Old 12-08-2004, 04:39 PM   #1
Loadedagain OP
making chips
Loadedagain's Avatar
Oddometer: 26,732
lc4 fuel tank empty sender
any of you clods have problems with your out of fuel idiot light? mine has never come on and i've run right dry out of petrol several times.
the light comes on after the circuit the sender goes "closed" for a couple seconds, then the light flashes and the odo flips to the "f" position. i can make this happen if i jump the terminals at the sender.
just popped the sender itself out right now and i cant get it to go "closed". shake it, scream at it, drown it in petrol, etc, etc... it aint going closed.
y'all think i need a new one? is it just a little float, or is there more in there than i can see?
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Old 12-08-2004, 05:07 PM   #2
dagwood
dagwood's Avatar
Oddometer: 35,427
Whats a fuel tank empty sender? must be that new fangled dumy lamp fer people that can't use the odo.
I just wait till it starts to babble then I have half gallon+ to find fuel.
did you try to move it by hand? or force?? is mechanical or is it electrical like two brass strips that when the circuts broken the light comes on tipe?
dagwood is offline   Reply With Quote
Old 12-08-2004, 05:38 PM   #3
Loadedagain OP
making chips
Oddometer: 26,732
here is the sender in its natural state... the naught little beetch.
once she is removed from her home this is what she looks like. if there's a float in there it's a wee one forsure.
Old 12-08-2004, 05:59 PM   #4
dagwood
dagwood's Avatar
Oddometer: 35,427
I bet it's not a float but a resistance probe with the cover to prevent sloshing from effecting it causing false readings. sort of like a moister meter. works on ohms of resistance. seen others like it.
Old 12-08-2004, 06:39 PM   #5
Loadedagain OP
making chips
Oddometer: 26,732
ohms of resistance? i like that... i'll somehow use it again.
the input to the imo only works when resistance is damn near nil... shorted to be exact. the sender is "open" (zero ohms) when i hold it in air, sink it in petrol with the up side up, sink it in petrol with the up side down, and when i shake the living bejesus out of it.
my feeling is the damn thing is jiggered. just wundrin if anyone knows exactly how these farkin things werk. specs?
Old 12-08-2004, 08:05 PM   #6
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Hit it with a stick then soak it in gin... it'll be fine. If it isn't...
Part Number: 58207080000
Description: GAS-LEVEL SENSO
Retail: $45.44
So... how's tricks?
creeper is offline   Reply With Quote
Old 12-08-2004, 08:30 PM   #7
ysr612
ysr612's Avatar
Oddometer: 10,089
this will be a guess but it may be pressure. by the looks of your tank it looks like you have a few miles in the other side when you run dry. On the drz with the clark I have more then 11 miles if I turn the bike on its side and lift to pour the gas to the petcock.
ysr612 is online now   Reply With Quote
Old 12-08-2004, 09:02 PM   #8
Loadedagain OP
making chips
Oddometer: 26,732
pressure? tell me more.
there's a fair amount of fuel left in the tank when the sender goes dry. i'd bet there's 100km (?). no need to put a ktm on its side, as there are petcocks on both tank lobes.. some like to call that "the second reserve".
Old 12-08-2004, 09:15 PM   #9
ysr612
ysr612's Avatar
Oddometer: 10,089
I have seen pressure transducers of several types some are so senitive that by the time they are underwater they are full on. some are just a strain gage on the inside of a beryllium brass disk but they have to run into an Opamp. but that looks like it could be just a conductive patch with a rubber bladder and a housing around it to keep the fuel from sloshing. If that is the case you are fucked because if they go bad the're gone.
Old 12-08-2004, 09:29 PM   #10
ysr612
ysr612's Avatar
Oddometer: 10,089
by the way fuel is non polar so those ohmy thingys ain't going to work
Old 12-09-2004, 12:07 AM   #11
Buckster
Buckster's Avatar
Oddometer: 1,003
It's fucked, replace it!
Buckster is offline   Reply With Quote
Old 12-09-2004, 10:26 AM   #12
gybeman
gybeman's Avatar
Oddometer: 633
It may be a silly question, but do you have both fuel taps open ? I think I ran out once without the fuel light coming on but I had one or both of them closed.
gybeman is offline   Reply With Quote
Old 12-09-2004, 11:51 AM   #13
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,237
I have read that you can use the right side fuel tap as a additional reserve, especially good as the reserve on this monster tank is paltry IMO. Never thought to close both... when you opened them did it still have fuel in there?
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 12-09-2004, 12:46 PM   #14
dirtrider
Dusty Adventurer
dirtrider's Avatar
Oddometer: 3,316
Forget the sender. Just whittle this into a stick. Then you can stick it in your tank and figure out the level any time you want. Damn canuck
2013 Husky TE511
2014 KTM 350 XC-F
2006 KTM Adv 950
2001 KTM 640 LC4 Sold
I only like two kinds of women, foreign and domestic
dirtrider is offline   Reply With Quote
Old 05-11-2014, 11:35 PM   #15
two trackin fool
two trackin fool's Avatar
Oddometer: 1,285
updated price .
$ 64.50
Stay Patient and Trust your Journey
two trackin fool is offline   Reply With Quote
Times are GMT -7.   It's 07:32 AM.
