Old 02-06-2011, 09:04 PM   #136
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
There's a pin that aligns the cam gear to the cam shaft. I assume it's supposed to be a permanently pressed in place, but it is slipping out of the 250's cam gear. Is that supposed to happen?
Pablo83 is offline   Reply With Quote
Old 02-06-2011, 10:37 PM   #137
DisTech
DisTech's Avatar
Oddometer: 616
I don't know if it's supposed to, but I've got 4 or 5 350 cam's and it's loose on all of them. The C shaped lock washer for the cam sprocket bolts keeps the pin in on one side, but the only thing stopping the pin on the other was the rocker cover (although there was no indication that the pin ever touched the rocker cover).
DisTech - Suzuki (1993 DR350S & 1994 DR350, 1996 DR650/DR790), BMW (1999 R1100GS)
DisTech is offline   Reply With Quote
Old 02-06-2011, 11:18 PM   #138
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
I saw someone's comment that they had installed a DR250 CDI on their 350. Is there any advantage to that?
I believe the 250 has more timing advance...
jessepitt is offline   Reply With Quote
Old 02-07-2011, 07:15 AM   #139
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
Thanks. That's what I was afraid of. Now I have to remove the cover on the other bike to make sure the clip is covering the pin.
Old 02-07-2011, 11:43 AM   #140
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
When I started this project I bought two DR350 engine gasket kits. Since I ended up with a 250 and a 440, I had two 350 head gaskets left over. I could only find one last night. After a lot of searching I found the 250 head gasket (uh oh). So last night I took apart the DR250 so I could remove the 350 head gasket that I had installed and replace it with the proper size one. It turns out that there is a noticeable compression difference with the proper size head gasket.
Old 02-07-2011, 12:49 PM   #141
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
removing the kickstand switch
I hate kickstand switches. Removing it is easy. Unplug and unbolt the switch; throw it away. Follow the two switch wires (one green, one black w/ white) up through the wiring harness as far as you want to take them. Cut and solder them together. A butt connector would work to, but if it ever came loose you would have a very difficult time trying to find out why your engine dies when you put it in gear, so I suggest soldering and shrink tube.
Pablo83 screwed with this post 04-24-2011 at 03:10 PM
Old 02-08-2011, 10:50 AM   #142
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
mounted skidplate
Old 02-08-2011, 10:52 AM   #143
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
The DR350 has a larger rod on the end of the shift pawl than the DR250S. I'm guessing the smaller rod was digging into the case so Suzuki made it larger.
Old 02-08-2011, 10:54 AM   #144
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
The 250 is running! It still has some clutch drag so it will have to come back in some time, but I had to make room in the shop for other projects so right now it sits on the back porch.
Old 02-08-2011, 11:03 AM   #145
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,771
What's next?
a1fa is online now   Reply With Quote
Old 02-10-2011, 01:08 PM   #146
juda5
juda5's Avatar
Oddometer: 121
That skid plate looks awesome!
I need to learn to weld!
juda5 is online now   Reply With Quote
Old 02-10-2011, 01:28 PM   #147
3uba296
Thumpcurious
3uba296's Avatar
Oddometer: 133
Love this thread!
Dr350(80)R-97
3uba296 is offline   Reply With Quote
Old 02-10-2011, 01:43 PM   #148
BikePilot
BikePilot's Avatar
Oddometer: 11,253
And a higher rev limit (though the 350 should get stiffer valve springs and ti retainers before you try and rev it that high imho).
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 02-10-2011, 03:50 PM   #149
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
That's good to know. I'll be retaining the RPM gauge from the 250 which shows redline at 9500. Do you know what RPM the rev limiter activates for the 250 and 350?
Old 02-17-2011, 05:23 PM   #150
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
I need a longer clutch cable. Any ideas?
Times are GMT -7.   It's 10:05 PM.
