Old 11-26-2010, 06:50 AM   #316
JMo (& piglet) OP
Dakar Dazed
JMo (& piglet)'s Avatar
Oddometer: 2,427
Originally Posted by LukasM
By the way Jenny, did you get a chance to weigh the bike once it was completed?
Hi Lukas - no, I didn't think to to be honest, but I imagine it is around 150Kg with everything fitted (but not full of fuel) - that's what I put on the shipping form anyway x
JVO reckon their kit 'only' adds 16Kg to the stock weight of the bike, so that's around 135Kg...
I'm not running their rear tank of course, but I doubt it is much lighter than the stock subframe and Safari Tank I do have?
The main extra weight is all the navigation gear, plus a heavier wheel-set (cush-drive hub, mousses and Michelin Deserts), then there is the metal bash-plate and water tanks too.
Certainly the bike feels nothing like as heavy as my Tenere did last year, so picking it up out of the sand is going to be a whole lot easier this time round!
If I can get it on some scales I will, and let you know...
Jx
JMo (& piglet) screwed with this post 11-27-2010 at 04:39 AM
JMo (& piglet) is online now   Reply With Quote
Old 11-26-2010, 06:21 PM   #317
Bluebull2007
Bluebull2007's Avatar
Oddometer: 3,331
Originally Posted by PPiA
The Autocal works by you changing the distance each time to match the route sheet. After a few times the ICO adjusts to those inputs. I think it's designed to ignore the first couple of times for when you take a wrong turn.
Lots of people don't like it, but I think it's great.
It takes into account variations between whatever vehicles the route sheet maker was in. I noticed I got mine spot on for the first couple of days in the Alta Turia, but on the 3rd it went out of wack. Turned out it was an old sheet they reused, done in a different vehicle. After the first few corners I was good to go again. Others just had to put up with the discrepancies, or muck around with their wheel diameter settings.
Thanks for this response. A number of folks told me to aviod the autocalc, but after you made it sound so simple, maybe its worth a bash after all.
So do you run on 100dredths or tens in your racing?
Racing Rallye Raid Dos Sertoes 2010 Ride report:
LIVING THE DREAM - Racing 4,500km across Brazil.
a n00b goes Rally racing- How to get into Rally
RIFF RAFF 2011 - GO JONAH!
Bluebull2007 is offline   Reply With Quote
Old 11-27-2010, 04:43 AM   #318
JMo (& piglet) OP
Dakar Dazed
Oddometer: 2,427
Oi - get a room!
Let's get this thread back on track shall we?!
I'm hoping to have the T-shirt design finalized early next week, then the supporters packs will be ready to order... remember there will only be 50 sets available, so not only will you get some great gear, but it's going to be pretty exclusive too!
More info shortly...
Toot toot!
Jenny xx
JMo (& piglet) screwed with this post 11-27-2010 at 02:13 PM
Old 11-27-2010, 11:06 AM   #319
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 6,844
This is what happens when you let your manager design things...
NordieBoy is offline   Reply With Quote
Old 11-27-2010, 01:02 PM   #320
F650Dakar_Norway
What off-season?
F650Dakar_Norway's Avatar
Oddometer: 904
Originally Posted by JMo (& piglet)
The 'full-power' spec of the WR is a 175 main jet, and I've also got a 168 and the stock 160 with me - so if I have problems, then we can change the jet size for the higher days, but to be honest, I'd rather not feck about with the carb unless I really have too. The bike is running very sweetly at the moment, and I don't like to disturb it!
Jx
I'm considering the R&D Power Bowl for my own Katoom 690 Rally to easen the carb jet adjustment complexity. It's a bolt-on outside-adjustable jet-adjustment kit for the Keihin FCR-MX flat-slide carb. Should make things a bit easier on-the-fly even for you Dakar-folks. On my bike the front fuel tanks are quite easily removed, but on a long haul I reckon it's OK not having to remove the carb bottom to manually change fuel jets when needed.
