Old 07-22-2013, 01:07 PM   #3736
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,301
Maybe the unit is made for a post 96 650.Shims and spacers work?
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 07-23-2013, 08:31 AM   #3737
MartinPetren
Swedish Adventurer
MartinPetren's Avatar
Oddometer: 369
Picking up a TM40 tomorrow, the current owner claims it to be the pumper one. Does it look right to you? (Just want to be sure..)
edit:
I bought it! Appears to be right. Hopefully I get my new piston next week and then I'll slam it onto the bike!
Piston at the moment:
Anyone else had this problem?
Martin Petrén
WallStreetBikes
MartinPetren screwed with this post 07-26-2013 at 08:25 AM
MartinPetren is online now   Reply With Quote
Old 08-04-2013, 08:24 PM   #3738
tonusmaximus
maximus
tonusmaximus's Avatar
Oddometer: 488
Anyone know a link or model for clutch lever? oem perch. Found a few cheap black ones but not sure of fit. Maybe someone has a spare? Broke mine on the third drop today and have a temp on that barely works... Need barkbusters.
Sent from my SPH-D700 using Tapatalk 2
tonusmaximus is offline   Reply With Quote
Old 08-04-2013, 08:28 PM   #3739
knybanjo
kinda slow
knybanjo's Avatar
Oddometer: 23,989
http://www.bikebandit.com/1993-suzuk...7?m=139300&f=2
knybanjo is offline   Reply With Quote
Old 08-04-2013, 08:56 PM   #3740
tonusmaximus
maximus
Oddometer: 488
Yeah I saw that. was hoping for reference numbers to order comperable lever from free shipping somewhere like amazon. bikebandit wants $7 shipping. Five bikes keeps me in the poor house. Thanks tho.
You guys threw a great party at Ricks Rondevous btw. I got druuuuuunk.
Old 08-04-2013, 10:22 PM   #3741
SpringheelJack
Vagrant Lurker
Oddometer: 33
Check Dennis Kirk. They have a fit/no-fit thing for your bike and you could probably check the same model on Amazon. I got both a brake and clutch lever there for my DR. I've had better luck with their shipping, too (DK vs BikeBandit.)
Steve
1982 CB900F (It was gone, now back again)
1993 Nighthawk 750
1992 DR650 (gone)
2005 DL1000 (gone, sadly)
Lots more in the far past ...
SpringheelJack is offline   Reply With Quote
Old 08-06-2013, 12:49 AM   #3742
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 3,942
I filmed a DR650S 91' On my ride last Sunday. From Williams AZ to the Grand Canyon Off road. Love that bike.
http://www.youtube.com/watch?v=lbvAzpYA2As
DR-Z440E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY is offline   Reply With Quote
Old 08-07-2013, 07:37 PM   #3743
DURTI
Oddometer: 8
Clutch Cover
I am looking to replace the clutch cover on my 1990 DR 650s... I have found a few used on line, and was wondering if there are compatible years that I could shop for as well (i.e. 1991 or 1992). Please let me know.
Thank you,
DURTI
DURTI is offline   Reply With Quote
Old 08-08-2013, 07:31 AM   #3744
Schall87
Schall87's Avatar
Oddometer: 38
What tires were those
What tires were those on the DR650?
Schall87 is offline   Reply With Quote
Old 08-17-2013, 05:39 PM   #3745
Ppawslinging
roost ready
Oddometer: 2
carb
I have a 93 and the carb runs great, except for one issue.
When I let off the throttle all the way, the motor revs around 2 1/2k for about 5-10 secs. What would cause this, the throttle springs back good.
Ppawslinging is offline   Reply With Quote
Old 08-22-2013, 08:32 AM   #3746
tonusmaximus
maximus
Oddometer: 488
Have stock tank plastics from a '94. anyone need?
Old 08-22-2013, 11:40 AM   #3747
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,975
What carb are you referring to? I don't follow this thread too closely (sorry) so I may have missed something previously..
On some 2 strokes, having too lean a pilot (slow) jet will result in a hanging idle. Dunno if it's the same for 4 strokes or not.
Also, if this is a CV carb (with the big dome on top) your throttle cable is only connected to the downstream butterfly valve, NOT to the throttle slide. If the slide is hanging up or the spring is weak, the slide may not be returning to the bottom as it should.
Ladder106 is online now   Reply With Quote
Old 08-22-2013, 11:36 PM   #3748
knybanjo
kinda slow
knybanjo's Avatar
Oddometer: 23,989
Hey!
Has anybody upgraded their steering head bearings to tapered rollers or know the bearing part number to do so?
Old 08-24-2013, 03:50 PM   #3749
MartinPetren
Swedish Adventurer
Oddometer: 369
Engine problem
Just did a piston change. Followed the manual and everything is done correctly, or well I did not encounter anything odd in the process. But when I started up the engine it makes this mechanical sound from the inside.. Is the timing chain not set correctly? I did have the lines leveled to the ground when in TDC and all.. i'm confused.
https://www.youtube.com/watch?v=KEPf...e_gdata_player
Martin Petrén
WallStreetBikes
Old 08-25-2013, 12:16 AM   #3750
rowie
Oddometer: 228
Sounds bad man! Could be a valve hitting the piston? Did you wind up the cam chain tensioner before installing it? The lines on the cam should be parallel with the surface of the head and the locating pin should be at 1 o'clock
Rowie's DR650RS Rebuild
rowie is offline   Reply With Quote
Times are GMT -7.   It's 08:48 AM.
