10-04-2007, 09:55 AM
#181 | |
Oddometer: 3,821
Or the needle and seat on the carb are worn and not shutting off the gas, allowing fuel in the line to overfill the carb.
"Deeply flawed people make deeply flawed decisions." |
10-05-2007, 08:14 AM
#182 |
I don't need a title
Oddometer: 365
Videos of starting for Steve
Steve, I hope this works. I took two vids, one of me starting the bike cold (a good day.... day and a half since I last rode it) and it running at high idle/ full choke. The second vid is it at half choke (same idle speed as no choke) and the engine up close and running. I hope that this helps you!
Cheers, Jason OK....... after looking for 15 minutes I cant see how you post videos like the guy earlier did.... or even just attach them to the message or PM. if someone can give me a heads up on this. The vids are less than 350kb each, in 3gp format/ quicktime from my cell phone. |
10-05-2007, 10:34 AM
#183 | |
Teach me this knowledge
Oddometer: 541
"Upload Your Videos" in the top-Right sign in and upload. Or go to Youtube and do the same. After uploading, view the video and click the link that says "link to this video" Copy and paste the html code here |
10-05-2007, 11:34 AM
#184 |
Oddometer: 365
emailed Steve
Steve, I emailed you about the videos. Should say jason from Adv. in the subject line.
10-05-2007, 11:43 AM
#185 | |
Oddometer: 541
10-05-2007, 11:57 AM
#186 |
Oddometer: 7,761
Post 'em up, Steve
10-05-2007, 12:03 PM
#187 | |
Oddometer: 541
10-05-2007, 12:11 PM
#188 | |
Oddometer: 541
10-05-2007, 12:23 PM
#189 |
Oddometer: 7,761
10-05-2007, 01:03 PM
#190 | |
Oddometer: 95
The brakes definately have a different feel now. I would describe it as quicker response, and firmer lever feel. The Russel lines look great, and seem to be high quality. They came with the proper Banjo Ends, which threaded onto the new Brake Line. They also had a different type of crush washer, which I had not seen before. The stock washer is usually copper, or chrome plated copper. These were a stamped steel washer, with an attached rubber O-ring. They seem to work fine, and I have not seen any leaks. They did advise not to torque these washers too much, but did not provide a recommended torque setting. Kim Kelley PS I ordered the new lines through one of the aftermarket websites, but I can't remember which one right now. Here's the manufacturer website. http://www.russellperformance.com/ Edit: Sorry for posting 2005 DR650 info in this tread, I just realized my goof. Adventure_R screwed with this post 10-05-2007 at 01:15 PM |
10-16-2007, 06:14 PM
#191 |
knight errant
Oddometer: 1,104
installed new stator
bike wont fire? anybody with experience?
.Rule # 1 RAYOP (no matter how fast the other guy is) Rule # 2 Spy the guy in your eye before you fly at the Y. slow is smooth, smooth is fast http://www.centralvalleyds.com/
10-16-2007, 09:07 PM
#192 | |
Broken Hearted
Oddometer: 9,543
Got a wiring diagram? Is it a stock stator or a rewind? |
10-17-2007, 12:39 AM
#193 |
Oddometer: 1
Broken oil pipe
Hello DRiders. Im new here, age 35, from Estonia (east europe) and i have 93 dr650rse.
A little problem with engine - there is a broken oil pipe in camchain tunnel of crankcase, coming from oil filter room. Take a look at this pic. Can you tell me, what for is it, where must it go? At moment the open end just reduces oil pressure. All pieces seems to removed by previous owner. About this pipe no words or pics in manuals. BTW, i have pre 96 DR manuals for DL, if someone interested ;) Grahv screwed with this post 10-17-2007 at 12:46 AM |
10-22-2007, 07:07 PM
#194 |
Oddometer: 85
So how are everyone's old drs running?
Figured I would give this thread a bump, I bought mine about 1.5 yrs ago and it has been stellar. Starts every time (except occasionally at HIGH altitude) is pretty quick, and will run all day at 80mph. I shot my tank, sidecovers and fender with black bedliner and it is interesting.
10-23-2007, 05:04 AM
#195 | |
Oddometer: 541
