Old 12-05-2011, 03:48 AM   #61
Mitas
caretaker
Mitas's Avatar
Oddometer: 284
+1
Mitas is offline   Reply With Quote
Old 10-07-2012, 01:07 AM   #62
Snowy
Snowy's Avatar
Oddometer: 1,998
Originally Posted by Mitas View Post
correct ...
@99p38a
if you donīt feel you need more grip.... itīs ok,... but have a look at the wear in the centre. 40 Psi is recommended for the Dakar models. 33Psi for the non - Dakarīs
Love the E09 on my DR's, and the F800GS. Look forward to using them on the R1200GSA if I do buy one.
I tended toward higher pressures after comments from Mitas. I have an E09 here that did 6500kms 2 up and lots of dirt and was still 7.8mm tread depth at centreline.
Currently my F800GS has an E07 on it that's done 8000kms of the same sort of 2 up, rocky fire trail riding. It has 7mm tread depth left, and it's the only tyre I've used where the sides are wearing as fast as the centre. I crank it over until I'm dragging footpegs and centre stand on road, The side stand foot plate extension has about 4mm worn off it. Never had an issue with them wet or dry. I run the E07 at maximum rated pressure. From -6C, rain hail or shine they've been great.
I ran the E09 at 40 psi. I had mixed results on the DR at lower pressures.
After all the tyres I've used, the Mitas are the closest to bullet proof on a big bike in the dirt.
Don't like the E09 front though. Knod depth too shallow, they tend to saw tooth quickly. But my experience of them was limited to low pressure running on the first set I bought. I've had 4 x E09 rears, 5 x C02 Stone Kings, 2 x E07. I tend to use Dunlop D952 front for pure offroad. I've used the E09, E07 front and have switched to Scorpion MT09AT on the front as a dual purpose tyre. The E07 front wore a little too much just off the centreline, mainly from 2 up fast tar and heavy braking. The Scorpion is wearing like that too, but not as bad.
In general I love the Mitas. I look forward to many many more miles on them. Keep them coming.
Snowy is offline   Reply With Quote
Old 10-07-2012, 05:21 AM   #63
Grants
Grants's Avatar
Oddometer: 119
Thumbs up for Mitas E09, best price / performance for off road tyres... no problem on road so far, just when cornering have to keep in mind that these are not Tourances or smth similar.
college on KTM have even more rough off road tyres, from Mitas... forgot the model number.
It would be good to have E09 in size of 150/70/17, any chances to see such tyres in shops?
Latvia - Romania
http://advrider.com/forums/showthread.php?t=754389
Grants is offline   Reply With Quote
Old 10-07-2012, 06:04 AM   #64
Snowy
Snowy's Avatar
Oddometer: 1,998
Mitas were doing a 150/70-17 in the E07 and I think in the E09 as well. The new E10 comes already in a 150/70-17.
The 140/80-17 sizes are cross ply I believe, and the new E10 is a bias ply, a combination of cross ply and radial ply. The 150 versions of the E09 and E07 will be Bias ply.
The downside for us is that Bias ply produces a stiffer carcass, so they make the rubber compound softer to get the ride and handling on road.
Hence the initial issues with the E10. Mitas has apparently changed the compound from the super soft one used in the early E10, that caused so much poor feedback from users.
Using a 140/80 in place of a 150/70 produces no real issues. The tyre tread face is spread flatter. I thought this would be an issue on road, but I can scrape the pegs without running out of rubber, and the flatter contact area seems to make them last longer on the wide rims than they do on narrower rims on lighter bikes.
Speed rating wise it isn't a problem here as we have a 110kph maximum. It sucks. The previous unlimited speed limit in the Northern Territory was replaced with a 130kph limit, but I hear they are going back to a unlimited limit outside of the main cities (towns). Previously you couldn't legally fit some tyres here if they didn't meet the manufacturers speed ratings, but with the NT capping their limit at 130 it helped open up tyre choices.
But it was only ever a problem if getting a reputable dealer to fit them for you. Fit them yourself and you fit whatever you want.
Old 10-07-2012, 06:08 AM   #65
Snowy
Snowy's Avatar
Oddometer: 1,998
I forgot, I measured the E07 again and at 8400kms it has 6.74mm of tread left at the centre line. About half the tread depth of a new one.
Still works well off road. Not quite as well as an E09, but it definitely lasts longer on road.
Old 10-07-2012, 07:43 AM   #66
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,902
So are these Mitas tires available for sale yet from any US vendors? Not anywhere that I've found but I'd love to be proven wrong.
Current: 2014 R1200GSW & 2007 DR650
jdub is offline   Reply With Quote
Old 10-07-2012, 09:28 AM   #67
wcisse
wcisse's Avatar
Oddometer: 70
I received this reply from Mitas - looks like they are standing up an e-store for direct purchase in the near future....
From: Joel Rayson [mailto:Joel.Rayson@mitas-tires.com]
Sent: Wednesday, September 19, 2012 12:57 PM
To: Cissell, Wayne
Subject: RE: E-09 Dakar
Wayne,
We are looking more like 90 days ETA with the new shop with everything going smoothly. We are working as fast as we can and will make an announcement once we are up and running. Sorry about the delay
Thanks again
Joel Rayson
Marketing Communication Specialist
Mitas Tires North America, Inc.
