Old 09-10-2010, 10:54 PM   #1
Box'a'bits OP
In need of repair
Box'a'bits's Avatar
Oddometer: 2,241
Fitting a '91 R100GS with an HPN Tank
Okay, I've just imported an HPN 43l Tank to put on my 91 R100GS paralever. I am aware that you need to modify things to make this fit. Tell me (or better yet show me) what you have done.
Here's the thread on where we've gone with this bike so far...
Cheers, Steve
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is online now   Reply With Quote
Old 09-10-2010, 11:38 PM   #2
Padmei
enamoured
Oddometer: 3,657
It'll never work. You shouldn't have bought it. Best get rid of it before it starts to annoy ya.
Padmei is offline   Reply With Quote
Old 09-10-2010, 11:45 PM   #3
fishkens
Further...
Oddometer: 5,147
Cheers, Steve
My experince is a bit different since I put the 43 l tank on my 88 GS (it didn't have the plastic bits and "roo" bars making the fairing.
1 - install three brackets that come with the tank (two front and one just in front of the tool trak
2 - relocate oil cooler to central spot in front of the gas tank.
Forging ahead, down a false trail.
fishkens is offline   Reply With Quote
Old 09-10-2010, 11:51 PM   #4
fishkens
Further...
Oddometer: 5,147
Whoops, hit enter...
3 - Use bracket from BMW to mount oil cooler to frame
4 - Oil Lines? Back in 1991 I had to scrounge 'em up from Earles along with the fittings. Touratech or BMW can be a source today.
Hmmm, other items:
5 - Your fairing. I can't say how you'll need to modify it. My minimalist tendancies would be to sell it on fleabay and install a headlight and electonic gauge system of some sort. Hopefully you'll get better advice on that.
6 - I reommend replacing the nuts that secure the gas tank with metric wing nuts. Should you need to remove the gas tank to access spots underneath it this will save some time. (It seems that I remove the gas tank frequently...for fun).
That's what I've got.
Old 09-11-2010, 01:02 AM   #5
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,497
You'll need to modify your seat to fit it as well. It will involve cutting into the seatpan. On the upside, you could lose about 20 pounds of high up weight by getting rid of your fairing, roo bars, head light, gauges, etc and replacing them with a light weight dirt bike headlight and a trailtech or similar electronic instrument set. If you don't go that route though, you wouldn't be the first. Others have made it work:
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler screwed with this post 09-11-2010 at 01:35 AM
Airhead Wrangler is online now   Reply With Quote
Old 09-11-2010, 04:33 AM   #6
Box'a'bits OP
In need of repair
Box'a'bits's Avatar
Oddometer: 2,241
To answer my own question
Others have made the roo bars work, by adding 7cm (?) into the bars. The fairing also needed to be trimmed. Here's an example on a R80 Basic (from the UKGSer site).
Still be interested in others comments, particularly those that have done this. Once you start cutting things up its hard to go back.
I've also considered losing the fairing (the original plan) & using an R100 8" headlight, with electronic speedo.
Old 09-11-2010, 07:06 AM   #7
nowhereman
I'm lost -don't follow me
nowhereman's Avatar
Oddometer: 386
been thinking about this too
I have been considering getting the tank too, but in my case I was going to sell off all the old stuff (PD tank, fairing and dash) and going with a trailtech or soltek lighting setup and either an IMO 300 or something else for all the engine info. But then there's the seat issue, oil cooler relocation, etc.
Now if I could convince myself to drop the change on all that (feels like I'd be into it for around 2k after all the stuff is bought) and convince my wife the banker - nah never mind.
If you don't want to cut up your seat, you may find one still available at touratech. They used to sell them, but they're spendy.
Forgot to add - here's photos of my favorite HPN tank / gauge set up. You can get the whole shebang from africa queens in germany.
Here's the dash board / gauge tree
1990 R100GSPD
1964 LI125S with a 240 MRB kit
nowhereman screwed with this post 09-11-2010 at 01:54 PM
nowhereman is offline   Reply With Quote
Old 09-11-2010, 11:25 AM   #8
fishkens
Further...
Oddometer: 5,147
A Corbin seat also fits w/out modification. The code on the bottom of my seat pan is GS9.3CDS. I like this saddle because it doesn't have the lip at the front that stock saddle has.
http://www.equinoxmc.co.uk/index.php...roducts_id=138
fishkens screwed with this post 09-11-2010 at 08:17 PM
Old 09-11-2010, 11:28 AM   #9
fishkens
Further...
Oddometer: 5,147
Wrangler - Is that a Fox shock on that bike? Do you know if it's still working?
Old 09-11-2010, 03:20 PM   #10
Airhead Wrangler
Adios Mexico
Oddometer: 6,497
Not my bike so I can't say for sure, but it does look like one. The owner of the bike seems to have disappeared in the middle of a long trip to south america.
Old 09-15-2010, 04:46 AM   #11
Box'a'bits OP
In need of repair
Box'a'bits's Avatar
Oddometer: 2,241
Photo of your frame spine someone?
Okay, decided to ditch the '91 R100GS OEM fairing & go with an 8" light.
Test fitted tank to the bike & (as expected) I will need to trim some of the frame fittings & relocate where some of the electrical items are fitted. I'm keen to see how others has dealt to that. The relay space I have currently filled with a heated grip controller & enduralast regulator, which I now need to re-house.
Thanks for any helpful comment you can make.
Old 09-15-2010, 05:24 PM   #12
Uncle Pollo
happy cachiporra
Uncle Pollo's Avatar
Oddometer: 47,808
omfg
Uncle Pollo is offline   Reply With Quote
Old 09-15-2010, 06:28 PM   #13
bmwloco
bmwloco's Avatar
Oddometer: 1,416
My Acerbis 44 liter (now the HPN methinks) was on my R100GS back in
'93 when I was riding the US, NZ and Oz.
After a lot of thought, I just did away with the oil cooler. Mind you, I did that 9 months before I set out on my 9 month journey. It was never an issue. It also made service and maintenance a hell of a lot easier.
Still have this tank; it is going on The Beast (picking up in early October)
'66 BMW R60/2, '83 BMW R100RS,'81 BMW R100RS "Das Beast", '87 BMW R850R '77 Honda XL125
Airhead #371
bmwloco is offline   Reply With Quote
Old 12-09-2011, 06:09 AM   #14
Daithi
Destination Unknown.
Daithi's Avatar
Oddometer: 176
Hi, could one of you gentlemen post a photo of the longer hoses going to the new cooler position, I've the
cooler pushed out of the way to fit the tank but I don't have the longer hoses/mounts etc.
I just want to be sure the hoses will allow the cooler to sit in the right place and not foul when I fit a new
front end, so it's the length of each and a photo of the cooler in position if possible.
Thanks, Daithi.
CCM404 & DRz1000
Daithi is offline   Reply With Quote
Old 12-09-2011, 06:23 AM   #15
onaXR
Druid
onaXR's Avatar
Oddometer: 2,086
Cant see a bunch from these shots, but roo bars widened oil cooler in center of the frame behind the frt wheel, some electrics moved from top of frame under tank, and the fairing brackets widened a bit. Oil cooler lines are touratech.
Klaatu barada nikto
onaXR is offline   Reply With Quote
Times are GMT -7.   It's 04:54 PM.
