Old 08-24-2010, 11:58 AM   #1
Corona OP
Dreaming of Dreaming
Corona's Avatar
Oddometer: 100
Gear shifting on the f800gs with MX boots
So last week I thought I would cut my off road teeth on some byways in the UK on my f800gs. All was going well until I came across some muddy ruts and my OEM road tyres gave up and the bike took a tumble.
All good as I had crash bars until the bike pinned me to the floor nearly snapping my ankle. Now not so good as I was in the middle of a forest, in the dark on my own. Anyway I managed to wriggle free narrowly avoiding a broken ankle but from this experience I decided to buy some proper MX boots instead of my road boots.
I now have a pair of Alpinestar Tech 7 boots which feel suitably tough enough to protect my ankle but I now find it super hard to change gear as my ankle doesn't move. Is there a nack to this, do I need a longer gear lever, is the gs suitable? Any advice appreciated.
2010 BMW F800 GS
Farkles: Adv Spec Crash Bars, Adv Spec Bash Plate, Bark Busters w/ Storm Guards, CalSci Touring screen, Remus Ti exhuast
Current Tyre: Conti TK80
2005 CBR600F4i
Farkles: Hell braided brake lines
Current Tyre: Michelin Pilot Road 2
Corona is offline   Reply With Quote
Old 08-24-2010, 12:03 PM   #2
dendrophobe
Motorbike Junky
dendrophobe's Avatar
Oddometer: 859
I wouldn't say that you necessarily "need" one, but an adjustable gear lever would probably help you to shift. I've had a similar issue with my Sidi Crossfires. I didn't go with an adjustable-length lever, but I did remove mine and angle it up a bit to help with shifting.
Ultimately, it's whatever you're comfortable with, and you can use safely. Touratech and Wunderlich both make adjustable levers that will probably make it easier for you; the good thing is they're relatively cheap.
Doug
Semper Fi
2009 BMW F800GS, Olive Drab
2006 Ducati Sport 1000, Black
Custom built Ducati GT1000 Scrambler, Red
dendrophobe is offline   Reply With Quote
Old 08-24-2010, 12:41 PM   #3
gregneedham
I seem to fall often
gregneedham's Avatar
Oddometer: 856
Adjust your gear lever all the way up. That might help a bit. Give yourself some time on the bike riding with the boots, you will get the hang of it.
The first time I hopped on my bike with my Alpinestar Tech 8s, I almost dumped the bike 10 feet in front of my house. I couldn't shift to save my life.
Now it's second nature and wouldn't go back. Like everything else, it just takes some time.
2002 KTM 640 Adventure
2000 BMW R 1150 GS (sold)
1982 BMW R100RT (sold)
My 640 Adventure blog
My 1150 GS blog (retired)
Memphis to Moab - TAT 09 Blog
designkeywest.com
gregneedham is offline   Reply With Quote
Old 08-24-2010, 12:55 PM   #4
TastyPants
Harasshole
TastyPants's Avatar
Oddometer: 226
I had to adjust my stock gear lever up with my new boots. No problem since and its cheap to do!
TastyPants is offline   Reply With Quote
Old 08-24-2010, 01:28 PM   #5
Corona OP
Corona's Avatar
Oddometer: 100
Thanks for the info guys. Should my boots be slightly big or should they be a tight fit? I am normally a UK 9 and I ended up buying a US10 boot.
2010 BMW F800 GS
2005 CBR600F4i
Old 08-24-2010, 03:30 PM   #6
ecce
ecce's Avatar
Oddometer: 129
In normal shoes I use 42, sometimes 41 or 43. I bought 44 for the MX boots.
I have EUR 44 and my brother EUR 42 on our MX boots (sidi crossfire). We can barely tell any difference in overall size on the outside but we sure notice a difference on the inside. The main difference you can tell on the outside is that the larger boot looks wider.
Buy larger than you think you need. Your feet will grow temporarily under exercise and from the heat. And you will be able to use thicker or double socks. I.e. a thin liner and a thicker ontop of that. Preferably made out of wool or similar. Smell less and wont get as cold when getting wet from the inside or outside.
