Old 10-14-2013, 08:02 AM   #3781
markplace
markplace's Avatar
Oddometer: 68
Rear exhaust
Do any of you have a stock rear can gathering dust that they might want to sell me cheap? Mine has many rust holes and cracks and is getting unusually loud. I would prefer it not rusty or holey.
markplace is offline   Reply With Quote
Old 10-14-2013, 09:15 AM   #3782
markplace
markplace's Avatar
Oddometer: 68
sorry, it's a 93. down the road I'll build a better one when I have the time and money.
Old 10-15-2013, 02:26 AM   #3783
@ndy
@ndy's Avatar
Oddometer: 15
Had some time today so I grind the bolt out of the swing arm... Was all melted together with the spacer that's why was free spinning
Next I used the heat gun to melt the locktite on the ex bolts and free the disk from the wheels
Took the callipers apart... Find out that my rear calliper had both of the rubber pistons missing... front calliper was very rusty...
Should I wire brush and paint or go and get some aftermarket ones (original are stupid expensive).
Need to buy the bearing puller ... Something like that perhaps... http://www.enduroforkseals.com/id197.html.
Next on the list take apart the forks and bring the frame to the powder coating
[IMG][/IMG]
@ndy screwed with this post 10-15-2013 at 02:35 AM
@ndy is offline   Reply With Quote
Old 10-15-2013, 05:54 AM   #3784
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,232
Those calipers are trashed.I'd search here and thumper talk to see what options are available and grab good used ones off of ebay or the classifieds on the forums.Never hurts to run want to buy ads.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is online now   Reply With Quote
Old 10-15-2013, 08:37 AM   #3785
knybanjo
kinda slow
knybanjo's Avatar
Oddometer: 23,794
I was able to clean mine up and put new seals in them.
knybanjo is offline   Reply With Quote
Old 10-15-2013, 09:56 AM   #3786
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,948
The important part of the caliper is the inside bore. The outsides can be cleaned up and coated (with the bores masked off) or painted.
If the bores are in good shape and not pitted, reused them. Inspect the pistons and if not badly pitted these can be cleaned up with 000 steel wool. The pistons can be replaced if bad and are much less expensive and the entire caliper.
Then put in new seals and you should be OK
Ladder106 is offline   Reply With Quote
Old 10-15-2013, 12:28 PM   #3787
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,232
I have done it too,but looking back,it'd been worth the $20 for a clean take off.
Old 10-15-2013, 12:45 PM   #3788
knybanjo
kinda slow
knybanjo's Avatar
Oddometer: 23,794
You can get new calipers for $20? Link?
Old 10-15-2013, 12:59 PM   #3789
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,232
No not new.A clean take off from a bike being parted out.
Old 10-15-2013, 02:32 PM   #3790
knybanjo
kinda slow
knybanjo's Avatar
Oddometer: 23,794
Link?
Old 10-15-2013, 05:39 PM   #3791
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,232
Link?
I just search ebay and keep an eye out there.No certain seller.
Old 10-16-2013, 01:18 AM   #3792
@ndy
@ndy's Avatar
Oddometer: 15
Small lines inside the bore like fine scratches... Time for new callipers.
Probably going for discs and brake lines too ... If I can find something that will fit my '91.
On that note does anybody know if brake disks post 96 will fit a classic '91?
Finding lots of aftermarket on ebay but all for post 96 dr, only original expensive stuff for mine.
Thank you people really appreciate your ideas and tips
Old 10-16-2013, 02:36 PM   #3793
GRinCR
Oppressed Nomad
GRinCR's Avatar
Oddometer: 326
I can only speak for the front and it is a sure NO. The post '96 rotor is larger in circumference and has 5 holes for mounting. The rears look similar, but haven't put the two side by side since I don't want any more spare parts for I bike I don't have.
I did find aftermarket for both front and rear for my 1990... I will get back to you if I can find the links again.
*******Addition********
Home now and I dug through yee 'ole email box and found I bought the front rotor from Summit Racing. It was on back order and took over a month for me to see it. It was about $100US.
I only had luck finding it by searching with the part #MD6076D.
Google "MD6076D" and you will get plenty of hits like this one for $99 from EBC.
http://www.amazon.com/EBC-Brakes-MD6.../dp/B00666C4LU
For the rear rotor I used ebay. Got the disc and pads for around the same price.
Cheers!
Greg Smith
'90 DR650RS
Costa Rica: Trippin' with GR , The Bike Teardown
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
"My father taught me to work; he did not teach me to love it." -Abraham Lincoln
GRinCR screwed with this post 10-16-2013 at 05:34 PM
GRinCR is offline   Reply With Quote
Old 10-18-2013, 04:34 AM   #3794
tonusmaximus
maximus
tonusmaximus's Avatar
Oddometer: 455
http://www.advrider.com/forums/showthread.php?t=920544
not mine but I could use some parts off it If he will part it out.
Sent from my SPH-D700 using Tapatalk 2
tonusmaximus is offline   Reply With Quote
Old 10-18-2013, 08:30 AM   #3795
GRinCR
Oppressed Nomad
GRinCR's Avatar
Oddometer: 326
Question FMF or others...
I have been getting an itch to spend some more money on the DR. I like the look and sound of FMF but will entertain any bargain out there.
I see all the aftermarket pipes are set up for the gerneric looking, post '96 SE models. So my question is, if one were to install directly to the classic, old school DR would it require any modifications?
Greg Smith
'90 DR650RS
Times are GMT -7.   It's 08:48 PM.
