't dent or bend at all. It just bounced off whatever I hit and kept going. It's something I have complete confidence in. It's worth more than Yann charges for them. Lots of other plates are aluminum that costs more, so as far as I could tell it's a more durable product at a cheaper price. I couldn't be more satisfied with it.
If you're thinking about it your just trying to justify it to yourself.
wingnut11 is offline   Reply With Quote
Old 08-21-2010, 01:37 AM   #14
wingnut11
generally strange
wingnut11's Avatar
Oddometer: 692
One more thing
I'm not saying the givi crash bars are the best, but at this point (3 tip overs) I've got no reason to be dissatisfied with them.
Old 08-21-2010, 08:49 AM   #15
Moooz
Moooz's Avatar
Oddometer: 455
I like my Pat Walsh set up. They survived t-boning a SUV and sliding down the road, protected the engine and oil cooler/filter, etc. They bent a little but were easy to bend back into shape. You can also put a floor jack underneath to lift it up and jack stands on the bottom where each the side bars connect. Makes it easy for front wheel removal.
Moooz is offline   Reply With Quote
Times are GMT -7.   It's 04:40 AM.
