Old 09-08-2010, 08:49 PM   #1
Oz-Strom OP
Still trying
Oz-Strom's Avatar
Oddometer: 768
21" spoked front wheel on a F650GS?
Has anyone done this for improved dirt performance Also anyone fitted an 18" rear?
I did this on my Aprilia Pegaso Trail, and like the fact that I can swap the std road wheels for the dirt wheels with knobbies for when I go serious ADV riding. I am considering this bike as a replacement.
Thoughts and recommendations please?
Cheers
Graham
Oz-Strom is offline   Reply With Quote
Old 09-09-2010, 01:54 AM   #2
LukasM
Oddometer: 5,426
Marky did it, there is a thread with lots of pictures. The front from an F650 single (Dakar version has 21" front) will bolt in with the twin spacers, just flip it around to get the brake disc on the right side.
The 17" rear from an F800GS will bolt right in as well. You can also make a KTM 950/990 18" wheel fit, but it will require some custom spacers and an adapter plate for the brake disc. Not quite finished with mine yet, but it's from a 950 Super Enduro and has a super strong 2.5" wide Dirt Star rim.
Old 09-18-2010, 08:10 PM   #3
elijahl2
Midlife BMW crisis
elijahl2's Avatar
Oddometer: 10
Nicely done.
Good info. I'm thinking about doing this as well to my 2010 F650GS Twin. I'd like to hear more reports on it first before dropping the cash for it. Thanks for the post and keep them coming.
~elijah
BMW F798GS 2010 (650 doesn't ring true)
Honda Deauville '02
Honda Trail 90 '84
I'll race my 650 against your 650!
elijahl2 is offline   Reply With Quote
Old 04-25-2011, 11:51 PM   #4
DakarboySA
Oddometer: 51
Do you guys know if its possible to put 21'' dakar front rim on a f650 twin Cheers.
DakarboySA is offline   Reply With Quote
Old 04-26-2011, 12:30 AM   #5
Mike.C
Stelvio Dreamer!
Mike.C's Avatar
Oddometer: 592
Woody can now make one.
Be aware that RAD makes these hubs from Woody's initial suggestions and design. Under no circumstances would I ever buy them from RAD as they modified the bearing design from Woodys' specs and there have been 4 complete failures that I know of, we evaded failure by some diligent pre flight inspection and after much investigation Woody discovered RADs' un documented and badly executed alterations to his design.
Woody now gets the hubs from RAD and re specs them back to his original and much more robust design. If you want to see them in the flesh, PM me.
Hmm just noticed you wanted a 21", ours are standard size but I see no reason why Woody couldn't lace a 21" rim onto the hub. Then the only difficulty might be clearances.
Sal chickened out 3
Cheers, Mike
Don't just look at it - Ride the bloody thing!
Mike.C screwed with this post 04-26-2011 at 12:39 AM
Mike.C is offline   Reply With Quote
Old 04-26-2011, 09:13 AM   #6
markymcd
markymcd's Avatar
Oddometer: 887
I've used the f650gs single front wheel (it's a 19") and had woody build me a rear from a 800gs hub and Exel Takasago rim. I stayed with the same size as I'm vertically challenged but check out "A"'s thread. He started with the 650 twin and put a KTM front end on and i'm sure it's an 18" rear. Not 100% sure if the Dakar front will work but take a look at the schematics on BikeBandit and see if the 19" GS and 21" dakar have similar hubs and brake rotors.
I'd be a little concerned about putting a 21 on the front with the existing forks. there might be clearance issues with full fork compression.
I've done a few more mods since this photo... 2" rox risers. painted lower panels charcoal. removed front fender and added upper rear 650 single front fender. Tail tidy is next.
cheers,
Mark
www.adventuredecals.com
markymcd is offline   Reply With Quote
Old 08-23-2013, 07:14 PM   #7
RBlake
Oddometer: 1
Bought a second set of stock wheels
I bought a second set of wheels. Mounted K60 Heidenau tires with a 42 tooth sprocket on the rear.
I can change my wheels between dirt/adventure and road/wet in a couple of minutes. The cast wheels are not nearly as durable, but my F650GS Twin is used more for commuting than anything else.
If I do more dirt, I'll probably look for a lighter bike. For now I feel like I have everything I need on this bike.
RBlake is offline   Reply With Quote
Old 08-24-2013, 07:22 AM   #8
ebrabaek
Oddometer: 4,810
I have a stock 21 in the flea market.....
Erling
Old 09-11-2013, 04:03 AM   #9
Juozaz
Juozaz F800GS Blonde
Oddometer: 23
21" spoked wheel with f800gs fork
One from most important things for f650gs.
Sorry friends, but how to import dirctly photos in this thread? Thank You, ebrabaek!
Juozaz F800GS AlpineWhite
Lithuania (ian)
Juozaz screwed with this post 09-11-2013 at 07:42 AM
Juozaz is offline   Reply With Quote
Old 09-11-2013, 05:26 AM   #10
ebrabaek
Oddometer: 4,810
Originally Posted by Juozaz View Post
https://plus.google.com/photos/11275...62436327911083
One from most important thinks for f650gs.
It appears your google link above is restricted. You need to host the picture on a online website. I use photobucket.com. It is free. Then you cross link it to this website. Takes a little to get used, but is fairly easy when you get started.
Erling
Old 01-12-2015, 05:03 PM   #11
Excite-Bike
Excite-Bike's Avatar
Oddometer: 179
Originally Posted by LukasM View Post
The front from an F650 single (Dakar version has 21" front) will bolt in with the twin spacers, just flip it around to get the brake disc on the right side. The 17" rear from an F800GS will bolt right in as well.
How would a 21" wheel and tire fit under a non-adjustable fender fixed to the forks that's meant for a 19" wheel and tire?
Excite-Bike is offline   Reply With Quote
Old 01-12-2015, 07:12 PM   #12
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,262
So a piece of plastic ends that plan?
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is offline   Reply With Quote
Old 01-12-2015, 07:17 PM   #13
Excite-Bike
Oddometer: 179
Dunno, but it leads to believe that nobody actually has done it without completely replacing the forks as the guy with the red bike above did.
Old 01-12-2015, 07:24 PM   #14
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,262
Fairly common mod.
No I don't have links......
Old 01-12-2015, 07:28 PM   #15
Excite-Bike
Oddometer: 179
Fairly common mod.
So if an old F650GS Dakar or new G650GS Sertão front 21" spoke wheel is a direct bolt-on for the F650GS Twin then what is done to the fender to make room for the extra 2 inches? It gets moved up with some custom work? Replaced with some aftermarket fender? You need the fender from the donor bike?
Times are GMT -7.   It's 09:46 PM.
