Old 05-16-2011, 11:19 PM   #226
BAD-MOD
professional fiddler
BAD-MOD's Avatar
Oddometer: 163
i guess you have changed all the stuff to be the same ? is it the same carb as your old one ? intake leaks ? air filter ? . I don't know prob something simple though
is it new out of the box or second hand new ?
Try it otherwise you'll never know what is possible
BAD-MOD is offline   Reply With Quote
Old 05-17-2011, 06:35 AM   #227
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,815
Yes, I change all the components from the new carb to the old one (fuel jets, slide, needle, air jets, choke plunger, floats, float bowl, AP components). The new carb model is the same as the old (TM33 pumper).
The carb was brand new.
Pablo83 is offline   Reply With Quote
Old 05-17-2011, 11:38 AM   #228
juda5
juda5's Avatar
Oddometer: 124
It's sounding a lot like the pilot circuit is not working at all... have you pulled the pilot screw to see if maybe the end is broken off? Can you blow through the pilot circuit?
juda5 is offline   Reply With Quote
Old 05-17-2011, 11:57 AM   #229
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,815
I've removed both the pilot screw and jet and run carb cleaner through the system to make sure nothing's clogged.
Old 05-20-2011, 06:38 PM   #230
Tukata
ADV Demo Rider
Tukata's Avatar
Oddometer: 1,486
This might sound dumb/odd, but:
I might suggest a lightweight hardening liquid to pour into the tank.
Mark the level below the petcock and make sure to remove it. Make sure its: slightly flexible/malleable aka not going to chip, lighter than gas, ok to react with constant contact with gas, and not going to harden and expand too much.
Ok chemical gurus have at it...
Probably an epoxy.
Yes, I'd love to try
What ever happens to be in the stable at the current time.
H-ADV in fabrication
Tukata is offline   Reply With Quote
Old 05-24-2011, 06:53 PM   #231
BAD-MOD
BAD-MOD's Avatar
Oddometer: 163
stumped man i can't think of anything else sorry bro .
Old 05-31-2011, 02:12 PM   #232
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,815
Originally Posted by Airvent View Post
How does a trials tire handle sand?
I just got back from another trip to Moab and this time I used the trials tire. In a straight line the tire does just fine on anything including deep sand. When you lean the bike over the tire starts to have some issues. Leaned over on gravel roads it gets a little unpredictable; it won't let go, but it resists leaning at first, then it will suddenly lean and then grip again. Leaned over in sand, it wants to drift out (making some pretty tight corners possible).
I guess if you're looking for straight line traction, go with the trials tire, if you need predictable cornering, stick with an MX tire. I'd love to find a tire with trials type center knobs and MX type side knobs.
Old 06-01-2011, 09:30 PM   #233
Rich667
Rich667's Avatar
Oddometer: 178
sorry for the wait, im not very computer savy... im still not sure if it will show up but if it does heres my sub frame in the making
Rich667 is offline   Reply With Quote
Old 06-02-2011, 04:45 PM   #234
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,815
Does the stock airbox mount to this, or did you build another one?
Old 06-02-2011, 10:21 PM   #235
Rich667
Rich667's Avatar
Oddometer: 178
stock for now, its basically the same dimensions as the original subframe, just square tubing and the fender mounts are slightly different. unfortunately for me, i only have access to a tig welder at college so right now im stuck with the stock airbox.
Old 06-02-2011, 10:25 PM   #236
Rich667
Rich667's Avatar
Oddometer: 178
here's the kx plastics, i had some old body panels laying around from my ring-ting days, turns out they kinda fit.
Old 06-03-2011, 07:50 AM   #237
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,815
cool, thanks for posting
Old 06-04-2011, 10:31 AM   #238
inroads
Wimberley,Texas
Oddometer: 277
Never did hear if there was a dipstick oil temp gauge available for the DR. I have seen them for the dry sump XR's but not for the DR's.
inroads is offline   Reply With Quote
Old 06-05-2011, 08:51 AM   #239
adventure95004
adventure95004's Avatar
Oddometer: 87
dipstick
check ebay, I found a Dutch(I think) seller. Group buy maybe? kinda pricey but looks good quality.
what the hell was I thinking??????
transplanted limey in florida, don't ask why!
adventure95004 is offline   Reply With Quote
Old 06-05-2011, 08:54 AM   #240
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,815
I can't find anything. Was this on US eBay?
Times are GMT -7.   It's 02:15 AM.
