Old 11-01-2013, 08:17 PM   #14806
Colonial Mick
Nettle Licker
Colonial Mick's Avatar
Oddometer: 2,412
Originally Posted by philth View Post
can anyone find a 12 volt cig or usb charger for the battery on a dji phantom quadcopter?
Phil do you need a 12volt source with a voltage reducer to charge your battery? What is the battery voltage?
http://www.ebay.com.au/itm/1x-USB-Ca...item565d4fe9e4
This is easier. Then just use your 240 volt charger.
http://www.ebay.com.au/itm/12V-DC-to...item4150bf0831
I have one of these to use on the bike. Had it for years .It charges my Scalar rider camera music thingo and anything else I need to have 240volts for. Saves having heaps of extra chargers.
http://www.ebay.com.au/itm/Doss-PIN3...item20d59757e9
"Be who you are and say what you feel.
Because those who mind don't matter
and those who matter don't mind".
Colonial Mick screwed with this post 11-01-2013 at 08:52 PM
Colonial Mick is offline   Reply With Quote
Old 11-01-2013, 10:34 PM   #14807
Doctor
Prez of nEVs Fanclub
Doctor's Avatar
Oddometer: 8,258
A2 banned , wtf did i miss, as i was off on my bike .....
Stolen from Baz
'must be the 'ooooohhhhhmmmmm' factor kicking in'
Doctor is offline   Reply With Quote
Old 11-01-2013, 10:49 PM   #14808
tHEtREV
Captain Awesome
tHEtREV's Avatar
Oddometer: 7,675
A lot of bannings happen with no evidence of what they did being left behind.
I used to see someone was banned (you included), have a look at there profile and look at there last few posts.
On a lot of people you don't even see anything that was remotely offensive.
It often makes me wonder if the offending posts get banished from the internet, or they were being dicks in PMs to mods.
Not saying they did or didn't deserve it, just an observation....
tEAM iDIOT.
A KDX is way cooler than what ever you ride...
tHEtREV is offline   Reply With Quote
Old 11-01-2013, 11:10 PM   #14809
Phil_Fong
Labelled Extremist
Phil_Fong's Avatar
Oddometer: 13,050
He posted a picture of Hitlers winking arse.
2 weeks apparently.
tEAM nONG - Quorn Schnitzel Club
Phil_Fong is offline   Reply With Quote
Old 11-01-2013, 11:31 PM   #14810
philth
philth
philth's Avatar
Oddometer: 6,198
thanks guys
might just get a few spare batts and stick with me 240 charger
hang on what about an inverter?
i must not post hairy buttocks
philth is offline   Reply With Quote
Old 11-01-2013, 11:45 PM   #14811
dunc59
dunc59's Avatar
Oddometer: 509
i was looking at getting one of these inverters as they also have a usb outlet as well as the 240 v outlet
http://www.supercheapauto.com.au/onl...om=40704#Cross
TRIUMPH 1200 explorer
dunc59 is offline   Reply With Quote
Old 11-02-2013, 01:53 AM   #14812
Merlinzen
Oddometer: 110
Jaycar has a similar one on special ATM:
http://www.jaycar.com.au/productView.asp?ID=MI5127
$38
Merlinzen is offline   Reply With Quote
Old 11-02-2013, 02:41 AM   #14813
Colonial Mick
Nettle Licker
Oddometer: 2,412
Get a decent one. Mine is OK but it did over heat and I had to vent the case but it works fine now. Don't run your TV off the crapy ones or you will need to buy a new one.
Old 11-02-2013, 02:42 AM   #14814
Colonial Mick
Nettle Licker
Oddometer: 2,412
thanks guys
12V in Phil then just plug in your 240volt charger.
Old 11-02-2013, 08:43 PM   #14815
tHEtREV
Captain Awesome
tHEtREV's Avatar
Oddometer: 7,675
Does anyone know if the wiring diagram has any correlation with the way wires go into plugs?
For example, if we had a six pin plug in a two rows of three pins arrangement, and the wiring diagram has it as a box with six wires coming into it, do the usually have the wires marked in a pastern, like reading from left to right, the first is the lower left on the plug, 2nd top left, third middle bottom etc, or is there no set pattern?
I'm trying to wire in a CDI but don't have the plug...
tEAM iDIOT.
Old 11-03-2013, 01:26 AM   #14816
neilaction
Slightly Less Adventurous
neilaction's Avatar
Oddometer: 7,038
The short answer is yes.
The wiring diagram will have the wires in order 1-6.
The plug should have the pins labelled.
If not then you will need a plug layout diagram which should be with a wiring diagram.
A wiring diagram is different to a circuit diagram. BTW.
If it can't be fixed with a hammer, its probably electrical.
2009 Honda CBF1000, 1980 Suzuki GS1000ST (Aus spec), Dr6fiddy,
neilaction is online now   Reply With Quote
Old 11-04-2013, 08:39 PM   #14817
GSnovice
Beer me up, Scotty!
GSnovice's Avatar
Oddometer: 1,611
Question for the tech heads
We're looking around for a multi-function colour printer/scanner/copier for home use. Networkable(?), capable of scanning slides/negatives, individual ink cartridges, read direct from cards/usb stick etc etc. There's a squillion of 'em around - anyone got any experience with them?
Harley Davidson - The best way to convert petrol to noise without the side effect of horsepower.
GSnovice is offline   Reply With Quote
Old 11-04-2013, 08:44 PM   #14818
ECKS-Man
ECKS-Man's Avatar
Oddometer: 859
Might have to narrow it down a little! What size paper, do you need A3? Do you need colour printing or just colour scanning? Inkjet or laser?
Work to live, Live to Ride!
ECKS-Man is offline   Reply With Quote
Old 11-04-2013, 09:07 PM   #14819
lentil
All round nice guy
lentil's Avatar
Oddometer: 8,022
We use a little HP @ home with a wireless setup so I can print wirelessly across the my network (I tend not to use a print server or any other network devices - saves setting up a print server etc etc!)
Its great I can set it up so that I can print from either PC in the house - and then if I need to remote print I just dial into my machine via VPN and print from there
I would spend a bomb on the printer just make sure the cartridges wont send you broke as that seems to be the big issue (I am too tight and have removed the printer use from the kids )
Leith
F5 is for wussies Command R is where the actions at!
Apple fanboy
Originally Posted by troy safari carpente View Post
It's the classic freudian slip... "come out of the closet, and jump into the jaccuzzi with the rest of us..."
lentil is offline   Reply With Quote
Old 11-04-2013, 09:58 PM   #14820
D_A
D_A's Avatar
Oddometer: 1,242
HP, Cannon and Brother are all usually pretty good. I also prefer HP but that's just personal preference, they' all have good and bad models. As Lentil mentioned, spend more on the printer if you can spend less on the ink/toner. You will come out ahead pretty quickly. If you only rarely print anything, get a laser printer. Ink dries in the print heads if left long enough and can cost you a new printer if it gets bad enough while toner is good to go almost forever if it stays dry.
D_A is offline   Reply With Quote
Times are GMT -7.   It's 08:29 AM.
