Old 01-04-2012, 03:12 PM   #346
tdrrally
tdrrally's Avatar
Oddometer: 3,330
i believe the different spec in the stator from 92-93 may be from kick start to e start
i dont know about dr250 to 350 cdi but i do know the drz400e cdi works on my drz250 with one minor mod
i would guess the 250 to 350 cdi is plug and play there might be a different spark timing
there is a crank trigger, the coils just make the power
1980 TS125 project in the corner
tdrrally is offline   Reply With Quote
Old 01-04-2012, 03:29 PM   #347
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
Originally Posted by tdrrally View Post
ok is the plug a bit rich ?
or is it lean?
i have a 40 in near stock bike now and it starts in 4-5 kicks at 25degs
i plan on installing an old school supertrapp (it can with the bike) and a modded air box
along with a 42 pilot jet
The plug seems to be the right color (slightly tan).
Pablo83 is offline   Reply With Quote
Old 01-04-2012, 04:04 PM   #348
tdrrally
tdrrally's Avatar
Oddometer: 3,330
that tough
how old is the plug?
Old 01-04-2012, 07:21 PM   #349
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
that tough
Almost a year.
Old 01-04-2012, 07:29 PM   #350
tdrrally
tdrrally's Avatar
Oddometer: 3,330
have you tried a new plug?
Old 01-05-2012, 05:17 AM   #351
Greg Bender
Oddometer: 1,162
*IF* you need to look into the stator and/or pick up coil, here are some links that may provide some help:
http://www.maximum-suzuki.com/forums...?topic=63342.0
http://www.maximum-suzuki.com/forums...?topic=65745.0
http://www.maximum-suzuki.com/forums...?topic=82026.0
Regards,
Gregory Bender
Greg Bender is offline   Reply With Quote
Old 01-05-2012, 07:04 AM   #352
rubberband
Will ride for tacos
rubberband's Avatar
Oddometer: 395
While going through the basics...... are the valves in spec?
2011 UPAT
rubberband is offline   Reply With Quote
Old 01-05-2012, 10:24 AM   #353
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
Just checked em. They're right on.
Old 01-05-2012, 03:35 PM   #354
tdrrally
tdrrally's Avatar
Oddometer: 3,330
have you removed the bottom of the carb?
it could have some water or dirt in there
Old 01-05-2012, 04:58 PM   #355
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
The carb gets removed/cleaned/rejetted 2-4 times a year for riding at different elevations. Last time it was cleaned was November and I've been having these issues for a much longer time.
Old 01-05-2012, 05:26 PM   #356
MrPulldown
MrPulldown's Avatar
Oddometer: 3,060
I think we should all assume that Pablo has done all of the basic stuff. His problems are ones that the majority of DR350 owners will never face. In fact suggesting items like the kick stand safety is jsut a waste of cyber space.
Good luck to you. I always follow this post to try to learn things from one of the DR legends.
MrPulldown is offline   Reply With Quote
Old 01-05-2012, 05:41 PM   #357
tdrrally
tdrrally's Avatar
Oddometer: 3,330
just trying to help
and lean what the issue is incase i have it
it almost seems like a fuel issue
have you kicked it over with a plug in the head and a second on the end of the wyre resting on the head ?
Old 01-05-2012, 10:43 PM   #358
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
Nope. What does adding a second plug do to change the spark?
Old 01-05-2012, 11:01 PM   #359
shearboy2004
KIWIINUSA
shearboy2004's Avatar
Oddometer: 4,393
I did have one once where the carb had been tightened too firmly to the inlet manifold and had actually bowed the mounting flange leaving a small gap .
The O ring should take this gap up but after a few backfires a tiny piece of O ring had decided to bugger off and it was a bitch to start till I found it .
88 R100GS
75 Norton Commando Roadster
98 DR450
07 Sherco 510 called Holy Shit .450 Sherco called Bling .
13 Sherco 300i called The Bee's Knees .
shearboy2004 is offline   Reply With Quote
Old 01-06-2012, 05:46 AM   #360
tdrrally
tdrrally's Avatar
Oddometer: 3,330
checking for a spark issue
when cold
i like problems like this more when there in front of me
Times are GMT -7.   It's 04:03 AM.
