Old 02-12-2012, 06:49 PM   #31
JGoody
Oddometer: 291
Originally Posted by pauljm View Post
My Wunderlich adjustable gear lever managed to snap on the weekend while on road up shifting.
Its been a while since I have been off road where it would get a knock unless its just been weaken for a while.
Anyway it bent up on the slide shaft one half snapped one still hanging on. Straightening snapped it obviously managed to rig it to continue the ride & get home. MacGyver eat your heart out.
Thinking of a replacement & maybe an Alloy lever that snaps isn't ideal. Any one found anything new recently to hit the market? Need it longer than std my size 12 Sidi Adv won't fit under/between the std lever.
Interesting -- I just put on the Wunderlich as the stock adjuster moved up a notch (and the rubber removed) was OK but not perfect with boots. I do wonder about the alloy casting -- it seems like the cheap BMW shifter would bend but not break and could be bent back. Anyone else with out there with Wunderlich problems? Also did yours slide on easily? -- Mine was so hard to get on I had the dealer do it as it was due for service and going in the shop anyway. Touratech makes a cheaper adjustable model that I believe is steel.
JGoody is offline   Reply With Quote
Old 02-13-2012, 08:12 AM   #32
TowPro
Lets ride
Oddometer: 3,298
I tried the touratech lever. When you slide the touratech (or stock shifter) on, the cross bolt that holds it on is made so it lines up with the relief in the shifter shaft. This way if the bolt comes loose, the shifter will not fall off (unless the bolt comes all the way out).
With the touratech the hole for the cross bolt was drilled to close to the shaft. When you slide the bolt through it binds on the shifter shaft and it cross threaded the bolt. When I went to loosen the bolt it broke off. I ended up having to drill the bolt out to get the shifter off. They exchanged it for me saying that the powder coating must have gotten into the hole. Got the new one and and it was exactly the same way.
I noticed with the shifter off the bike the bolt threads in perfectly, on the bike the bolt binds against the shaft. I called them about this and they said "BMW sources the shift shafts from different vendors, and yours must be machined wrong"
Sure. No way the touratech shifter could be drilled in the wrong spot, it has to be the BMW shifter shaft
It went back to touratech for a refund.
TowPro is online now   Reply With Quote
Old 02-25-2012, 11:59 PM   #33
mikefletcher24
Baja rider
mikefletcher24's Avatar
Oddometer: 70
I bought the GS boots and had the same problem with mine. Ordered the touratech adjustable one and also raised it up a notch. It was hitting the case, so I bent it slightly and now it works great. Breaking in the boots helps too as you get a better feel.
mikefletcher24 is offline   Reply With Quote
Old 02-26-2012, 10:10 AM   #34
GB.UK
GB.UK's Avatar
Oddometer: 62
Hello from the UK, what I did on mine was; I had a touratech lever off a R1200GS laying in the garage, I unbolted it and mated the front part with the folding tip with the standard part by cutting off the tip of the stock one.
Works fine
GB.UK is offline   Reply With Quote
Old 02-26-2012, 11:31 AM   #35
Steveman
Steveman's Avatar
Oddometer: 471
kewl idea
Steveman is offline   Reply With Quote
Old 02-27-2012, 10:32 AM   #36
señormoto
Supermoto Abuser
señormoto's Avatar
Oddometer: 1,110
Originally Posted by Corona View Post
Thanks for the info guys. Should my boots be slightly big or should they be a tight fit? I am normally a UK 9 and I ended up buying a US10 boot.
They should be as comfortable as a hiking boot. All of the alpinestars boots I've had took a while to break in, afterwards they shifted easier. Walk around in them and the flex will loosen up.
I have a feeling that there are some decisions being made on certain teams lately to make things more complex in order to ensure a certain technological standard of confusion is met.
señormoto is offline   Reply With Quote
Old 10-25-2012, 03:33 PM   #37
tinpusher
tinpusher's Avatar
Oddometer: 52
Moved mine up a notch and bent it out slightly to fit over engine case. Works great now.
tinpusher is offline   Reply With Quote
Old 10-26-2012, 07:07 AM   #38
KLRscoob
KLRscoob's Avatar
Oddometer: 207
I have a size 14 boot and all I did is move the shifter up a couple of teeth. Gives more clearance for rocks and such as well. No need for adjustable levers unless you just want to support the aftermarket suppliers
www.ARMYMILLARD.com
In honor of Gregory N. Millard
Son - Brother - Hero
KLRscoob is offline   Reply With Quote
Old 10-26-2012, 02:55 PM   #39
Harry Swan
One more time
Harry Swan's Avatar
Oddometer: 1,100
Doesn't that make it harder to get your foot up to downshift? My MX boots aren't that flexible. I still like Wunderlich's longer shifter.
What the hell do I know?!?
Harry Swan is offline   Reply With Quote
Old 10-26-2012, 04:09 PM   #40
JGoody
Oddometer: 291
Same issue with mine! Same worries about the alloy casting -- but the fit is good.
Old 11-05-2012, 06:30 PM   #41
KLRscoob
KLRscoob's Avatar
Oddometer: 207
I just lift my whole boot like an MX bike. Doesn't require much boot flex with this technique.
www.ARMYMILLARD.com
Old 11-07-2012, 02:03 PM   #42
whitham_wannabe
whitham_wannabe's Avatar
Oddometer: 1,098
My Wunderlich failed too, after three years or so. Made a replacement out of steel, so far so good.
http://advrider.com/forums/showthread.php?t=831880
From a WW1 RAF Flight Manual ...
"If a crash at the home airfield is inevitable, try to hit something soft and, preferably, inexpensive"
Travels With Bruce : More Travels With Bruce
whitham_wannabe is offline   Reply With Quote
Old 11-19-2012, 08:47 AM   #43
EPMD
EPMD's Avatar
Oddometer: 169
Get used to it.
I now have a pair of Alpinestar Tech 7 boots which feel suitably tough enough to protect my ankle but I now find it super hard to change gear as my ankle doesn't move. Is there a nack to this, do I need a longer gear lever, is the gs suitable? Any advice appreciated.
MX boots won't let you articulate your ankle the same amount as road boots and/or regular shoes.
So you'll need to adjust accordingly.
When seated, especially when leaning forward, you'll basically need to lift your entire foot off the peg to shift. Same goes for braking. You end up using your whole leg to shift (and brake).
When standing, you should have enough ankle range of motion to brake and shift. Important tip! Stay on the balls of your feet for greater control and shock absorbing abilities by letting your ankle joints work. When needing to brake/shift, transition to the arches of your feet. Then switch back to the balls of your feet as soon as you can.
I'm not making this stuff up either. These are all pro MX and off road riding tips from Donnie Bales and Gary Semics.
EPMD screwed with this post 11-19-2012 at 09:00 AM
EPMD is offline   Reply With Quote
Times are GMT -7.   It's 11:18 AM.
