Old 06-13-2013, 06:46 AM   #46
Just Dan
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,882
Originally Posted by hunter_greyghost View Post
What's the wheelbase on the W800's?
Cheers
Baza
Wheelbase is 1465 mm (57.6 ") The rear tire is 130 X 18 and there is quite a bit of choice. Most seem to go for the BT45's or the Avon's
13' kawasaki W800, Yep the twin
13' Skyteam Ace 125 BIG BORE
81' BMW R100 CS
Old bikers don't get old by accident.
Just Dan is offline   Reply With Quote
Old 06-13-2013, 07:12 AM   #47
livo
livo's Avatar
Oddometer: 266
Originally Posted by tripodtiger View Post
Are oem tyres designed to wear out super quick? Like starter cartridges in printers.
No, they're not designed to wear out quick.... but you won't usually find a really 'good' tyre OEM. My front OEM dunlop on the V-Strom lasted about 19000km and the rear lasted just over 23000km (I bought the bike when it had about 18000km on it).
Dad hasn't got a lot of k's racked up on the w800 yet, so we'll just have to see how long those dunlop loops last
Suzuki DL650 V-Strom 2007
Suzuki DR-Z250 2009
livo is offline   Reply With Quote
Old 06-13-2013, 10:35 AM   #48
BravoFox
Twin With a Kick
BravoFox's Avatar
Oddometer: 256
Over here W800 are sold with Dunlop K81 as OEM. Looks the part.
______________________
99 Clubman W650
78 R100/7
BravoFox is offline   Reply With Quote
Old 06-14-2013, 01:18 AM   #49
hunter_greyghost
XS650 Allroads Traveller
hunter_greyghost's Avatar
Oddometer: 8,255
Wheelbase on the XS650 is 1435mm [56.5"], which makes the W800 longer by 30mm!,
yet I saw one in Goulburn today & it looked shorter to me, at least from front of the tank to the rear of the seat looks shorter!
Have to have a look at a new Trumpy Scrambler for some comparisons as well, I know Ferals5 reckons heavier rear shocks & seat could do with some work too?
Cheers
Baza
1981 XS650SH "Tourer" [ For Sale - 2015], 1975 XS650B "Adventure" ['Kenny Krazyhorse'], 1982 XL500R 'Project' x2 [for sale], DT175 [new projects] x 2
www.aussiegreyghost.smugmug.com
Couldn't afford a 'GSA', so now it's an 'XSA' "I didn't do it! & whoever said I did, is a liar!"
hunter_greyghost is offline   Reply With Quote
Old 06-14-2013, 05:39 AM   #50
Just Dan
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,882
The W800 is tiny. That is what I like about the bike. Not the right bike if your 6' or so.
I just use a sheepskin and that works fine for me. Plenty of after market seats as well
For rear shocks, There are aftermarket shocks, even cheap piggy back ones on Ebay for $120. From reports they seem to work better than stock ones.
81' BMW R100 CS
Old 06-14-2013, 06:19 AM   #51
BravoFox
Twin With a Kick
BravoFox's Avatar
Oddometer: 256
Bluhduh Tiny?
It's not tiny. It's the size of a similar moto from that era.
Modern bikes might have have grown in size as cars have, but it doesn't make the W "tiny". A Mash is tiny, a VanVan is tiny. Not a W.
99 Clubman W650
78 R100/7
Old 06-16-2013, 08:46 PM   #52
tripodtiger
I used to be SCRay
tripodtiger's Avatar
Oddometer: 4,700
Almost agree with you Dan. The little girl is not much bigger than a 250. I also have to agree with BravoFox, it's around the same size as Bonnie from the 60's. How does it compare with a Commando?
Remember the first time you saw 750/4 - they were huge! We got used to it. I recall riding a 750 Tenere and being turned off because of it's bulk. A few years later the 900 Tiger didn't seem so big but any 4 valve GS was over sized. Seems that that's the normal, acceptable size of any large 'all road' bike.
Which then means that, relative to what's on the market, the W is tiny. The bit I disagree with is that is it's not the right bike for those slightly larger than normal. I reckon it's a great thing to ride. Mine could be set up a lot better, ie nothing has been done from stock, if it was just for me, especially as I no longer 'need' to ride at 120+.
There's the rub, as far as I'm concerned.
Finally, for the present any way, compare the W to the Bonnie. Is my recollection correct that the basic Bonnie is around 20kg heavier, if that falls within the definition of making the W 'tiny'. It's all relative, isn't it?
rayb Crash Dummy (no testing involved)
Old 06-16-2013, 09:30 PM   #53
UncleGra
CRASHING BORE
Oddometer: 2,985
Bonnie T100..dry weight 205kg...max payload 200kg
max torque..678 Nm @5800 rpm
66.1 PS @7500 rpm
.. I fixt it...my way....gjr
Done good...Played strong... J.G.
UncleGra is offline   Reply With Quote
Old 06-16-2013, 10:04 PM   #54
fayeslane
Rankest of amateurs
fayeslane's Avatar
Oddometer: 1,738
66.1 PS @7500 rpm
What's happening with the rest of your fleet Hunk?
fayeslane
Faster than a speeding pullet
2002 Yamaha TDM900
various BMW airheads
fayeslane is offline   Reply With Quote
Old 06-17-2013, 12:26 AM   #55
UncleGra
CRASHING BORE
Oddometer: 2,985
absolutely sfa...so I'm preppin this for me next adventure...
Old 06-17-2013, 01:21 AM   #56
fayeslane
Rankest of amateurs
fayeslane's Avatar
Oddometer: 1,738
Look out for potholes ya mad bugger
If you swing past my place on your next trip on that, there's a coupla hours work for you
Ride on bro
fayeslane
2002 Yamaha TDM900
Old 06-17-2013, 01:23 AM   #57
Woody2627
Skinny Decaf Latte Thanks
Woody2627's Avatar
Oddometer: 965
What sort of oil will you be runnin Unc? We can discuss tyres later. :
Woody2627 is online now   Reply With Quote
Old 06-17-2013, 01:23 AM   #58
tripodtiger
I used to be SCRay
Oddometer: 4,700
You're a dickhead.
Old 06-17-2013, 01:29 AM   #59
fayeslane
Rankest of amateurs
fayeslane's Avatar
Oddometer: 1,738
You're a dickhead.
Succinct
fayeslane
2002 Yamaha TDM900
Old 06-17-2013, 02:21 AM   #60
BravoFox
Twin With a Kick
BravoFox's Avatar
Oddometer: 256
A W (650, not any diff from 800 dimension-wise) and a T120 side by side on the pic below..
Not bad huh ?
http://postimg.org/image/x94jtzeej/
99 Clubman W650
78 R100/7
BravoFox screwed with this post 06-17-2013 at 02:31 AM
Times are GMT -7.   It's 04:00 PM.
