Old 01-06-2014, 01:56 PM   #3841
markplace
markplace's Avatar
Oddometer: 86
Nice cut away. The 35fo has made a huge difference in the bike. More low end power and less noise. Here's what my previous muffler looked like.
I also had time to add this home made windscreen for commuting.
markplace is offline   Reply With Quote
Old 01-12-2014, 07:18 PM   #3842
rgtrough
Oddometer: 3
New guy here
Hey guys, last month I acquired a 1993 DR650 with 15,500 miles in great shape. Here we go. This bike is pure stock. After I learned the starting ritual this bike has no issues. Starts on second kick. Warms up on the choke. Then runs up and down the road great. What's the problem you ask? I want to do some mods to increase performance. But I read about guys whose bike won't idle at stoplights or stumbles off idle. So first thing I'm doing is swapping the stock 15 sprocket for a 14. My question, I can wiggle the sprocket side to side, not front to back but side to side. Is this normal? if not how is it fixed?
Thanks Bud
rgtrough is offline   Reply With Quote
Old 01-13-2014, 09:01 AM   #3843
motolab
motolab's Avatar
Oddometer: 2,619
BST40 carbs use a cold start enrichment circuit instead of a choke. A choke is closed when an engine is cold and opened when it is warm, whereas a fuel enrichment circuit is opened when the engine is cold and closed when it is warm. A choke works by restricting the air flow, whereas an enrichment circuit works by adding extra fuel. A choke requires a fast idle cam or something akin to it (or you have to hold the throttle open manually), whereas an enrichment circuit adds a little extra air simultaneously with the extra fuel, so the fast idle is already built in.
Regards,
Derek
motolab is online now   Reply With Quote
Old 01-13-2014, 10:24 AM   #3844
markplace
markplace's Avatar
Oddometer: 86
Thanks Bud
I think the stock front is actually a 16. And mine floats a bit as well too. It rides on a splined shaft and is held only by a clip. This is something I wanted to research as well. The spocket has three threaded holes for another retainer that isn't installed on mine. BTW, a good set up for me so far is a 46 rear and I swap between a 15 and 16 on the front. I don't top out as well on the freeway and gas mileage is a bit lower with the 16/46, but it's a quick swap to 15/46 if I plan to go trail riding. Much easier on the clutch.
Old 01-13-2014, 12:38 PM   #3845
markplace
markplace's Avatar
Oddometer: 86
I just found this video answering some of our questions.
https://www.youtube.com/watch?v=Yzc4qw6Ooko
Old 01-13-2014, 01:27 PM   #3846
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,984
Wrong !!
Never trust someone who uses SAE tools on a Metric bike.
Also....the big "E" clip is a REALLY BAD idea.
There is a large rubber/neoprene ring that is supposed to live between the outer retaining plate and the sprocket. It likely does nothing but cushion the chain a bit to reduce noise but does make my DR750 sound a lot smoother. The outer rataining plate is there to locate the CS sprocket on the shaft to maintain the correct chain line in the final drive.
The reason that the youtube vid shows wear on the outer retaining ring is that he is missing the rubber part. A bit of "parts" research before starting a project will prevent many errors.
See:
http://www.bikebandit.com/1992-suzuk...9331#sch240206
Part # 35.
To answer your first question...yes...there is some play and wiggling between the CS sprocket and the splined shaft..... but this is mostly take up by the retaining plate. There should be just a touch of "in/out" play in the output shaft but NO radial movement in the bearing.
Be certain that you're running enough chain slack to prevent putting huge loads onto the splines and the output shaft bearing. Many guys new to DS bikes set their final drive up with the chain WAY too tight. Longer travel suspension demands more chain slack. See the manual for specs or do the set up the correct way with the output shaft, swingarm pivot and rear axle all lined up.
Ladder106 is offline   Reply With Quote
Old 01-13-2014, 02:26 PM   #3847
markplace
markplace's Avatar
Oddometer: 86
Right!!!
I'm off to the dealer for some parts I guess. Procycle has one for smaller sprockets that might fit too.
Old 01-13-2014, 05:47 PM   #3848
rgtrough
Oddometer: 3
Thanks for the replies. I guess it was important to make sure I knew there is not a choke on the carb. I read that the stock front sprocket was a 15. This must be true on the '96+ models. I found out today that the pre '96 models had a 16 stock. Mine has already been dropped -1. There is nothing bolted to the sprocket. Just 3 bolts threaded into the sprocket. I guess I need to find out what I need to add. What was stock? 16/46?
peace, Bud
Old 01-13-2014, 09:48 PM   #3849
markplace
markplace's Avatar
Oddometer: 86
It's 16/42 on ours.
Old 01-15-2014, 04:59 PM   #3850
markplace
markplace's Avatar
Oddometer: 86
Very true. I agree
I just ordered the retainer, bolts, and rubber thing. I had a lot of options to weigh in on my decision. Your "enthusiasm", my 12,000 miles of no problems, but the final clincher was the Suzuki mechanic telling me that "Stock is probably best". I would prefer to not have a catastrophic failure.
There is a large rubber/neoprene ring that is supposed to live between the outer retaining plate and the sprocket. It likely does nothing but cushion the chain a bit to reduce noise but does make my DR750 sound a lot smoother. The outer retaining plate is there to locate the CS sprocket on the shaft to maintain the correct chain line in the final drive.
The rubber part was the most expensive.
Yes, that's true. Straight from the mechanic's mouth.
We'll see. Parts coming soon
Always.
Old 01-21-2014, 05:03 PM   #3851
rgtrough
Oddometer: 3
Sproket Replacement
Hey guys, I'm replacing the front sprocket on my '93 DR650. The new sprocket has an offset on one side. Which side does the offset face, the engine or the cover? Thanks for the help?
peace, Bud
Old 01-21-2014, 08:12 PM   #3852
rowie
Oddometer: 228
Thanks Bud
I used a DR750 front sprocket on mine. The difference is the 750/800 sprockets are 10mm wide at the spline, vs 7mm wide for a 650 sprocket. Helps to reduce the side to side movement.
http://www.jtsprockets.com/catalogue/sprocket/JTF438
Cheers,
David
Rowie's DR650RS Rebuild
rowie is offline   Reply With Quote
Old 01-22-2014, 08:09 AM   #3853
Ladder106
Ladder106's Avatar
Oddometer: 4,984
This info is for the DR750/800 but is similar, I believe, to the early model DR650s.
If your bike uses the circular metal retaining plate and the large rubber O-ring type chain damper.....
.....the CS sprocket is mounted with the FLAT SIDE OUT.
See parts diagram a few posts above for the 'sploded view of the retainer plate and damper ring.
If you assemble it with the shoulder outside, the rubber damper is not held in place and will just spin around being useless.
Old 01-28-2014, 08:15 PM   #3854
Falconpunch01
Fly and ride!
Falconpunch01's Avatar
Oddometer: 108
Anyone know where I can get some new plastics for my 93' 650 ? mine are looking rough wanna get some better ones for the new year. And also what are some people using for exhaust ? I want a louder exhaust.
Falconpunch01 is offline   Reply With Quote
Old 01-29-2014, 05:13 AM   #3855
MartinPetren
Swedish Adventurer
MartinPetren's Avatar
Oddometer: 369
Check HERE for new OEM stuff. But it's probably going to cost.. better have a look at ebay! Aftermarket exhaust can be bought from Hessler.
Martin Petrén
WallStreetBikes
MartinPetren is online now   Reply With Quote
Times are GMT -7.   It's 09:24 AM.
