Old 08-24-2010, 10:23 AM   #1
nella OP
nella's Avatar
Oddometer: 403
venting an airhead gear box
A while back I made a plug to go in the hole left when I removed the speedometer cable:
I read that HPN offers a vented breather plug that has a tube that you attach to the frame.
My question is should I make a breather arrangement for my plug? If so, why does the gear box need to be vented?
Thanks,
Scott
Scott
nella is offline   Reply With Quote
Old 08-24-2010, 10:46 AM   #2
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,569
You already have a breather. The bolt holding your plug in has a hole down the length of it. That's the stock breather. Or you could replace it with a solid bolt and switch your plug to one of these:
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 08-24-2010, 11:02 AM   #3
rkatapt
Indo-Kraut
Oddometer: 261
I stuck a cork in my old speedo cable hole...
rkatapt is offline   Reply With Quote
Old 08-24-2010, 11:38 AM   #4
east high
east high's Avatar
Oddometer: 955
/thread
'71 r75/5
east high is offline   Reply With Quote
Old 08-24-2010, 12:23 PM   #5
Hawk Medicine
Coyote's Brother
Oddometer: 3,304
I have one of those vented plugs floating around the shop somewheres...
As I understand it, the guys racing airheads need to vent the gear box because under stress, they get hot and can puke oil. Therefore, the simple solution is to vent the tranny out to the the same catch bottle that services the engine.
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Old 08-24-2010, 02:16 PM   #6
nella OP
nella's Avatar
Oddometer: 403
My speedo cable bolt does not have a hole in it (it's not the original bolt), so I guess I'll make up a new vented plug. Thanks all for the advice.
Scott
Scott
Old 08-24-2010, 05:03 PM   #7
pommie john
pommie john's Avatar
Oddometer: 1,477
Thanks,
Scott
Yes you need a breather. The 'box contains air and oil that expand as it is heated causing an increase in pressure in the 'box. The temp of the gearbox can vary quite a lot from sub zero to ( guessing here) 80 C.
Without a breather to vent this pressure, it will be trying to get out of the seals and either finding its way into the clutch, or the shaft, or down onto the road.
pommie john is offline   Reply With Quote
Old 08-24-2010, 05:35 PM   #8
bikecat
bikecat's Avatar
Oddometer: 1,122
What's the part number for the original vented plug for a R100Gs?
bikecat is offline   Reply With Quote
Old 03-18-2011, 10:25 AM   #9
rkatapt
Indo-Kraut
Oddometer: 261
snip
Bumping this thread up...
Does anyone know where to get this breather stateside? I am wanting something a little more refined than the cork I've been using for a while. If I order from bmwboxersupplies.com it's 25,60 just to ship it to Dallas and the part itself is only 16,39.
Old 03-18-2011, 10:37 AM   #10
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,905
Touratech supplies a "proper" cap, but uses the tranny vent bolt for venting... ($16.40 and in stock) .....If you are looking specifically for something with which to vent farther up (water crossings, anyone?), it looks like you might be able to drill and tap this piece for an air tube, and use a solid bolt rather than the stock vent-bolt....
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 03-18-2011, 12:31 PM   #11
Jon-Lars
Jon-Lars
Jon-Lars's Avatar
Oddometer: 549
When you installed the replacement plug, did you remove the speedo drive gear from the tranny?
It comes out through the plug hole.
Cheers, Jon-Lars Sorenson
Beverly, WA
http://www.facebook.com/BMWR90S
Jon-Lars is offline   Reply With Quote
Old 03-18-2011, 01:56 PM   #12
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,905
Hmmm... if one were to pull out the drive cable, and to leave that drive gear in there, what might happen? I would think that is supported and kept in place with more than just the cable end?
Loving the 80ST
Old 03-18-2011, 05:34 PM   #13
nella OP
nella's Avatar
Oddometer: 403
I think most folks just pull the cable and replace with some plug without fooling around with the drive gear inside.
Scott
Old 03-18-2011, 05:58 PM   #14
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,700
I cut an old speedo cable,pulled the guts out and ran it up under the tank to make a piped vent.
Looks stock cost nothing.
My bike is slow but the earth is patient.
Rucksta is offline   Reply With Quote
Old 03-18-2011, 06:05 PM   #15
Jon-Lars
Jon-Lars
Jon-Lars's Avatar
Oddometer: 549
If anyone has a transmission on the shelf, remove the vented bolt and tilt the tranny over so that the drive gear slips out. It isn't retained in there by much. I think it has a boss on the bottom end that locates it in position inside the case.
If you remove the speedo cable, the top end of the gear is no longer held in place against axial and longitudinal loads. The gear is still driven but is able to move out of its engagement zone. I don't like that situation.
What is the drawback if you remove it? Are other components that are lubricated in there by the splash of that gear?
Wish I know more about the innards of a 5 speed BMW gearbox.
Beverly, WA
Times are GMT -7.   It's 04:22 AM.
