Old 08-21-2010, 04:36 AM   #1
Zpider OP
Oddometer: 97
Question Remove the cat from original exhaust?
Has anyone tried this as an alternative to buying aftermarket cans? Thinking of it since my Sebrings are way to loud and i cant find any inserts for them.
BMW R1200GS Adv 2008
http://www.weirdperformance.se
Zpider is offline   Reply With Quote
Old 08-21-2010, 05:30 AM   #2
thugdog
Druid Revisionist
thugdog's Avatar
Oddometer: 396
http://www.advrider.com/forums/showt...light=Catalyst
....there's nothing more permanent than a temporary solution
thugdog is offline   Reply With Quote
Old 08-21-2010, 12:57 PM   #3
Farscape
Oh, look! Orange koolaid!
Farscape's Avatar
Location: Kickin' stones down the road to hell - Edmond, OK
Oddometer: 553
I did it. No problems so far.
I did it in conjumction with a canisterectomy, SAS removal and install of a H2W jet kit and snorkel.
I don't think the cans run any cooler and there is no change in the sound of the exhaust note. I just didn't need the cat in there anymore. Bike runs great.
I had a guy here in OKC that can weld stainless cut them out and re-weld the cans. He did an awesome, very clean job. You really wouldn't know it wasn't stock if I didn't tell you -- plus, the welds are hidden behind the rear plastics.
FYI, YMMV, IMHO, etc...
-- Jody
'04 KTM 950 Adventure "Garfield" '02 KTM 520 exc-r "Hooligan Machine"
Looks like someone swung a turd covered stick through a junkyard dumpster and that's what stuck to it. - Barman
Farscape is offline   Reply With Quote
Old 08-22-2010, 02:07 AM   #4
Zpider OP
Oddometer: 97
Originally Posted by Farscape
Bike runs great.
Can you compare it to aftermarket cans?
I think most say is wasnt worth the job at all.
Anyone know of inserts for Sebring cans?
Old 08-22-2010, 09:04 AM   #5
locksmith777
locksmith777's Avatar
Oddometer: 61
Heres some inserts http://cgi.ebay.co.uk/DB-KILLER-BAFF...torcycle_Parts
There are lots of different ones on the market .Or you could get some made up..
locksmith777 is offline   Reply With Quote
Old 08-22-2010, 09:57 AM   #6
ADVMax
Sporting Foole
ADVMax's Avatar
Oddometer: 32,152
You can actually hog the cats out with a big-ass drill. Lay the cans on their side and secure them so they won't twist and spin with the drill. Be real careful and drag out the larger bits, then when there's only leetle pieces left carefully stand the can up and clean out the rest with a shop vac.
The tubes that go from the bulkhead behind the cat to the next chamber extend up an inch or so past the bulkhead so with the cans laying on their side - and then carefully standing them up to vacuum will prevent little pieces from dropping into the nether regions of the can.
It ends up being a lot less hassle than cutting them and rewelding them.
There is absolutely NO EXCUSE for what I'm about to do!
The Second Amendment - it ain't about duck hunting.
You heatherns needs some churchin up - http://www.landoverbaptist.org/
ADVMax is offline   Reply With Quote
Old 08-22-2010, 06:33 PM   #7
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,055
Mine are decatted. Runs great, runs cool, looks stock.
Old 08-23-2010, 04:10 AM   #8
Zpider OP
Oddometer: 97
Did you do anything to the carbs? How was the performance difference to stock with cat?
Old 08-23-2010, 06:43 AM   #9
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,705
De catted my stock cans - had to set the carbs back to 1 jet under stock due to the pre filter. Did make a clear difference to performance tho. But ive gone to the 2-1 GPR system which makes it seem trivial re weight n performance.
Pete
Pete
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 08-23-2010, 06:49 PM   #10
Farscape
Farscape's Avatar
Oddometer: 553
Can't compare as I have not ran other cans.
Cost me $35 if I remember correctly. In the grand scheme of things with the H2W jet kit, snorkel, blocking plates, etc. it wasn't much. Plus I helped a local fab guy/rider out that offered his services. I wasn't prepared to spend nearly a grand on Akros anyhow...
-- Jody
Old 12-18-2013, 08:43 PM   #11
The Dude Himself
Hooked on Dirt!!
The Dude Himself's Avatar
Oddometer: 1,782
Qucik question - did decatting change the exhaust smell at all? After a ride does your gear/garage have a noticeable exhaust smell? I'm trying to determine if my jetting needs tweaked; or if this is a natural part of running catless.
The Dude Himself is offline   Reply With Quote
Old 12-18-2013, 08:55 PM   #12
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,705
No difference to the smell at my end???
Pete
Old 12-18-2013, 09:09 PM   #13
tacosupreme
tacosupreme's Avatar
Oddometer: 257
You will notice more smell, especially if you are running rich.
'12 990 with some orange stuff on it to make it go faster.
tacosupreme is offline   Reply With Quote
Times are GMT -7.   It's 09:50 AM.
