11-14-2010, 12:29 PM
#226 |
Oddometer: 1,332
Jenny, I'd be careful if I were you!
In general, 12V batteries require a charging voltage of somewhere between 13-14V ![]() In this scenario, whilst the bike is running, the power needed to run all your equipment will come directly from your stator and your battery will just be left unattended, therefore not getting sufficient charge energy. This means after stalling the bike a few times there won't be enough juice to start the engine. Another issue I see is that the lights still running with the engine shut off. With a dead cold bike (and equipment), by turning on the ignition the lights, especially the HID one, will suck a gigantic amount of power from the battery (a good 7A ![]() ![]() ) an this for about half a minute. In that time when you try to button start the bike, the voltage of your battery will drop drastically, thus not allowing the starter motor to turn fast enough. Perhaps putting a toggle switch for your lights will prevent this?Have you had several start attempts on the bike (especially dead cold ones), yet? schattat screwed with this post 11-14-2010 at 12:35 PM |
11-14-2010, 12:32 PM
#227 |
Oddometer: 1,332
I honestly don't see any issues with LEDs at all!
They are fully sealed, and won't break from vibrations. Just looks at your ordinary bulb (traditional and HID). They have an outer glass shell, that is fragile, and the wire inside that emits the light can snap in 2 at any time. LED's have a very high efficiency grade, meaning they don't waste a lot of power... For LEDs, it's just a matter of getting the right setup, so I'm with "tehdutchie"
11-14-2010, 01:34 PM
#228 | |
Dakar Dazed
Oddometer: 2,428
The tell-tale was basically just a dash board warning lamp that illuminated when the switch to the relay was made - although the switch circuit is just a low power feed to the relay, I guess putting the current through the light too was too much? it never went out though? Anyways... it seems to be sussed now... I really like the idea of LED lights (especially as there is no bloody ballast box to try and find a spot for on a crowded Nav tower!) - and I've had gone for a Vision-X 10W lamp if Touratech hadn't come up with the goods on a Micro DE Xenon... I've seen the Trail tech auxiliary HIDs with the built-in ballast, but have seen a number of reports of people have had those fail? Like you say, LED is probably going to be the way to go in future... J x
JennyDakar.com Dakar Dazed II - the Return to Dakar in 2014! Dakar Dazed 2011 - read the whole gory story here! JMo (& piglet) screwed with this post 11-14-2010 at 01:55 PM |
11-14-2010, 01:48 PM
#229 | |||
Dakar Dazed
Oddometer: 2,428
I must say, I'll be narked if it isn't charging the battery as well as running the gear, as Trail Tech said there would be enough juice from their stator set-up to run both the lights and the fan (the nav gear is pretty negligible really, although I guess the roadbook motor takes a bit?) Of course I could just disconnect the low beam (ideally with a switch as you say) if it turns out there is not enough juice... worst case scenario would be at night stuck in sand when you might need the fan on... but you can always stop and let the bike cool down I guess? and to be honest, you probably wouldn't need the HID if you were stuck/at slow speed? But I agree, everything SHOULD work TOGETHER ideally. Quote:
After the run today I left it for an hour or so, and it fired right up (in fact it fired right up at the petrol station 5 minutes down the road this morning) but as I say, I've not had a chance to run it with both lights going yet - tomorrow hopefully! Out of interest, when the HID is on, it seems to suck about 0.5V at idle - would this be about right (in whatever the amps/watts/volts relationship is?) I really appreciate all your knowledge on this! J x
JennyDakar.com Dakar Dazed II - the Return to Dakar in 2014! Dakar Dazed 2011 - read the whole gory story here! JMo (& piglet) screwed with this post 11-14-2010 at 02:03 PM |
11-14-2010, 02:09 PM
#230 |
Oddometer: 50
I have a bar mounted off/low/high switch for my X2 HID. It's never on when I start the bike though I have knocked it on a few times while the bike is off and ended up draining the battery.
It's not tied into the ignition yet but that is something I would like to do. I usally end up knocking the switch when loading the bike into a truck. Sucks arriving at your destination with a dead battery. I did a 3+ hour run yesterday with a single light on the whole ride and with both HIDs running for the last hour after dark. I didn't run into any battery issues and had no trouble starting the bike at any time. We were stopping fairly frequently as well.
06 WR450F 2011 Riff-Raff - Go Jonah |
11-14-2010, 02:16 PM
#231 | |
Dakar Dazed
Oddometer: 2,428
The X2 is two 35W HIDs is that right? I guess that is similar to the stock 35W bulb and the Xenon running together... I should be a lot more confident after a test with both tomorrow... J x |
11-14-2010, 02:35 PM
#232 | |
slave to gravity
Good job getting your LX sorted
Riff Raff 2012, 2011, 2010, 2009 Skibum Soiree 2012 Skibum Soiree 2011skibum soiree '10 RIP ITsteve, ride in peace my friend save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk |
11-14-2010, 04:14 PM
#233 | |
Gas Burner
Oddometer: 1,956
Africa Twin RD07 '00 - My Kleopatra Malfunction specialist... Road Rush (Romania, Serbia) Peloponnese Peninsula on two Africa Twins 9 countries in 15 days - Tserts.com |
11-14-2010, 07:47 PM
#234 | |
Oddometer: 3,331
Hmmm, My problem wasnt really with the starter (although that happened too!), but more so with the bloody thing sucking power out of my engine, I thought it was bad fuel till I turned my HID off! Very freaky.Anyway whatever you end up with make sure you have tested it. Asuume nothing with this, because it could be a rally ender!