Source:
http://www.r1dean.com/cart/
For Yamaha FCR-MX carb:
http://www.r1dean.com/cart/index.php...index&cPath=31
Installation:
http://www.r1dean.com/support.html
Found this article about it on a WR450F:
http://www.dirtrider.com/reviews/dir...50f/index.html
Norway
________________________________
Current stable:
2010 BMW F800GS
2008 KTM 690 RR
'04 BMW F650GS Dakar
'94 Honda ST1100
'09 Garmin Zumo 550
F650Dakar_Norway screwed with this post 11-27-2010 at 01:10 PM
F650Dakar_Norway is offline   Reply With Quote
Old 11-27-2010, 01:03 PM   #321
SonHomme
Team F5,⌘R FYCYFF
SonHomme's Avatar
Oddometer: 558
"For God so loved the world that he gave his one and only Son, that whoever believes in him shall not perish but have eternal life." John 3:16
I use to smoke, now I vape.
DP: I was thinking, "all these people ...are sleeping now". Nope, you're all still on! When do you sleep?!
PackMule:Third week of January. n00b.
TEAM F5, rank: ⌘R ===> FTW
SonHomme is offline   Reply With Quote
Old 11-27-2010, 01:04 PM   #322
matheas
matheas's Avatar
Oddometer: 36
Just Caught up with this thread. Sounds like you are going to have a blast and I am looking forward to following your progress. Just keep the rubber side down and all will be well. Go get 'em JMO.
matheas is offline   Reply With Quote
Old 11-27-2010, 02:23 PM   #323
PPiA
Pete
PPiA's Avatar
Oddometer: 956
Tenths.
Sorry Jen, go Piglet!
PPiA is offline   Reply With Quote
Old 11-27-2010, 03:24 PM   #324
spick
Oddometer: 50
Hate to be a stick in the mud but be careful there with the logo. You wouldn't want to get whacked with a copyright infringement suit after the shirts are printed. That's something you might want to check into. Disney doesn't play nice when it comes to these things.
06 WR450F
2011 Riff-Raff - Go Jonah
spick is offline   Reply With Quote
Old 11-27-2010, 03:30 PM   #325
tserts
Gas Burner
tserts's Avatar
Oddometer: 1,956
Yeah, make it "JoMomma Racing" (JMo for short) and you can then watch your supporter packs fly off the shelves like hot cakes...
Africa Twin RD07 '00 - My Kleopatra
Malfunction specialist...
Road Rush (Romania, Serbia)
Peloponnese Peninsula on two Africa Twins
9 countries in 15 days - Tserts.com
tserts is offline   Reply With Quote
Old 11-27-2010, 03:37 PM   #326
JMo (& piglet) OP
Dakar Dazed
Oddometer: 2,427
Who's to say that is a Disney piglet? The original was actually a drawing downloaded from a copyright free website, and has been modified...
"Any resemblance to characters living or dead is purely coincidental..."
J x
Old 11-27-2010, 05:03 PM   #327
JMo (& piglet) OP
Dakar Dazed
Oddometer: 2,427
How about I wrap him in a swaddling...?
Jxx
Old 11-27-2010, 05:07 PM   #328
Kyler
Confused Hack Nut
Kyler's Avatar
Oddometer: 2,523
Jxx
I dig it! Where do I sign up?
Ken => I'm a DAMN Rider (No rules, just ride!)
Happiness is a 3-wheel drift!
Member of the Maryland OHV Alliance
Kyler is offline   Reply With Quote
Old 11-27-2010, 09:57 PM   #329
Remarksman
Oddometer: 419
Excellent thread!
I just found this great story of your preparation for the Dakar yesterday and have been enjoying the peek into some of the many details tremendously.
But this:
...takes the cake! That is hilariously awesome!
Remarksman is offline   Reply With Quote
Old 11-28-2010, 02:09 AM   #330
bamarider
Adventure n00b
Location: Stuck in Kosovo, living vicariously thru ADVRider
Oddometer: 89
Dakar Dazed...
Piglet sure does look Dakar Dazed..
Go Jmo... Go!!!
'86 Honda VFR
'89 Honda Transalp
'91 Honda ST1100
All at home patiently awaiting my return
'89 Yamaha XTZ 750 Super Tenere
Balkans Adventurer...
bamarider is offline   Reply With Quote
Times are GMT -7.   It's 01:50 PM.
