Old 12-09-2004, 11:11 PM   #1
meat popsicle OP
Ignostic
meat popsicle's Avatar
Oddometer: 14,239
Question on KTM's tank material
Anyone know what KTM makes their tanks out of? Specifically the KTM 640 Adv.'s 27 liter tank. I am looking into repair materials and methods in the equipment forum.
I thought I read somewhere that Acerbis makes the tanks but I am not sure about this.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 12-10-2004, 12:57 AM   #2
overlandr
Dystopist
Oddometer: 5,899
Believe its Elkamet in Germany. Try these links.
http://int.elkamet.de/GF_D/manufacturing.shtml
http://www.elkamet.de/GF_D/sponsoring.shtml
overlandr screwed with this post 12-10-2004 at 01:06 AM
overlandr is offline   Reply With Quote
Old 12-10-2004, 04:46 AM   #3
Cat0020
El cheapo
Cat0020's Avatar
Oddometer: 5,558
Both main tanks on my 2000 660 Rallye and 2002 LC4 Adv. have Acerbis stamped on them..
Mankind is doomed & Physics do not lie
Chances favor the prepared mind.
Cat0020 is offline   Reply With Quote
Old 12-10-2004, 07:11 AM   #4
Loadedagain
making chips
Loadedagain's Avatar
Oddometer: 26,732
mine too
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Old 12-10-2004, 07:22 AM   #5
meat popsicle OP
Ignostic
Oddometer: 14,239
Alright.... so what does Acerbis make its tanks out of... PA, PC, PE... what?
MTBE - mentioned - thought that was a flame retardant used in furniture:
http://faq.f650.com/FAQs/Aftermarket...rbis%20Details
" HPN Tanks made by Acerbis : 43 liters (11.3 gal.), in white, red, blue, black or transparent for 735 to 998 DM and 148 DM for installation kit. Made of non-paintable material ("Philipps CL 50"), so you have to stick with these colors here. The HPN tank is also available in a Nylon-material (paintable), for 1048 DM plus the installation kit. These tanks have a fill sleeve that stucks out of the tank, so mounting a tank bag may be more difficult as usual (Same as with R 100 GS PD). You cannot check the oil level with tank on the bike. It only takes about 2 minutes to get the tank off. "
http://www.micapeak.com/bmw/gs/gs_acces.html
another with same info as above:
http://www.roadkill.com/~davet/moto/gastank.review.html
- Hmmm, nylon - that does sound right for what you see under the paint - does that sound right?
Old 12-10-2004, 01:12 PM   #6
markjenn
Oddometer: 10,457
What failed?
Mine has a failed right "ear" (that mates to the right/upper support donut) - the previous owner said it started leaking after a crash. He epoxied it and removed the mount from the bike to not put any further pressure on it. I went further and shimmed/padded the frame backbone to use the tank's saddle hump to further distribute the load. It seems to be a premanent fix - no problems in many thousands of miles.
- Mark
Old 12-10-2004, 02:04 PM   #7
meat popsicle OP
Ignostic
Oddometer: 14,239
Originally Posted by markjenn
What failed?
- Mark
No failure, just some cosmetic repairs after my asphault inspection.
See: http://www.advrider.com/forums/showthread.php?t=62059
I am looking to repair some scratches and minor gouges from a slide prior to repainting. So if you know, is the tank nylon???
If you do have trouble with that you might want to find a plastic welder to fix it for ya. Supposedly a good job will be good as new!
Old 12-10-2004, 03:17 PM   #8
rapiti
IOR Veteran
rapiti's Avatar
Oddometer: 1,907
Mine is painted, and I have always believed it to be nylon. Not positive, but that's my story, and I'm sticking to it.
...its the best paint scheme that has ever been or ever will be on an Adv...-AussieRob
rapiti is offline   Reply With Quote
Old 12-10-2004, 03:50 PM   #9
meat popsicle OP
Ignostic
Oddometer: 14,239
Ah, a "faith-based" response...
Seriously though, with the paint off and the scrapes and gouges it looks like nylon...
to an untrained eye.
Old 12-10-2004, 05:11 PM   #10
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Hey Carne de Palo,
MTBE is Methyl Tertiary Butyl Ether, it's an octane booster recently banned for contaminating groundwater....
Still not sure what our tanks are made of (laminated Austrian gnome skins?)...
CC
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 12-10-2004, 05:47 PM   #11
meat popsicle OP
Ignostic
Oddometer: 14,239
Originally Posted by ChrisC
Hey Carne de Palo,
CC
Oopsie, I was thinkin of PBDE... can't even claim dislexia!
I am guessing nylon - Australian gnomes are not so tough!
Old 12-10-2004, 10:01 PM   #12
Scoot Jockey
BST Faithful
Scoot Jockey's Avatar
Oddometer: 73
Mr. Popsicle,
Don't quote me on this, but I remember reading on the German forum that our tanks are made of a P6 composite. I would bet that traditional auto body fillers(bondo,glazing compound) would work on it though, or you could add some material through plastic welding, and sand down the area a bit to feather it out over a slightly larger area. Personally, I think it would be interesting to try my hand at making some carbon fiber guards to cover the damaged areas.
Good Luck
Scoot Jockey
Scoot Jockey is offline   Reply With Quote
Old 12-11-2004, 05:54 AM   #13
rapiti
IOR Veteran
rapiti's Avatar
Oddometer: 1,907
Go nude
Old 12-11-2004, 08:52 AM   #14
meat popsicle OP
Ignostic
Oddometer: 14,239
Go nude
I am not taking all the paint off my tank rapiti...
that is way too much work for a fashion statement.
Old 12-11-2004, 09:10 AM   #15
Happe
Offroad Nut
Happe's Avatar
Oddometer: 684
Hi Meat,
the Adventure Tank is from PA.
The Rally tank and also the rear tanks are made from PE.
Epoxi based fillers schould work for a little while on the Adventure tanks, if you really have to remove the marks of honour
cheers
Stefan
KTM Lc4 660 Rally MY98 pre e-start; KTM EXC450 MY14 Torque Rally Conversion; KTM EXC450 MY04 HDB Rally Light; Honda XRV750 RD04 MY91 AfricaTwin -for Sale-
Happe is offline   Reply With Quote
Times are GMT -7.   It's 10:45 PM.
