Old 09-17-2010, 03:53 PM   #1
ADVDiesel OP
Oddometer: 1
950 SE wheel on 990 adventure
I was wondering if anyone has swapped a set of 950 super enduro wheels on to their 950/990 adventure. Any additional parts needed? I Cross-referenced the parts manuals and the spindles have different part numbers. Any information would be appreciated.
ADVDiesel is offline   Reply With Quote
Old 09-17-2010, 05:30 PM   #2
metal
President of FRONJ
metal's Avatar
Oddometer: 205
I've been running SE wheels on my 950 ADV for quite a while now. They work just fine. You will just need to swap your wheel spacers over as they are different on the two bikes.
FIND ME ON SPOT
SPOT ADVENTURES
metal is offline   Reply With Quote
Old 09-17-2010, 05:32 PM   #3
LukasM
Oddometer: 5,417
The SE has a single disc hub and uses a 26mm spindle. I think the wheel spacers will swap out so you can make it 30mm, but you will still need a single caliper conversion.
Old 09-17-2010, 06:24 PM   #4
HWSNBN
HWSNBN's Avatar
Oddometer: 2,895
Rears the same, front is only one disk. I laced a SE rim to my front hub. Swapped the rear rim too. They rock.. and don't bend when they hit them.
HWSNBN is offline   Reply With Quote
Old 09-18-2010, 03:00 PM   #5
waveman
Oddometer: 8
I confirm the rear is the same, pay attention at the rear disk, It doesn't work with adv 950 model, SE disk is floating
waveman is offline   Reply With Quote
Old 09-18-2010, 07:10 PM   #6
LukasM
Oddometer: 5,417
Why does it not work? As long as the thickness is the same it shouldn't make any difference.
Old 09-19-2010, 02:49 PM   #7
mookymoo
Mookish Mook
Oddometer: 4,393
It does work. You have to use the 950A spacers though.
(nothing to do with the disc - more to do with differences in thickness of the calliper mount - SE and 990 have thinner mounts)
mookymoo is offline   Reply With Quote
Old 09-23-2011, 07:20 AM   #8
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,532
Curious why you would want to do that ... most go the other way and put SE rims on their ADV
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 09-23-2011, 07:26 AM   #9
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,762
You may have read this wrong. He's asking if you can do what you said.
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 09-23-2011, 07:39 AM   #10
Dan Alexander
Oddometer: 7,532
Ooops, my bad
Old 09-24-2011, 09:02 PM   #11
Riddler990
I Suck, You Rule.
Riddler990's Avatar
Oddometer: 531
I did the opposite, I had a set of woodies excels built for my '08 990 adv. wanted to swap the "good" wheel setup to my SE. called woodies, all I needed was a new set of spacers for the front wheel, which woodies sold me very cheep, $15 i think, there is a left and right side to them, they are not the same. the rear is all good, nothing special. I had to remove 1 front rotor and the abs rings. So it sounds like you need the correct front wheel spacers, call woodies.
Riddler990 is offline   Reply With Quote
Old 09-24-2011, 09:09 PM   #12
Riddler990
I Suck, You Rule.
Riddler990's Avatar
Oddometer: 531
Also there is going to be a difference between the spacers on a 950 and a 990 ADV.
Times are GMT -7.   It's 03:10 AM.
