Thread Tools Search this Thread Rating: Thread Rating: 58 votes, 5.00 average. Display Modes
Old 05-23-2014, 11:29 PM   #661
Herkjerk
Herkjerk's Avatar
Oddometer: 408
Originally Posted by Countdown View Post
Do mean you have a solar panel with a regulated 5V (USB) output on mini USB plug?
If so, yes you could plug it into USB connector on your 62 and the 62 would automatically toggle between internal battery and external solar panel when available.
Well according to the specs on the thing it says it has a "5v output to device" it has an internal 5400 mAh lithium battery so I was hoping it would consistently run of that battery regardless if the GPS' own batteries are dead or not. Worst case scenario I just use the solar charger to charge the batteries.
Herkjerk is offline   Reply With Quote
Old 05-24-2014, 05:25 PM   #662
Countdown
Oddometer: 5,707
Sounds like Plan A would work just fine.
Jerry Counts
Countdown is offline   Reply With Quote
Old 06-10-2014, 09:59 AM   #663
ram1000
ram1000's Avatar
Oddometer: 1,835
Just bought a 62s and ordered City Nav from GPS City. I see it has a bunch of mapping on the unit that I guess is of no use to me can I just delete those or do they overlay into the City Nav maps for one reason or another?
A good adventure bike will get you to where you wish you had a good dirt bike! (and back)
:2014 XC800 :2012 WR450
ram1000 is offline   Reply With Quote
Old 06-10-2014, 10:10 AM   #664
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,770
That 62S was new or used? Modern Garmin handhelds like the 62/78 can have many maps onboard, in separate files, so existing maps don't necessarily need to be removed.
Sent using strings and tin cans and Tapatalk.
Old 06-10-2014, 11:04 AM   #665
Countdown
Oddometer: 5,707
No, no.
No need to delete any existing maps.
They do not over lay (transparent), it only displays one set at a time no matter how many are turned on but there is an order and it redraws all each time it moves (if like 60/76) so best to turn on the one you want and turn the others off except base map in case you ride off the one you are using..
Jerry Counts
Old 06-16-2014, 09:53 AM   #666
Bosky
Long Haul ADV
Bosky's Avatar
Oddometer: 254
Hey guys I'm sorry to drop in like this but I'm between 62s and 78,for light trails up north WI in MI and a lot of street riding.I'm trying to figure out how important 24k Topo map are ,how they interact with base map that comes with device.And where CN come into play not raly sure if you have to switch to CN manual or the whole thing takes over automatic.Price point of 78 makes little more sense then 62s.
CN and 24k topo maps come on data card so how you use 2 data cards.
This time next year we'll be millionaires.
Sr Del Boy Trotter
Bosky screwed with this post 06-16-2014 at 10:01 AM
Bosky is offline   Reply With Quote
Old 06-16-2014, 03:30 PM   #667
SnowMule
[angry moth noises]
SnowMule's Avatar
Oddometer: 18,716
Of the two...
> 78 because external power connector
> Forego the topo maps (you're in IL, how many hills are there, really? ) and install CityNav. Far more useful.
Spewer of the poignant non sequitur
#155 | Mule's Photos | BackCountryRebels | ThumperTalk | Tekrider | TylersBA
SnowMule is offline   Reply With Quote
Old 06-16-2014, 03:59 PM   #668
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,770
Keep in mind the 78S is more directly comparable to the 62S.
Wireless file transfer and a faster usb port are both worth getting.
Old 06-16-2014, 05:56 PM   #669
Countdown
Oddometer: 5,707
Worth it to you or him?
Jerry Counts
Old 06-16-2014, 06:03 PM   #670
250senuf
250senuf's Avatar
Oddometer: 2,410
Better off to get the maps on DVD rather than the data cards. Then load what you want/all you want onto the 78.
Not all who wonder are confused
250senuf is offline   Reply With Quote
Old 06-16-2014, 08:22 PM   #671
Bosky
Long Haul ADV
Bosky's Avatar
Oddometer: 254
62 just looks more rugged and trail friendly, based on looks.No proper charging capabilities is huge disadvantage.
Chitalk
Sr Del Boy Trotter
Old 06-17-2014, 03:22 AM   #672
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,770
Chitalk
None of the handhelds but the Montana and Monterra charge through USB. The 4 pin and USB only provide power to run the GPS, not charge it.
Old 06-17-2014, 03:29 AM   #673
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,770
One recent exception is the latest Oregon 600 series. It has a battery which is USB rechargeable.
Old 06-17-2014, 03:42 AM   #674
XRman
XRman's Avatar
Oddometer: 3,015
possibly misleading
Originally Posted by rickypanecatyl View Post
That does work to power the unit. The issue is it will likely cause the unit to fail with any kind of moisture/rain.
Great care should be taken when using it.
Sent from my C5502 using Tapatalk
14000 km later in all weather my hard wired 62s is still working. go figure!
XRman is offline   Reply With Quote
Old 06-17-2014, 04:31 PM   #675
Bosky
Long Haul ADV
Bosky's Avatar
Oddometer: 254
Can anyone explain in short terms how CN works with device base map, and what happens when you add topo maps.Is there simply Road and Trail function that you switch or everything interact with each other.
Chitalk
Sr Del Boy Trotter
HTML code is Off
Times are GMT -7.   It's 10:23 PM.
