Thread Tools Search this Thread Rating: Thread Rating: 58 votes, 5.00 average. Display Modes
Old 05-10-2013, 05:54 PM   #361
canadasax
canadasax's Avatar
Oddometer: 345
Power cord or 276 and 78?
I have a 276c on my bike that is hard wired to the battery.
Can I use the same power cord to power my 78 (that I am thinking of buying)
They both use the round power plug and they look the same.
I love the 276 but it doesn't have a microcard slot.
canadasax is offline   Reply With Quote
Old 05-10-2013, 06:56 PM   #362
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,770
I don't think it is the same, but all I have to go by is pictures of the 276C cable online, and it does not look the same as the one I had for my other Garmins which used the 78 type of connector.
This is the 276C cable.
This is the 60/76/78 cable.
Not a great picture but it is much rounder than the 276C as far as I can tell.
Emmbeedee is online now   Reply With Quote
Old 05-10-2013, 07:00 PM   #363
SnowMule
[angry moth noises]
SnowMule's Avatar
Oddometer: 18,719
Yup, that big round connector is standard across most Garmin receivers.
I say "Most", because there's a few (like my ancient GPS12) that couldn't take more than 8 volts on the power lines. The presence of a center pin tells you it's a low-voltage model.
Spewer of the poignant non sequitur
#155 | Mule's Photos | BackCountryRebels | ThumperTalk | Tekrider | TylersBA
SnowMule is offline   Reply With Quote
Old 06-27-2013, 09:28 AM   #364
Countdown
Oddometer: 5,707
62/78 Setup
If you only use Tracks in your 62/78 or participate in Dual Sport rides and follow their Tracks, I have Setup instructions along with may other tips for using your 62/78.
They can be found on my web site:
http://www.dualsportwest.com/Gps/GpsOverview
Jerry Counts
Countdown is offline   Reply With Quote
Old 06-27-2013, 12:08 PM   #365
Countdown
Oddometer: 5,707
Transfering gpx file
I copied a gpx file into the gpx folder in my 78. I can see the file there but the 78 does not see it, that is the tracks do not show on the map page.
I used Mapsourse to downloaded the tracks and waypoints and now there is a temp file in the gpx folder and all the tracks show on the track page and map page.
What am I doinig wrong?
Jerry Counts
Old 06-27-2013, 01:26 PM   #366
HogWild
Scott Whitney
HogWild's Avatar
Oddometer: 2,766
You're thinking logically.
New desert racing frontiers
It will be Devilish !
HogWild is offline   Reply With Quote
Old 06-27-2013, 02:06 PM   #367
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,770
Send me the file as an email attachment and I'll try it on my 62S.
Old 06-28-2013, 12:04 PM   #368
Countdown
Oddometer: 5,707
Totally forgot it was Garmin!
On 3-Day Austin to Eureka and back. See D37 message board.
Jerry Counts
Old 07-01-2013, 06:59 AM   #369
Countdown
Oddometer: 5,707
This is it
Jerry Counts
Old 07-02-2013, 03:53 AM   #370
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,770
So what's supposed to be wrong here? My 62S is not handy so I transferred the file through Basecamp to my Montana and all the tracks are in the Track Manager, ready to use, and so are all your waypoints, in the Waypoint Manager.
Old 07-02-2013, 05:49 AM   #371
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 6,270
Dumb question....I am using my 62s for a lot of onroad riding and I have a minor issue that may have been discussed but I can't find it. I prefer to use the "Trip Computer" as my main screen. Is there a way to set it to switch to "map" when approaching a turn? My other GPS's can do that, but can't seem to do it with the 62.
TIA
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966
RichBeBe is offline   Reply With Quote
Old 07-02-2013, 06:04 AM   #372
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,770
TIA
Not a dumb question at all, but you won't like the answer. It's not possible to get any of the new generation of Garmin handheld units to switch and notify you on upcoming turns.
Even the mighty Montana won't alert you.
Old 07-02-2013, 05:28 PM   #373
Countdown
Oddometer: 5,707
See post 365. copied .gpx file to 78 and it is there but no track in track manager.
Jerry Counts
Old 07-02-2013, 05:30 PM   #374
Countdown
Oddometer: 5,707
Tell me, why on earth would you ride with trip computer page on?
Jerry Counts
Old 07-02-2013, 05:30 PM   #375
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,770
See post 371. I used Basecamp and sent the file to the gps and it worked.
The problem must be your procedure because the file is fine.
HTML code is Off
Times are GMT -7.   It's 04:42 AM.
