Go Back   ADVrider > Riding > Regional forums > New Zealand
Old 12-12-2011, 01:29 PM   #646
igormortis
igormortis's Avatar
Oddometer: 1,305
Semantics - bah! This is the internet!
igormortis is offline   Reply With Quote
Old 12-12-2011, 06:54 PM   #647
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,139
You're not one of those anti-semantics are you?
NordieBoy is online now   Reply With Quote
Old 12-13-2011, 12:45 AM   #648
guzzitony
Guzton
guzzitony's Avatar
Oddometer: 162
Bugger, wondered wot WAR meant. memories, i lived there for 5 years, can't exactly remember why but!
SHEDSAM- objects given/collected and stored in a
shed/mancave. esp car/bike parts.
guzzitony is offline   Reply With Quote
Old 12-13-2011, 02:31 AM   #649
Eddieb
Eddieb's Avatar
Oddometer: 960
You should pop your head up more often Tony. Had beers at my place tonight and your bike came up. Matt who organised the WAR ride saw you going through upper hutt the other day and had never seen it before. You could have come along tonight.
05 farkled DR650 - 86 BMW R80 with Velorex sidecar - 67 Ducati 250 Mark 3 Narrow Case
www.AdventureRidingNZ.co.nz Free GPS tracks for New Zealand, over 60 Owners and workshop manual downloads, ADV bike specs chart & more
Eddieb is offline   Reply With Quote
Old 12-15-2011, 02:03 AM   #650
igormortis
igormortis's Avatar
Oddometer: 1,305
Hey Steve, you’re running a UNI air filter right? Do you have a part number?
Old 12-15-2011, 02:21 AM   #651
Box'a'bits OP
In need of repair
Box'a'bits's Avatar
Oddometer: 2,184
Here's where I got mine from. It's the same as the US one, but not the same as the Aus one. Appears to be part no NU 7303.
Apparently the Aus crowd will make a filter up for you (special order) if you send them your old paper filter exterior. That seemed like too much hassle to me. It has been suggested that you could make one up easily enough the same way. The filter material is relatively easy to get hold of.
I use 'No Toil' filter oil & cleaner on it.
The filter is not quite as good as dirt bike filters, which wrap around a cage, because its glued onto the 'cage', but its better than paying out for paper filters. The 'cage' is rubber with a coarse aluminium screen at the base. It uses the standard filter housing, & runs at approx the same jetting. It isn't as exposed as the 'race' filter that Moorespeed uses (hate to get that wet, or dusty).
I'll be interested to see what mine looks like when I take it out shortly - given it was clean before the WAR ride.
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits screwed with this post 12-15-2011 at 11:35 PM
Box'a'bits is offline   Reply With Quote
Old 12-17-2011, 10:49 PM   #652
Box'a'bits OP
In need of repair
Box'a'bits's Avatar
Oddometer: 2,184
Sorting the Forks
I've had a stiction issue on the forks, which meant that while the forks dealt with bigger hits really well, small irregularities in the road were fed back to the rider. This was especially annoying on the road. I waited for a while after the rebuild to see if this was caused by the new bushes & seals I had put in, but the situation hadn't improved significantly.
As a first step I removed the sealsavers, & dropped the fork oil from 5w to 2.5w (standard for the 48mm KYB forks). Intuitively this felt too light, but 'needs must'. The fork action off the bike was smooth, but felt underdamped.
When I putting the forks back on the bike, I noticed the stiction was back. After investigation, I discovered the cause was the axle. This was flared at the non threaded end - I had assumed deliberately by Yamaha. But no, this is another example of work of the hamfisted prior owner. After I carefully ground this flare off, the axle slide 2mm further into the forks, & the stiction issue was resolved. Result!
BTW Andy Mac, found that 6mm tap...
Box'a'bits screwed with this post 12-17-2011 at 11:09 PM
Old 12-18-2011, 12:21 AM   #653
Padmei
enamoured
Oddometer: 3,604
Excellent result. Good investigative work.
Padmei is online now   Reply With Quote
Old 12-18-2011, 10:22 PM   #654
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 1,875
Nice report Steve, found this shot of the beamer resting at the lookout point from Sunday's ride, you can see the fuel level in the tank has only 60 gallons left
My EXC530 Adventure
2008 Beta Rev3 - Trials with lots of errors
Night Falcon is offline   Reply With Quote
Old 12-18-2011, 11:01 PM   #655
Mark_S
Fair Weather Faggot
Mark_S's Avatar
Oddometer: 1,778
actually thats a photo of a cool looking KLR.
Pity that old shitter bmw to the right ruins the photo somewhat
but you are right that it was a nice RR
These are the best days
Mark_S is offline   Reply With Quote
Old 12-18-2011, 11:10 PM   #656
Padmei
enamoured
Oddometer: 3,604
Who's pissing on Barts leg?
Old 12-18-2011, 11:59 PM   #657
Night Falcon
Adventure NZL
Oddometer: 1,875
Thats just another bow legged KLR rider hitching a gonad back in place after a 10 min ride on the KLR with the stock shocks
My EXC530 Adventure
Old 12-22-2011, 01:00 AM   #658
Mark_S
Fair Weather Faggot
Mark_S's Avatar
Oddometer: 1,778
this is a much better photo of the old shiiter
Old 12-22-2011, 11:42 AM   #659
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,635
That's a good one.
R1150GS
R80GS Basic
Kokopelli is offline   Reply With Quote
Old 12-22-2011, 11:51 AM   #660
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,139
Not a bad shot of Gus either...
DR650 Wiki
Times are GMT -7.   It's 05:00 AM.
