09-26-2007, 09:14 AM
#166 | |
kinda slow
Oddometer: 20,409
09-26-2007, 08:20 PM
#167 |
Oddometer: 356
More questions
Today I rec'd the seals I ordered. Toolfan, you were spot on !
I was able to carefully pry the dust seal out with a screwdriver, taking extreme care not to scratch the tube. Refilled with oil, then set up a jack, and had my wife slowwwwllly lift up on the jack while I held the fork and a short 2x4 spacer to reach a solid point. Not sure if we would both get covered in oil when/if it blew. But with one stroke of the jack, the seal just popped out about an inch! Perfect ! Got the new one seated, and everything buttoned up, so far no leaks after a short ride later. I also pulled the tank and got to those valve ajustments, but the offset valve adjustment set I got from Autozone surprised me, didn't have one quite that thin per the specs. Rats. Well at least next try I'll know how to do it. QUESTION: as I have no owners manual, what is the "Prime" for on the petcock? There is no "off" on mine, only 3 positions.. Reserve, Normal/Run/whatever, and Prime. The service manual says turn it to "off" before pulling the tank. And when I hooked the tank back up, I had gas running from the bowl overflow? nonstop. Didn't know what to do, finally after catching repeated cupfulls, I opened the filler with key and apparently inside pressure was equalized, and the fuel finally stopped draining. It was kinda crazy with gas everywhere for a while. Oh yeah, mine was indeed a California bike, not anymore!
09-26-2007, 09:08 PM
#168 |
Broken Hearted
Oddometer: 9,543
Cool! Nothing more satisfying than a job well done!
Your petcock is vacuum operated - Reserve - get that last little bit On - If the engine is pulling vacuum, fuel will flow Prime - bypasses the vacuum diaphragm, fuel flows without engine running. |
09-27-2007, 06:47 AM
#169 |
Teach me this knowledge
Oddometer: 541
![]() +1 to what toolfan said |
09-27-2007, 03:33 PM
#170 |
I don't need a title
Oddometer: 365
Braided brake line?
So who was it that was gonna add the braided brake line? Did you figure out what length to order? Im lazy and hope that someone else figured the measurement. LOL
09-27-2007, 09:58 PM
#171 | |
kinda slow
Oddometer: 20,409
![]() I don't remember the #s....but...it was the longest one the shop had in stock. (I think they thought they'd never sell it) ![]() It made a WORLD of difference on my bike! side note....someone thinks my bike may just have a bent shifting fork rubbing while in 3rd.
10-01-2007, 01:13 PM
#172 |
knight errant
Oddometer: 1,104
megacycle cams?
anybody install a set of hot cams in th dr650?
.Rule # 1 RAYOP (no matter how fast the other guy is) Rule # 2 Spy the guy in your eye before you fly at the Y. slow is smooth, smooth is fast http://www.centralvalleyds.com/
10-02-2007, 08:25 AM
#173 | |
Oddometer: 2,220
My bike is finally becoming fun to ride after: fork seals Eibach fork springs slipon jet kit chain/sprockets risers and YZ-high bend fat bar Renthal med grips brake pads braided lines Moose shift lever Plus: Acerbis 6.6-gal tank DRZ250 tail light LED turn siggies Please, please, please, if you add up the cost of those parts, don't tell me! But, if anyone has a suggestion for a better rear shock for the old girl let me know! |
10-02-2007, 09:29 AM
#174 |
Oddometer: 365
Slipon/ jetting
What slip-on muffler did you use?
I would love to dump the boat anchor....... I think it is a 2inch opening but would love to know if you found a sure fit pipe. Also, what jetting are you running? I have a 155 main Dynojet, needle on 4th clip as suggested and the fuel screw out 2 turns. Still hesitates badly when Im letting out the clutch unless I up the idle to around 2000rpm. Im at around 500ft above sea level, side cover off airbox and foam air filter. Thanks! Jason |
10-02-2007, 11:15 AM
#175 |
Oddometer: 2,220
The bike came with a crappy old Cobra, uninstalled.
As for jetting, I just used DJ's recommendations. My s/b sidecover is intact. I'm happy with it except for decel popping, which I can eliminate by idling up to about 1700. I have it at 1500. Have you cleaned your idle circuit? Sounds like it's not getting enough fuel on the bottom. |
10-02-2007, 11:46 AM
#176 |
Oddometer: 365
I took everything apart a while ago when I did the jet kit. I have played with the idle and idle mixture screw and just can't get the crisp low end throttle that am used to from riding inline 4's forever. If I idle around 2000 it is perfec too, just seems like a engine shouldn't idle at 2000rpm, but I dont have any owners manual or anything to give specs. I might throw the side cover on before I leave forwork to see if that helps. Up above 3000rpm it screams! Hard to believe that it is only a 650 single the way the power comes on!
I know that it is always tough to perfect carbs, esp. non-pumper carbs like on the DR and esp. on singles. I do a lot of city riding and having to worry about bogging and stalling at a stoplight aren't cool. Just for reference: 92 kicker, 6500 miles 6.6.gallon tank Eibach front springs and heavier oil (Im 6'3" 260 pounds) SOON gettting MEFO tires...... from KLR650.com, supposed to be the best on/off road tire around Jet kit, Dynojet 155 main, extended fuel screw out 2 turns Foam air filter Want a new headlight/turn signal setup from UFO or someone Want a new silencer/muffler Want a braided front brake line |
10-02-2007, 02:50 PM
#177 |
Oddometer: 365
Side cover on
So I am at work now and I put the side cover back on before I rode in. It is only a 5-10 minute ride but I felt a difference with the side cover on.
I rode the first 1/2 mile or so at full choke so it was idling around 2000rpm. Then at a stop sign I cut the choke all the way of and rode the last 1, 1 1/2 miles with no choke. She seems to pull from idle better but there is definately a midrange bog now and some popping on deceleration, but from a stop it seems much better. I should be putting close to 200 miles on tomorrow. Stop and go, open 2 lane country roads and some twisties. SHould be a good test to see if that cover makes it more ridable all around. The "rush" at higher rpm's is a bit less but still has decent power. It is a bit quieter too with the air cleaner closed off inside the box. Oh, it is cloundy, wt and about 60 degrees here today, yesterday was sunny and over 70....... if that makes a difference. |
10-03-2007, 01:37 PM
#178 | |
Oddometer: 3,812
"Deeply flawed people make deeply flawed decisions." |
10-04-2007, 06:03 AM
#179 | |
Oddometer: 356
Does anyone think it is possible to blow air (by mouth) from the bottom of the vent hose going to the tank? This would easily verify an open line. I tried and couldn't get anything, is there is a check valve or something inside? My serv manual shows a fuel/air separator up near the filler neck inside. This vent hose used to connect to the now removed emmissions canister, and also had an inline check valve, which is also removed at present. Another thought, this leaking only occurs sometimes, when trying to cold start, or right after cold starting. Could this be an issue of the carb float stuck at first, then loosening up? I never had this problem before pulling the smog gear last week. Thanks, great thread. |
10-04-2007, 07:21 AM
#180 | |
Broken Hearted
Oddometer: 9,543
The pressure in the tank shouldn't matter. Plus the tank is vented, so it shouldn't build up pressure.
The petcock has a diaphragm in it, when the engine produces vaccum (is on). You can make it work by sucking on the hose that goes from the carb to the back of the petcock. (Not the fuel hose, the other, smaller one) It sounds to me like yours is working correctly, but it sounds like your floats are set too high and they let too much fuel into the bowls Quote:
