Old 01-28-2012, 06:12 PM   #61
LouisBiker
TR650
LouisBiker's Avatar
Oddometer: 131
Originally Posted by Mark or Jack View Post
Black Box hard cases
These guys sell woodworking tools but I stumbled upon some hard cases.
They may be suitable for panniers, the small sizes would be good for cameras.
The store is Carbatec and they are in a few locations around Oz.
Wow, that's great. cheap and look like they'd do the job.
Thanks for the heads up!!
LouisBiker is offline   Reply With Quote
Old 03-19-2012, 03:15 PM   #62
Precis
Maladroit malcontent
Precis's Avatar
Oddometer: 3,711
Bunnings boxes now $39.95 - so much for being an early-adopter!
"I would like to die on Mars; just not on impact." Elon Musk
Precis is offline   Reply With Quote
Old 03-19-2012, 03:42 PM   #63
FLICKIT
FLICKIT's Avatar
Oddometer: 881
I'm tempted to get a couple more to replace the ones I've smashed the hinges on.. (even though they'll probably glue up ok)
Since I'll be living out of the cases for 3 months I'm looking at adding some $2 bunnings handles over the hinge gussets to help protect them in falls, they're the main weak point when using them as side cases...
Something like this:
The handles "should" help stop them digging in and breaking, I'll also put some Sikaflex between the gussets to glue them together to add some strength...
Edit: BTW, I also broke one of the side latches when I clipped a log that was hiding in ferns at the side of a track, it glued back on ok...
If you give the cases a smack, make sure you look around for the bits that fall off... so they can be glued back together
FLICKIT screwed with this post 03-19-2012 at 04:00 PM
FLICKIT is offline   Reply With Quote
Old 03-19-2012, 05:18 PM   #64
Precis
Precis's Avatar
Oddometer: 3,711
I noticed a pack of ten (12?) stainless drawer/cupboard handles while I was at the B-shop too - long, with slight overhangs, so not a loop like the ones you show - about $25 IIRC - struck me as cheap-as, anyway.
Old 03-19-2012, 05:47 PM   #65
FLICKIT
FLICKIT's Avatar
Oddometer: 881
The ones pictured above are 96mm wide with 4mm threads... $19.90 for 10 at Bunnings...
(9310086949942 D Handle Ikonic 96mm SCP PK10 1949942)
Old 03-19-2012, 06:04 PM   #66
hattah79
hattah79's Avatar
Oddometer: 971
Three for the 990
Fitted up 3 to my 990
The "craftright" label removes with a little heat
hattah79 screwed with this post 03-19-2012 at 06:08 PM Reason: spelling error
hattah79 is offline   Reply With Quote
Old 03-19-2012, 06:15 PM   #67
southern cross
WARDY
Oddometer: 420
box's
For those adding the Bunnings " D " handles don't forget to add large washers on the inside otherwise they will tear off or pull out of the plastic if it gets a side hit or a lay down.
southern cross is offline   Reply With Quote
Old 03-20-2012, 04:00 AM   #68
gunnabuild1
gunnabuild1's Avatar
Oddometer: 860
Every time these come up I'm down my local Bunnings [Booval] No one knows a damn thing and I sure as hell cant find 'em.
gunnabuild1 is offline   Reply With Quote
Old 03-20-2012, 05:51 AM   #69
woopwoop
will think for food
woopwoop's Avatar
Oddometer: 5,637
I think you might be right. I had a look in the online catalogue and can't find them either.
You have to enter your postcode so their system can "localise" the catalogue. I don't think they stock them in Qld.....only a bright yellow different brand one. Too bad...I would've grabbed a pair at $40.00 each.
woopwoop is online now   Reply With Quote
Old 03-20-2012, 06:06 AM   #70
neilaction
Slightly Less Adventurous
neilaction's Avatar
Oddometer: 7,665
I saw them once in a local store but that was a year ago.
Nothing in the Innaloo store today.
If it can't be fixed with a hammer, its probably electrical.
2009 Honda CBF1000, 1980 Suzuki GS1000ST (Aus spec), Dr6fiddy,
neilaction is online now   Reply With Quote
Old 03-20-2012, 06:35 AM   #71
farcall
Bike-a-holic
farcall's Avatar
Oddometer: 1,894
When this last lot hit the shelves a few months ago I spoke to my deep throat at the local Bunnings. He's been there a few years but is just a happy shitkicker. He said these cases seem to be a special exclusive consignment run between Bunnings & Craftright which occur approx 12 months apart... very approx. Bunnings order shitloads in and flog em cheap. A few months later any stragglers then get flogged off at near half price. Some stores will have stragglers, most won't. Don't expect to see any more for another 12 months, if ever. That's the drum I got. Could be right, could be wrong. Seems right to me. Hope that info helps.
01 Africa Twin RD07A (x2)
05 HP2
11 K1600GTL
farcall is offline   Reply With Quote
Old 03-20-2012, 01:38 PM   #72
FLICKIT
FLICKIT's Avatar
Oddometer: 881
They seem to hide them well so it's probably worth getting them to check the computer for stock...
The stock number for them is "5810184"...
Old 03-20-2012, 02:33 PM   #73
neilaction
neilaction's Avatar
Oddometer: 7,665
I'll stop looking then.
Old 03-20-2012, 04:52 PM   #74
hattah79
hattah79's Avatar
Oddometer: 971
What store gave you that price
The Victorian stores I checked with all had them at $65.00
Across 4 stores I found 52 in stock
Old 03-21-2012, 12:56 AM   #75
Precis
Precis's Avatar
Oddometer: 3,711
I'll tell you tomorrow, after I've gone back & picked up a pair....
Times are GMT -7.   It's 03:37 PM.
