Old 03-24-2013, 11:02 PM   #106
Tfos1
Tfos1's Avatar
Oddometer: 226
Awesome!
Originally Posted by FLICKIT View Post
Things could be worse, I could have gone to a BMW (jk)
Can't wait to see the reaction to that comment!
Tfos1 is offline   Reply With Quote
Old 03-28-2013, 05:10 AM   #107
Old Kiwi#99
Oddometer: 279
Put a pair of the Bunnings cases (only colour they had, then) on the KLR about 4 years ago. They have taken some pretty good hits since then, still weathertight, still open and close properly.
The cheapass topbox lasted about a year before the bottom pulled out of it.
I see jaycar and Supercheap are selling similar cases now.
Old Kiwi#99 is offline   Reply With Quote
Old 03-28-2013, 01:57 PM   #108
FLICKIT
FLICKIT's Avatar
Oddometer: 853
That's good to know ... TY
SCA Safe Case - 515x435x215mm - $70
http://www.supercheapauto.com.au/onl...om=80701#Cross
(Same as the Bunnings - Craftright cases it appears)
They also have 3 sizes of the smaller 2 latch cases....
FLICKIT is offline   Reply With Quote
Old 03-30-2013, 10:07 PM   #109
Paulba
Paulba's Avatar
Oddometer: 43
Hi FLickit,
Could you show some shots of the mounting you used for the Tenere side cases.
Paul
In The shed ..
2010 XT660Z
1988 XT600Z
Paulba is offline   Reply With Quote
Old 03-30-2013, 10:25 PM   #110
FLICKIT
FLICKIT's Avatar
Oddometer: 853
Originally Posted by Paulba View Post
Hi FLickit,
Paul
The side cases are on an OTR rack ($230aus + del):
http://www.off-the-road.de/en/XT-660...-Z-Tenere.html
Using the OTR pannier mounting kit, ($62aus +del):
http://www.off-the-road.de/en/XT-660...-panniers.html
There's a bit more info here: (rack weight, pics, and such)
http://www.advrider.com/forums/showp...postcount=4010
Old 04-01-2013, 03:51 AM   #111
hattah79
hattah79's Avatar
Oddometer: 934
Other makes of bike
If you have something other than a Tenere try here
For the attachement parts
http://cariboucases.corecommerce.com...Yourself-Kits/
hattah79 is online now   Reply With Quote
Old 04-01-2013, 04:27 AM   #112
Old Kiwi#99
Oddometer: 279
Looking at the hinge damage to the cases Flickit is using - the Bunnings Craftech (Kinchrome) cases that I bought a few years ago (which may be totally different to the Bunnings Craftechs available now) have a full length hinge with a stainless hinge pin, so should be a bit more robust (if you pick your crashes carefully).
Old 04-01-2013, 03:32 PM   #113
Warin
Retired
Oddometer: 2,069
Another thing to consider - if you mounted them with the lid to the bike side then those hinges would be further in - thus less likely to be damaged.
Warin is offline   Reply With Quote
Old 04-01-2013, 07:40 PM   #114
FLICKIT
FLICKIT's Avatar
Oddometer: 853
This is what I did to protect the hinges, ROUGH! but it works
Enough scuffs to suggest it was worthwhile:
Here's how it looked before it was glued back together:
Times are GMT -7.   It's 05:30 AM.
