Old 09-17-2013, 05:40 PM   #1
Enduronut357 OP
Oddometer: 36
1975 dt400 exhaust
Is the baffle removable on the 1975 dt400 exhaust system? cause mine has a ring of the baffle rattling around inside of it and i need to get in there to remove it and also to clean it a wee bit better thanks in advance
Enduronut357 is offline   Reply With Quote
Old 09-17-2013, 07:28 PM   #2
Enduronut357 OP
Oddometer: 36
anybody? this forum is way slow in replies :(
Old 09-17-2013, 08:25 PM   #3
Scootern29
Scootern29's Avatar
Oddometer: 514
I would think it is removable. Most are. Sorry for the slow response we may be working on bikes.
Scootern29 screwed with this post 09-17-2013 at 08:26 PM Reason: more info
Scootern29 is offline   Reply With Quote
Old 09-18-2013, 03:10 AM   #4
Twin-shocker
Oddometer: 1,673
If its the front pipe, you will need to cut it open, repair and repack, then weld back together.............not a nice job! If its the back box, then some OE parts have removable baffles, but if not then get a back box intended for MX bike and modify to fit.
Old 09-18-2013, 02:46 PM   #5
joexr
Oddometer: 3,773
Look at a microfiche picture on one of the parts websites and you'll see where it comes apart. Try Chaparral.
Old 10-04-2013, 10:21 AM   #6
JR Greenhorn
JR Greenhorn's Avatar
Oddometer: 335
The silencer on my '79 YZ125 was doing the same thing. I cut one end of it off, pulled the loose baffle tube out, an then used a cutting torch to carefully burn off years of oil-soaked carbon buildup (without melting or cutting through the pipe). When it was clean, I had the baffle welded back in place, repacked it with new material, had the end I cut off welded back on, and then finally repainted it all. The bike finally ran great and the exhaust looked decent, if not factory.
Would I do it again? No, never. Just measure the stinger diameter and buy an aftermarket/universal fit silencer and figure out what it will take to get it mounted. It will be the same or less work to do that, and then you'll have something that's easily re-packable.
JR Greenhorn is offline   Reply With Quote
Old 10-04-2013, 10:46 PM   #7
Inane Cathode
Cheated Anion
Inane Cathode's Avatar
Oddometer: 4,601
Are you talking about the turbine piece that's down inside the end 6 inches or so, or the actual baffles further in there? Both should be spot welded to the outer casing of the muffler, the only removable part on that exhaust is the very end "spout" looking piece (you might have a little tube attached to the spout piece).
_______
Pokey The Wunderbus
The VEEP Project
Inane Cathode is offline   Reply With Quote
Times are GMT -7.   It's 08:27 AM.