7400 Carmel Executive Park, Suite 100, Charlotte, NC 28226 USA
__________________________________________________ _
Phone: +1-704-542-3422
Fax: +1-704-542-3474
E-mail: joel.rayson@mitas-tires.com
www.mitas-tires.com
Disclaimer: This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. Distribution only by express authority of a CGS Tyres company.
Sent: Wednesday, September 19, 2012 12:52 PM
To: Joel Rayson
Joel – thanks for getting back to me. What is the ETA on e-shop? I’d like to get some new tires in the next 30 days.
Wayne
Sent: Wednesday, September 19, 2012 12:30 PM
To: Cissell, Wayne
Subject: E-09 Dakar
Hi Wayne,
It is great to hear your interest in our dirt bike tires. We are currently reworking the e-shop so people will be able to purchase the tires directly from us in the future. I will have your email on file and when we are up and running I will be sending out a mass email, when the new e-shop is running again.
Thanks for your interest!
Joel Rayson
www.mitas-tires.com
wcisse is offline   Reply With Quote
Old 10-08-2012, 12:13 AM   #68
Mitas
caretaker
Mitas's Avatar
Oddometer: 284
Old 10-08-2012, 05:45 AM   #69
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,739
E07's on my 12gsa are my go to tire now. Can go get mucky, blast gravel, and scrape pegs all in the same ride (like.... yesterday) and it works.
For once, us canucks get the deal. Free shipping, and cheap prices from mx1canada.
Only thing that worries me is they've produced a Dakar version of the tire, and seem to be phasing out the older version. This one works, I really hate when a company fucks with something like this, it ALWAYS turns out worse for the consumer. ALWAYS.
Let's just say I have no false hopes of corporate benevolence. Just look at that Heidenau pos for proof. Yeah, a solid center strip on a tire meant to go offroad is a good idea...
Kinda making me wanna go get 3 or 4 sets of the old tires and store them until I need them. But getting a 1k PO for tires past the minister of the interior ain't gonna be easy... or advisable.
E09's? Have a set, with 10 kms at most on them. Full offroad tire, and I don't think that front would last for shit. Little meat on it, small knob size, I think I'd cook it in under 1k. I look at it as a one time use tire: use it for the weekend, then turf it. The rear has lots of meat on it, that one's a keeper.
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 10-08-2012, 06:33 AM   #70
Mitas
caretaker
Mitas's Avatar
Oddometer: 284
Naaaa,... donīt worry.... the Dakar last longer only ... itīs a reinforced version with harder tread compound as well .We as Mitas have both versions in production.
There might will be a 3rd Version ....
Old 10-08-2012, 06:46 AM   #71
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,739
I'm getting 18k kms/set, who needs a harder compound?
And I offroad a good bit, can't see that a stiffer carcass is needed.
Problem is: Shops are unlikely to stock both. So they'll stock the pricier ones, because there's better profit in them.
Can't see how the consumer makes out in this.
That being said, I really like the tires. You've got a good product, please don't mess it up.
Old 10-08-2012, 06:54 AM   #72
Mitas
caretaker
Mitas's Avatar
Oddometer: 284
.... thanks for the notice....
....especially when you run fully loaded through the desert of South Africa or China you might need a really bullet proof tyre.
Old 10-08-2012, 08:13 AM   #73
SkiFly01
Govna Racepipe
SkiFly01's Avatar
Oddometer: 592
Can't wait to see them for sale in the US again, without having to go through the Canadian site and pay crazy prices for shipping. It's the only reason I didn't get another E-09 and went to try out the Pirelli's.
Kai
2008 BMW GSA
2000 Kawasaki Super Sherpa
SkiFly01 is offline   Reply With Quote
Old 10-08-2012, 09:38 AM   #74
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,739
I can understand that requirement. But if we're to be honest, out of 1000 rear E07's made, what are the odds that even one will be riding those places? Many of us dream of it, but damn few manage to pull it off.
Like I said, it's already a damn good tire. I run offroad two-up, camping, so it's full load. If it can handle what I throw at it (and I'm not a little guy myself), then I'm sold. Compared to the competition (and I've tried all but the Mefos), you guys have got a winner. Good life, good handling, good bite on AND off road (I think everyone here who does both knows how hard that is to find), and a good price.
I just hope that this tire doesn't have happen to it like the Scouts did: new and 'improved', and it was a shit tire. I can't even give them away.
It's nice to see you're here discussing the product, it's so rare these days that a customer can see that when we talk to customer service, that it is no more than just lip service. Thank you for this. I'm sure we differ in opinion on things, but well... that's what makes the discussions more interesting.
Time to go wear out some more tires.
Old 10-08-2012, 11:46 AM   #75
mcstark
KaTooM convert
mcstark's Avatar
Oddometer: 1,152
For those in the colonies, did you pay any duty or penalties when ordering from our neighbors to the north? I've looked at their shipping, and while a little dear, it wouldn't put me off from ordering them.
I really like the looks of the E-07...Dakar version or not.
Regards,
Mark
2004 KTM 950 Adventure
Black is the new orange
mcstark is offline   Reply With Quote
Times are GMT -7.   It's 12:45 AM.
