Old 12-12-2004, 09:32 AM   #16
761
761's Avatar
Oddometer: 343
Originally Posted by creeper
Hi n00b... welcome to the asylum.
A little tip... fill out the rest of your public profile. No one will ever take you seriously if you leave it blank.
Creep
Hi Creep, thanks for the advice, and the welcome - just figuring this stuff out. Felt kinda obvious to me about the shield, but thought I might offer it up anyway.
761 is offline   Reply With Quote
Old 12-12-2004, 10:27 AM   #17
raindog
dharma bum
raindog's Avatar
Oddometer: 16,994
About 6 months ago I heard about a anti-fog mask that attached to the inside of the helmet... no squirt and rub chemicals required.
I was... "skeptical".
Got home this evening and found the Jan. issue of Motorcyclist in the mail, and as usual, did a quick thumb through... low and behold, they had tested one and determined that it all but eliminated shield foging. The staff gave it a rating of 5 'H'... what ever the hell that means.
I'm always looking for "something better" in this area... the best rub-on product I've found to date is the FogTech wipes.
One application and they last for several days in the funkiest weather Washington has to offer, but as with most chemicals, there is a degree of distortion and on-comming light flairing.
As it turns out, the mask is now being imported into the US by Street & Competition... so I ordered one. For $16 bucks... what the hell.
Anyway... the Respro Foggy Mask is available in assorted colors from:
http://streetandcomp.com/
Creep
I ordered one yesterday..I've been using the fog city liner for awhile but it doesn't help with my glasses Living in the PNW and wearing glasses just sucks..I'm looking forward to this bit of equipment wirking
raindog is offline   Reply With Quote
Old 12-12-2004, 11:50 AM   #18
mcoyote
Occam's Razorblade
mcoyote's Avatar
Oddometer: 615
Originally Posted by ZZR_Ron
I have to agree with him on the Fog City insert. They
make a photosensitive one as well. Work great!!
I tried them in the cold/wet and they do supress fogging but they cause a strange, multicolored halo-type effect around lights that reminded me of an MSG allergy. I couldn't take it, but I will readily admit that it's better than not being able to see at all.
"Professional coder on closed source. Do not attempt."
mcoyote is offline   Reply With Quote
Old 12-12-2004, 05:11 PM   #19
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Me to RD.
Mine has not shown up as yet... but I'll offer up an opinion ASAP-WTFTSU.
So... how's tricks?
creeper is offline   Reply With Quote
Old 12-12-2004, 07:15 PM   #20
rapiti
IOR Veteran
rapiti's Avatar
Oddometer: 1,908
My Arai TourCross came with a soft rubber fog shield. Is Arai Americas not shipping these with the XDs? Also got an extra set of shield screws, and painted caps to use when faceshield is removed, FWIW.
...its the best paint scheme that has ever been or ever will be on an Adv...-AussieRob
rapiti is offline   Reply With Quote
Old 12-13-2004, 08:07 AM   #21
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Fog shield and extra screws, no... caps when visor is not used, yes.
Arai... great helmets, shit company.
So... how's tricks?
Old 12-13-2004, 08:50 AM   #22
GearWhore
Running fans the flames
GearWhore's Avatar
Oddometer: 477
Snow Helmet
I have been riding with my Bombardier BV2S helmet. It rocks! The Foggy is a shitty product if you wear glasses and does an ok job deflecting your breath. But the BV2S, or any snowmobiling helmet that has an integrated mask is the only way to ride in below 30 F temps. This morning was 11 degrees F with windchills of minus 4 F and no fogging.
Also has a tail light and a integral sun visor! Can't say enough about it. I have an Arai head and it fits me just fine, no pressure points.
Gear Whore
GearWhore is offline   Reply With Quote
Old 12-13-2004, 08:53 AM   #23
bradgross
Too close to call...
bradgross's Avatar
Oddometer: 34
So Darth Vader-like...
[/QUOTE]
Luke, I am your father....
Brad
bradgross is offline   Reply With Quote
Old 12-13-2004, 03:18 PM   #24
rapiti
IOR Veteran
rapiti's Avatar
Oddometer: 1,908
Fixed it fer ya:
Arai... great helmets, shit distributor.
Old 12-13-2004, 03:29 PM   #25
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Fixed it fer ya:
Mmmmm OK.... I can run with that.
