Old 09-12-2010, 05:19 PM   #16
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,239
And that little knob behind the handle is to release/equalize pressure so they must be pretty air tight therefore watertight
He has a vairwee good fwiend in Wome you know
Big Willy is online now   Reply With Quote
Old 09-12-2010, 07:36 PM   #17
OBR650 OP
OBR650's Avatar
Oddometer: 398
I haven't mounted it yet, its just sitting on the rack. I've seen somewhere on the net mounting plates specific to Pelican Cases and V Strom rear racks, otherwise I will just make one up, I'll post pics if I do.
As to how tough these things are I can't see them being any weaker than Givi's or similar, I stood on it in the garage without any probs. The question is would you stand on a Givi case, drop it and/or bash it with a hammer and expect it not to break.
MR STACKALOT
OBR650 is offline   Reply With Quote
Old 09-12-2010, 08:53 PM   #18
Beach40
Beach40's Avatar
Oddometer: 2,975
Good find, I will check these out as well.
Any info in the packaging that mentions what type of plastic its made from or if its UV stable etc?
Beach40 is offline   Reply With Quote
Old 09-12-2010, 10:09 PM   #19
tripodtiger
I used to be SCRay
tripodtiger's Avatar
Oddometer: 4,720
Used to have a pelican case as a camera kit (well, fancy that?), in my previous occupation. It basically sat in the car for ever. The hot / cold cycling eventually warped the lid and it wasn't water/dust proof.
Later versions have the valve that needs to be kept open, unless it is in a wet environment.
Of course, if you drill holes in one side, that will probably also compromise it's waterproof-ness.
rayb Crash Dummy (no testing involved)
Old 09-12-2010, 10:09 PM   #20
Maggot1300
Oddometer: 246
SO were these at Kilsyth, ftg or the burwood hwy store? I noticed i'm just down the road from you (ftg) so figure i can easily enough get to the same store
Maggot1300 is offline   Reply With Quote
Old 09-12-2010, 10:58 PM   #21
OBR650 OP
OBR650's Avatar
Oddometer: 398
Bunnings Cantebury Rd, Bayswater. They're on a pallet just past the tool centre on the LHS.
MR STACKALOT
Old 09-12-2010, 11:05 PM   #22
Maggot1300
Oddometer: 246
cheers mate, I might drop past this week on the way back from work
Old 09-27-2010, 04:34 AM   #23
Sundowner
Bort
Sundowner's Avatar
Oddometer: 3,708
Bought one of these for duty on the S10 today (I suddenly feel so old - it'll be my first top box) at Bunnings Mile End for $65 (yep $20 off ). There's about half a dozen left, so be quick. They're on a pallet in the long central isle right behind the tool section. They'd make excellent cheap panniers if you used some 3mm alloy plate to reinforce the rear for fitting mount pucks. The hinges, carry handle and 4 clip catches look strong and the dust seal is well designed.
Sundowner is online now   Reply With Quote
Old 09-27-2010, 07:10 PM   #24
LittleHarleyGirl
Lady Adventurer
LittleHarleyGirl's Avatar
Oddometer: 12
Got one on the V-Strom
I have one of these boxes on the back of the V-Strom. Asked about the resistance to prolonged exposure to sunlight and the answer was "don't know", so I guess time will tell. I have a 345mm x 310mm x 5mm piece of aluminium plate bolted to the bike and the box bolted to it. I guess if you are worried about water resistance you could use rubber washers or a bit of silicone on the mounting holes. Intend to test it on a trip of some sort next year.
Harley (and Suzuki) Girl
LittleHarleyGirl is offline   Reply With Quote
Old 09-27-2010, 08:20 PM   #25
micq
micq's Avatar
Oddometer: 257
I went for the saftey yellow Kincrome box , [IMG][/IMG]
R1200GS
625 SXC
What one person receives without working for, another person must work for without receiving.
micq is offline   Reply With Quote
Old 09-27-2010, 08:22 PM   #26
micq
micq's Avatar
Oddometer: 257
[IMG][/IMG]
R1200GS
625 SXC
Old 09-27-2010, 08:24 PM   #27
micq
micq's Avatar
Oddometer: 257
[IMG][/IMG]
R1200GS
625 SXC
Old 09-27-2010, 08:25 PM   #28
micq
micq's Avatar
Oddometer: 257
[IMG][/IMG]
R1200GS
625 SXC
Old 11-30-2011, 08:47 PM   #29
farcall
Bike-a-holic
farcall's Avatar
Oddometer: 1,885
Bunnings have got their Craftright Case (Pelican knockoff) in their current cattledog - p29. Going for $65. Has been over 12mths since last on the shelves.
Mine has seen 8000km of use. One trip saw 2 days riding in constant rain. Another trip was 3 days in the usual WA dust. Proved absolutely watertight and dustproof.
Just sharing the love...
01 Africa Twin RD07A (x2)
05 HP2
11 K1600GTL
farcall is offline   Reply With Quote
Old 11-30-2011, 09:16 PM   #30
Colonial Mick
Nettle Licker
Colonial Mick's Avatar
Oddometer: 2,413
That really looks good! Well done.
"Be who you are and say what you feel.
Because those who mind don't matter
and those who matter don't mind".
Colonial Mick is offline   Reply With Quote
Times are GMT -7.   It's 03:52 AM.
