Old 01-31-2011, 12:08 PM   #106
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
RMX swinger
So this bike belonged to inmate Creswellelkhunter. You might try to PM him for details. The swingarm itself is very stout but I think the stack-o-washers spacer could use some fine tuneing.
jessepitt screwed with this post 01-31-2011 at 12:20 PM
jessepitt is offline   Reply With Quote
Old 01-31-2011, 08:15 PM   #107
shearboy2004
KIWIINUSA
shearboy2004's Avatar
Oddometer: 4,424
Originally Posted by pablo83 View Post
Someone on one of the DR350 threads was recently commenting on their Jesse-modified exhaust. Shearboy, was that you? Anyway, I'd like to keep this bike real quiet and wanted to know if there was a noticeable difference in sound after Jesse's mod. Anyone?
Mate with the bigger bore you will need to get a little better than stock and i have tried about everything and settled on the Jesse mod because like you I want stealth not the "hey look at me " thing.
At our altitude I get a bit of popping on decel but nothing like you would get on the aftermarkets, play with the jetting and you will get it close .
88 R100GS
75 Norton Commando Roadster
98 DR450
07 Sherco 510 called Holy Shit .450 Sherco called Bling .
13 Sherco 300i called The Bee's Knees .
shearboy2004 is offline   Reply With Quote
Old 01-31-2011, 08:18 PM   #108
shearboy2004
KIWIINUSA
Oddometer: 4,424
Another thing to consider when going big bore is the rise in compression ratio .This conversation took place late one night and was fairly revealing to me. http://www.advrider.com/forums/showthread.php?t=646691
This is how my 450 work out .
Somewhere around 11.8:1.
Assumptions. 9.5:1 is accurate. I have used 350cc and 450cc as the actual displacements - fine tune it yourself :) . 1mm squish height. Flat top pistons with valve reliefs that have not changed volume. If the pistons have a dome or dish that differs from the original the new volume must be taken into account.
1. Calculate chamber and squish volume of the 350 using C=Vs/Vc ie. Vc=Vs/C = 350/9.5 = 36.8cc
2. Calculate the difference in volume of the squish area using V=pi.r^2.h. ie V2-V1 = (pi. (8.95/2)^2. 0.1) - (pi. (7.9/2)^2. 0.1) = 1.38cc
3. Add volume to the chamber/squish volume calculated in 1. to the volume in 2. then calculate the new compression ratio.
C = 450 / (36.8+1.38) = 11.77
Armed with this information i will be skimming the piston top next time I pull it apart . Near 12 / 1 is a little high in my opinion and yours will be even higher if you go to 460cc.
88 R100GS
98 DR450
shearboy2004 screwed with this post 01-31-2011 at 08:31 PM
Old 02-02-2011, 08:33 PM   #109
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,812
This little thing is a real bitch to put back together:
If you want to save a fraction of an ounce, get the clutch pull lever from the '91 DR250S with the pimp lightening holes (or drill your own)
Pablo83 is offline   Reply With Quote
Old 02-02-2011, 08:34 PM   #110
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,812
Well, it's time to put the engine back in. The bike in the background will get assembled with all the leftover components and sold for cheap.
Old 02-02-2011, 08:40 PM   #111
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,812
thanks for the pics. If my swingarm doesn't work out I'll be going to one of these.
Old 02-03-2011, 09:15 AM   #112
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,812
Old 02-03-2011, 10:23 AM   #113
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,838
Did you say it is going to have an electric start?
a1fa is offline   Reply With Quote
Old 02-03-2011, 11:03 AM   #114
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,812
Nope, in fact, this morning I'm adding a large capacitor to the wiring harness so I can get rid of the battery.
BTW, I now have an extra 350cc jug that has theaded holes for mounting a starter. If someone wants it, I'll trade you your old bore, or make me an offer.
Old 02-03-2011, 01:59 PM   #115
HeadTrauma
¯\_(ツ)_/¯
HeadTrauma's Avatar
Oddometer: 1,260
Unless all the pertinent dimensions and volumes have been verified with actual measurement, the 11.8:1 number calculated backward from the OEM advertised ratio of 9.5:1 is really just a SWAG(scientific wild-ass guess). When a few of us were gathering Honda RFVC piston dims on TT, we found that not only were aftermarket pistons overstated, but that Honda overstated the stock static ratio as well. Maybe that's not the case with Suzuki; I don't know. Only taking actual measurements will say.
1995 XR628R -Lots of goodies...room for more.
"Another breakdown, suicidal shakedown,
Feels like I'm livin' on a chain gang."
HeadTrauma is offline   Reply With Quote
Old 02-03-2011, 02:42 PM   #116
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,812
Old 02-03-2011, 05:16 PM   #117
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,838
Almost there...
Old 02-03-2011, 06:14 PM   #118
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,812
Clutch no workie
The clutch doesn't completely engage, or disengage. I'll pull it apart to try and see what's going on. Any ideas?
Old 02-03-2011, 06:52 PM   #119
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,812
Notice the headlight is on. Without a battery, that's got to mean the engine's running... nice! It started on about the fourth kick. But now I have to tear it all apart again to see what's wrong with the clutch.
Old 02-03-2011, 09:13 PM   #120
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,812
Oversized Tank
I should have done a little more research in the oversized-tank department. I ordered the Clarke tank. After I ordered it I read some reviews and everyone recommends the Acerbis tank, and no one recommends the Clarke. Here's one of the reasons: the last half gallon-or-so of gas is unusable. You can see the remaining gas in the tank is below the petcock, so unless you can wheelie your way to the gas station, you're just carrying around extra weight. I did some weighing; the tank holds 2 lb, 1 oz of useless fuel. I hate extra weight.
Pablo83 screwed with this post 02-04-2011 at 07:16 AM
Times are GMT -7.   It's 12:08 AM.