So... how's tricks?
Old 12-13-2004, 08:57 PM   #26
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
So, here it is. A piece of neoprene with three velcro panels (two on the sides, on in the front) and a riveted plastic nose piece.
Also included is a piece of peel & stick velcro inteded to be stuck to the center of the chin bar, which is not needed on a Arai XD as the velcro sticks fine to the chin bar liner.
It's actually quite comfortable and when adjusted properly seems to seal off the breath pretty well. The first morning ride will tell the tale. As there are no ventilation holes to allow breath out, ( kinda would defeat the purpose yes?) if you just put the mask over your face and breath thru you mouth... you stop breathing
No clue if it will keep any part of my face warmer.
Putting the helmet on is about normal, pulling straight up rather than rolling it off forward seems to be the best method of removal... at least for my oversize melon.
In this shot I put on my reading glasses so you can see the relationships.
A (fuzzy) view from the inside, in the final position that fit well for me. It took about 4 tries to get it positioned where I wanted it.
Without commiting... it seems like it's gona' work. We'll see soon enough.
Creep
So... how's tricks?
Old 12-14-2004, 03:44 AM   #27
rapiti
IOR Veteran
rapiti's Avatar
Oddometer: 1,908
All you need now is some Blue Man makeup
Is that a tongue patch to keep you & loaded from wearing through the thing, or where the velcro is attached?
I think that's all for now.
Thanks for putting up pics. I always wondered about the foggy things. I always thought they were a chemical coating. I also have never seen a helmet that big
Old 12-14-2004, 07:35 AM   #28
andmoon
andmoon's Avatar
Oddometer: 3,188
I got the foggy after seeing it in the mag. I wear glasses and it's the best product I have used so far.
It's a PIA to adjust properly...if you plan on moving it from helmet to helmet it might be better to buy another one. Once adjusted it stays put.
Get the black one as the colored ones reflect in the shield.
If you use a neck cover and try to cover your chin, the breath gets pushed up to glasses. I adjusted mine so there are gaps on the side attachments where air can escape.
My HJC already had velcro on the chin piece so I put the stick on velcro into my arai but am scared to remove from hjc due to adjustment fears.
The foggy will not work well if you have a flat nose...if you have broken your nose ( or have bad genes) and it does not sit dead center on your face you will have to mount the foggy off center.
andmoon is offline   Reply With Quote
Old 12-14-2004, 12:04 PM   #29
xtphreak
from B4 "adventure bikes"
xtphreak's Avatar
Oddometer: 7,963
thinkI will try one of these if I can find one to look at first
thanks to whoever posted the Schampa web site
I'll post after and let y'all know
right now I use a polarguard balaclava, and fog like everyone else
I crack the shield open when I slow ... but hey it's a pain
Do one thing every day that scares you. Baz Luhrmann
Women and cats will do as they please,
and men and dogs should relax and get used to the idea.
Robert A. Heinlen
Adventure is discomfort recounted at leisure. Flash / GSWayne
Chrome don't get ya home. Rob Nye
Stamp Out Hoplophobia in Our lifetimes.
1999 Tiger 885
1995 XT600E
xtphreak is offline   Reply With Quote
Old 12-14-2004, 01:33 PM   #30
Snapper
Snapper's Avatar
Oddometer: 2,509
Originally Posted by xtphreak
thinkI will try one of these if I can find one to look at first...
thanks to whoever posted the Schampa web siteI'll post after and let y'all know
I posted the Schampa link, but now looking back at my post, I was not clear. I use the Hannibal, and love it. I haven't found an easier, more convenient way to keep my chin/neck *WARM* (even down to single digits), but it does *nothing* to prevent fogging in a *helmet*.
Looking at your model, the "Gordito" I highly doubt that it will help with helmet fogging either. The non-fogging comment Schampa makes is correct for skiers with googles (they say "glasses and goggles", not "helmet"), where your breath is taken away by the open air. Our fullface helmets will still trap your breath in. For fogging I use the FogTech fluid and a Nolan visor insert (similar to FogCity) as mentioned in my first post.
Sorry for the confusion.
Oh yeah... you should be able to check out the Schampas at the IMS (motorcycle show), I always see it sold there.
Lateral G Junkie
Fear Deer
Snapper is offline   Reply With Quote
Times are GMT -7.   It's 10:58 AM.
