Old 08-24-2010, 06:54 PM   #1
mfp4073 OP
mfp4073's Avatar
Oddometer: 2,365
airhead rims, whats the reason for the uneven "divots"
I have noticed on old wire spoke airheads there are divots around the rim, but the are not evenly spaced. Whats the reason for this?
1974 BMW R90/6 Bettie #1, 04 Triumph Bonneville
Originally Posted by Martin Blank
loner, lonegunman, get it. That’s the whole point. I like the lifestyle, the image. Look a the way I dress.
Originally Posted by bgoodsoil View Post
Cavemen must've designed them shortly after inventing the wheel.
mfp4073 is offline   Reply With Quote
Old 08-24-2010, 07:07 PM   #2
Mr. B.
Climate Controlled
Mr. B.'s Avatar
Oddometer: 145
Safety Feature?
I've been told it is a safety feature to keep the tire on the rim in case of a flat. I assume that its true........can anyone back that up?
Mr. B. is offline   Reply With Quote
Old 08-24-2010, 07:11 PM   #3
mfp4073 OP
mfp4073's Avatar
Oddometer: 2,365
Wouldnt they be evenly spaced then?
image for those who dont understand what I am talking about!
mfp4073 screwed with this post 08-24-2010 at 07:17 PM
Old 08-24-2010, 07:56 PM   #4
peterman
cop magnet
peterman's Avatar
Oddometer: 13,435
good question!
I have no knowledge of this for certain, but I imagine they are part of the manufacturing process used as a way to hold the rim from the internal side, once it has been rolled and welded. It would be interesting to watch the entire wheel making process from flat steel bands to a finished rim, for example, when are the spoke holes and dimples put in? After rolling, or before?
I'd imagine afterwards,,,anyone watched rims being made?
peterman
___________________________
"Your God, your rules,,YOU go burn in hell!" LLV
peterman is offline   Reply With Quote
Old 08-24-2010, 07:56 PM   #5
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,441
It's called a "drop center rim" and the ding-things prevent the bead from dismounting when you have the tire go flat.
Read up at Duane's Website:
http://www.w6rec.com/duane/bmw/5dents/index.htm
'73 R60/5 Toaster
Old 08-24-2010, 07:59 PM   #6
jdiaz
Oddometer: 32,176
I've heard the same thing.
jdiaz is offline   Reply With Quote
Old 08-24-2010, 08:46 PM   #7
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,079
They're not all the way around the rim because...
... it would negate the reason for the dropped center, making it difficult or impossible to mount a tire. Take a look, and you'll see they're evenly spaced from the valve stem. The valve stem itself probably acts as one of the humps.
Duane does talk about it on his site. And it is a safety thing I've only seen on BMW wire wheels, intended to keep the tire on the rim should it suddenly deflate.
Old 08-24-2010, 08:47 PM   #8
Xcuvator
Justa Venturer
Xcuvator's Avatar
Oddometer: 1,363
I have heard that they are to prevent the bead from breaking but I never have been able to figure out how those little dimples could accomplish such a task.
I just don't see how they could, since they don't protrude far enough from that part of the of the rim to even touch the bead. And then the spacing......?
___________________________________________
So much riding-so little time
Xcuvator is offline   Reply With Quote
Old 08-24-2010, 08:59 PM   #9
Wirespokes
Wirespokes's Avatar
Oddometer: 8,079
No, I don't see any way they could prevent the bead from coming loose! But they could help prevent the tire from dropping into the well and coming off the rim entirely.
Old 08-24-2010, 09:09 PM   #10
Plaka
Brevis illi vita est
Oddometer: 4,586
They keep the bead from dropping into the center all the way around the rim in the event of a flat.
It works well---just try to dismount a tire the wrong way!. It's in your manual---You have to start spooning at the divots so the bead can drop into the well on the opposite side of the rim. If you start opposite the divots there is no way to get the tire off. Try it.
Old 08-24-2010, 09:27 PM   #11
Xcuvator
Justa Venturer
Xcuvator's Avatar
Oddometer: 1,363
That makes sense, glad you- all cleared that up for me.
I do wonder though, why don't any of the other wheel manufacturers think it is such a good idea? Maybe there are some others doing it, but I don't recall noticing. Are there?
Old 08-25-2010, 03:20 PM   #12
mfp4073 OP
mfp4073's Avatar
Oddometer: 2,365
Good info! Another airhead mystery solved! Thanks all!
Old 08-25-2010, 03:49 PM   #13
England-Kev
Oddometer: 3,535
so if that is correct, then why are they not on the rear wheel as well then?
I asked BMW why they are there, they said they don't know
England-Kev is offline   Reply With Quote
Old 08-25-2010, 03:55 PM   #14
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,774
Correct.
They are on all the BMW wire wheels made for tubes, front and back: as mentioned above, just try to get the tire off without getting the bead down into the center where there are NOT divots while you spoon away on the opposite side.. they ARE effective... !!
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 08-26-2010, 10:12 AM   #15
England-Kev
Oddometer: 3,535
Well they ain't on my ST rear wheel
Times are GMT -7.   It's 05:47 AM.