Racing Rallye Raid Dos Sertoes 2010 Ride report: LIVING THE DREAM - Racing 4,500km across Brazil. a n00b goes Rally racing- How to get into Rally RIFF RAFF 2011 - GO JONAH! |
11-15-2010, 12:52 AM
#235 |
Oddometer: 324
All you really need to do is figure out whether you're using more watts than your charging system can supply (on average) - if so, you're in trouble, if not your OK (subject to the amount of starting you do). Measuring voltage at the battery is essentially a proxy measure to determine whether the charging system has enough juice to charge the battery.
Basically, your battery's a bucket you trickle a hose into (charging) and pour out of (starting) plus a few steady leaks (ignition system, lights, etc). PS you want about 5,000 rpm to take a meaningful charging voltage at the battery. Good luck.
"Rally racing makes heroin addiction seem like a vague craving for something salty!" (Apologies to Peter Egan) The appropriate number of cylinders for any motorcycle is two. Billy.B.F. screwed with this post 11-15-2010 at 02:47 AM |
11-15-2010, 02:28 AM
#236 | |
Oddometer: 1,386
You dont wanna drop out because of the darn HID light... Anyway, dont think you need to worry about arriving in the dark.. Just keep going and youll get there before dark. Jenny, please, do call Ewout at rallybikecenter.com and ask him for his experiences, he has built all the Yamaha Europe WR's in the past and knows the ins and outs. I think he will tell you the same thing as Bluebell experienced. |
11-15-2010, 02:37 AM
#237 |
Oddometer: 4,942
Hey Jenny,
I would definitely try to find somebody with a good multimeter and current clamp so you can accurately measure the draw of the individual items as well as the actual power your stator is making. I just got a new Fluke setup that you can borrow if you can't find anybody local, but it would take a few days to ship over there. I know your HID is supposed to be 35W but some of them use quite a bit more. And even if 35W is accurate, I doubt that your 100W electrical system will be able to put up with everything at once. 35W HID + 35W main light + 25W or so for the fan (that's what the Spal fan on my KTM draws) + 5W tail light + a few watts for the navigation gear. And don't forget that the ignition of the bike draws quite a bit as well! It just doesn't add up, so I would definitely make both lights switchable and only run a single one (or none) as default. Cheers
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
11-15-2010, 04:01 AM
#238 | |
Dakar Dazed
Oddometer: 2,428
Their spec says 100W at idle... I'll see how much juice there is at 5000rpm as Billy suggests, and report back shortly... I really appreciate everyone taking an interest, particularly at this late stage... J x |
11-15-2010, 10:29 AM
#239 |
Oddometer: 1,332
I found this on a ThumperTalk thread:
![]() Your setup seems to be the same as the Trailtech running 2 HIDs (power wise), although I still think there is too much load on your system. This guy measured a solid 13.4V at 1/4 throttle, which is an ideal number to charge the battery! |
11-15-2010, 12:15 PM
#240 |
Dakar Dazed
Oddometer: 2,428
Thanks for the link (and the PM) Tony, and your concern and knowledge! Fortunately, I think I've got it sorted - and the guys at Trail Tech weren't bluffing after all...
I refitted the HID loom this afternoon (without the tell-tale lamp) and fired up the bike... with the choke on (so around 3000rpm), I was getting 13.8V at the battery terminals with the stock 35w headlight on, 13.56V with the stock headlight and HID on, and 13.26V with the headlight, HID and Fan (plus the Nav gear) running... all good stable voltage readings too. Even at tickover (with the choke off) I was getting 12.8V steady with everything running, and raising the revs it was well into the 13.5V zone... A proper road-test will confirm tomorrow, but I'm confident there is enough power from the Trail Tech stator to keep the battery charging while the all gear is running - and as I mentioned previously, the HID and fan are independently switchable, so I can turn them on and off as required - it should be rare I'll need them all on at the same time anyway... I've also had more good news regarding sponsorship - no major sponsor (to cover my service assistance costs), but I've got a cost price deal on a new Arai helmet plus a load of service consumables - TwinAir filters, oil filters and chain guide and slippers, oh and some spare fork seals just incase... thanks to the UK importer Apico. I've also had a fantastic 11th hour offer from a dealer who can provide me with spare drive chains and sprockets, and has negotiated on my behalf all the engine oil I'm going to need from Putoline - so that is pretty much my service consumables covered now - all I need is a load of tyres! I've also had confirmation from Dirty Dog that they can supply me with some really tasty sunglasses to be included in the supporters packs - these are great glasses on or off the bike, they have unbreakable polarized lenses and great eye coverage (without looking like Bono!). I've used them all over the USA, and racing on both Heroes-Legend and in Tunisia, only requiring goggles on the really dusty days... I think you guys are going to love them! Kriega have also sprung for some really nice wallets, which double as a compact tool pouch - again photos to follow, but these are just the coolest piece of kit for your bumbag, tailpack or even a jacket pocket. Alpinestars have also provided some really nice baseball caps (along with some new boots for me) for you all, so the packs are really coming together now and should offer real value for money, with products that I genuinely endorse and have used for years... I'm hoping to get a few more bits to include, plus there will of course be a limited edition T-shirt with all the sponsors logos on... Toot toot for now! Jenny xx |
