Old 12-09-2011, 06:37 AM   #16
Daithi
Destination Unknown.
Daithi's Avatar
Oddometer: 176
Hi, could one of you gentlemen post a photo of the longer hoses going to the new cooler position, I've the
cooler pushed out of the way to fit the tank but I don't have the longer hoses/mounts etc.
I just want to be sure the hoses will allow the cooler to sit in the right place and not foul when I fit a new
front end, so it's the length of each and a photo of the cooler in position if possible.
Thanks, Daithi.
CCM404 & DRz1000
Daithi is offline   Reply With Quote
Old 12-09-2011, 01:35 PM   #17
onaXR
Druid
onaXR's Avatar
Oddometer: 2,086
Best pics I can get right now.
Klaatu barada nikto
onaXR is offline   Reply With Quote
Old 12-09-2011, 06:13 PM   #18
Daithi
Daithi's Avatar
Oddometer: 176
Thumb
Apologies for the duplicate posts, I thought the first one hadn't worked, and OnaXR thanks, that's exactly what I needed. I'll need to get those pipes made up and your photos will help a great deal.
I'm awaiting delivery of a DRz400E front end and will post pics when I've both jobs done. Thanks again.
Daithi.
CCM404 & DRz1000
Daithi screwed with this post 12-24-2011 at 02:28 PM
Old 12-09-2011, 07:11 PM   #19
bereahorn
Oddometer: 1,070
bereahorn is offline   Reply With Quote
Old 12-10-2011, 07:12 AM   #20
onaXR
Druid
onaXR's Avatar
Oddometer: 2,086
Originally Posted by Daithi View Post
Apologies for the duplicate posts, I thought the first one hadn't worked, and OnaXR thanks, that's exactly what I needed. I'll need to get those pipes made up and your photos will help a great deal. I'm awaiting delivery of a DRz400E front end and will post pics when I've both jobs done. Thanks again.
Daithi.
Come over and put new pushrod seals on mine and we will call it even.
Klaatu barada nikto
Old 07-30-2014, 07:27 AM   #21
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
seat mod
Does anyone have pics of how/where the stock r100gs seat needs to be modified for the tank to fit? I'd rather have a bit of guidance before I get out the sawzall.
bmwblake is offline   Reply With Quote
Old 07-30-2014, 09:21 AM   #22
jclark83
jclark83's Avatar
Oddometer: 373
There is some info on the touratech site. It says about 1cm needs taken off the front edge of the seat where it meets the tank. If my solo seat pan I ordered ever shows up I will tell you exactly how much I cut off the nose to make it fit.
1992 Bmw R100GS
2002 Bmw R1150GS
2008 Bmw K1200LT
jclark83 is offline   Reply With Quote
Old 07-30-2014, 12:40 PM   #23
Box'a'bits OP
In need of repair
Box'a'bits's Avatar
Oddometer: 2,272
Yes, you do need to modify the seat pan (& then the seat cover) to fit. The bit removed is a wedge, rather than a total amount. You need the seat pan to parallel the back of the tank.
This is a picture of the seat, premodified, test fitted. Obviously I couldn't fully 'seat' the seat because of the overlap.
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits screwed with this post 07-31-2014 at 12:46 AM
Box'a'bits is offline   Reply With Quote
Old 07-30-2014, 02:15 PM   #24
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
Perfect. Thanks for the help.
Old 08-27-2014, 04:45 PM   #25
jclark83
jclark83's Avatar
Oddometer: 373
I took 15mm off the bottom in a wedge shape, zero point in the vertical axis is 60mm from the bottom. These measurements are for a Seibenrock replacement seat pan. I think I am going to take 60mm off the nose of the seat where it climbs up the back of the tank. I just don't like the way it looks. The rear of the HPN tank is an odd shape. What do you guys think? Cut or no cut?
1992 Bmw R100GS
2002 Bmw R1150GS
2008 Bmw K1200LT
jclark83 screwed with this post 08-27-2014 at 04:47 PM Reason: Pics
Old 08-27-2014, 05:32 PM   #26
Box'a'bits OP
In need of repair
Box'a'bits's Avatar
Oddometer: 2,272
I did exactly that, to make it fit better
Old 08-27-2014, 05:59 PM   #27
jclark83
jclark83's Avatar
Oddometer: 373
Ok, I looked at pics of your seat on your "Gus" thread. That's what I hoped it would look like if I cut the nose off. The kreiga 5l looks good. I'm going to borrow that idea.
1992 Bmw R100GS
2002 Bmw R1150GS
2008 Bmw K1200LT
Old 12-10-2014, 08:05 PM   #28
woodly1069
woodly1069's Avatar
Location: Louisville, KY...really too far from the hills!
Oddometer: 1,927
Can't wait to see the bike Jim!
If you can't fix it with a hammer, you've got an electrical problem!
woodly1069 is offline   Reply With Quote
Times are GMT -7.   It's 10:27 PM.
