Old 03-18-2011, 11:33 PM   #16
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,182
Originally Posted by Rucksta View Post
I cut an old speedo cable,pulled the guts out and ran it up under the tank to make a piped vent.
Looks stock cost nothing.
I've done exactly that. I also zip tied a bit of filter foam over the end of the cable outer to keep the dust out. I also siliconed the cable end where the boot goes, so that that area doesn't allow in water. And I have a solid allen headed bolt into the tranny.
I think that the speedo drive is held in by the bolt into the tranny, not by the cable itself.
Now I need to find a venting solution for the final drive that appeals to my 'airhead' sense, i.e. cheap & practical.
My bike sees a few stream & river crossing, a bit of mud from time to time, & a lot of dust from gravel & dirt roads
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Old 03-19-2011, 10:47 AM   #17
Jon-Lars
Jon-Lars
Jon-Lars's Avatar
Oddometer: 544
The bolt engages a plastic bushing on the end of the speedo cable. That bushing holds the end of the cable and, I think, helps locate the drive gear in position.
Cheers, Jon-Lars Sorenson
Beverly, WA
http://www.facebook.com/BMWR90S
Jon-Lars is offline   Reply With Quote
Old 03-19-2011, 03:19 PM   #18
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,182
Originally Posted by Jon-Lars View Post
The bolt engages a plastic bushing on the end of the speedo cable. That bushing holds the end of the cable OUTER SHEATHING and, I think, helps locate the drive gear in position.
Correct.
Times are GMT -7.   It's 05:30 AM.