With regards to the original question. Gear shifting will usually only be easy in one direction, down or up, but not both (I prefer down). If you venture offroad a lot - position the lever so that it is easy when standing up. When you sit down you can fiddle around a bit without creating a major problem.
You may also need lower footpegs to work well with the rear brake when standing.
A MX boot like the sidi crossfire allows for more movement of the foot, to a certain level, than many of the competitors.
ecce is offline   Reply With Quote
Old 08-24-2010, 04:22 PM   #7
Smoke 'Em
Oddometer: 28
Just practice up a bit! I can shift fine in stock configuration with my size 47 crossfires.
Smoke 'Em is offline   Reply With Quote
Old 08-24-2010, 06:42 PM   #8
TowPro
Lets ride
Oddometer: 3,219
see if you can move the shifter up 1 notch on the splines. At least this will allow you to get your boot under the shifter.
Until the boots break in, try shifting by lifting your whole foot instead of bending your ankle. Walking in the boots helps break them in but it sucks trying to walk in MX boots.
2015 KTM 690 Enduro R
2014 R1200GS - My Naked Street Touring Bike
2000 KTM LC4 640 E - currently up for adoption with 3200 miles
TowPro is online now   Reply With Quote
Old 08-24-2010, 09:45 PM   #9
Harry Swan
One more time
Harry Swan's Avatar
Oddometer: 1,099
The f8gs's gear shift lever is about 20 mm shorter than an 1150gs and really a pain for someone wearing size 47 mx type boots. My resolve was an adjustable gear shift lever from either Wunderlich or Touratech and pivot pegz. Life is good again....
What the hell do I know?!?
Harry Swan is offline   Reply With Quote
Old 08-25-2010, 01:32 AM   #10
LukasM
Oddometer: 5,425
The best solution would be a properly adjusted gear lever, a good boot with a hinge like the Sidi Crossfire and maybe a set of Pivot Pegz.
Old 08-25-2010, 08:17 AM   #11
puckinet
Safety third
puckinet's Avatar
Oddometer: 346
Adjust the lever up one or two teeth but the boot should fit snug around your foot, it will break in. Alpinestar makes a great boot. If you look at the front of the boot you will see that it has a ruff area on the toe and the side. I mostly use the upper side of the boot to shift by just rolling the boot. I do the same on my dirt bike so I don't get caught with my foot stuck under the shifter.
Our famous last words "It doesn't look too bad".
08 KTM 450 EXCR
2010 BMW F800GS
Rick
puckinet is offline   Reply With Quote
Old 08-25-2010, 08:46 AM   #12
Ducksbane
Quaaack!!!
Ducksbane's Avatar
Oddometer: 1,195
I have a set of Fastaway pegs in the low position ... It now seems about right. I always thought the pegs on the 800 were too high and forward for me.
Don't forget to remove the rubber footpeg inserts for off road at least, this will lower your foot on the peg a fair way, at zero cost.
Ducksbane is offline   Reply With Quote
Old 08-25-2010, 08:51 AM   #13
GrizGirl
Oddometer: 1,442
Did you take the rubber boot off the pegs? I did that with a combination of adjusting the lever up a notch and all was fine. As the boots break in you will get a little more movement out of them as well.
GrizGirl is offline   Reply With Quote
Old 08-25-2010, 10:03 AM   #14
mapuda
Crash Tested
mapuda's Avatar
Oddometer: 268
Along with proper adjustment of the shift lever, I put PivotPegz on my F800GS and am amazed how well I can shift with boots on.
The pivoting action lets you easily get your toe under the shifter sitting or standing.
mapuda is offline   Reply With Quote
Old 08-25-2010, 10:45 AM   #15
Corona OP
Corona's Avatar
Oddometer: 100
Aha, how stupid I hadn't thought of that yet. I will go try it now.
2010 BMW F800 GS
2005 CBR600F4i
Times are GMT -7.   It's 05:52 AM.
