Old 08-23-2011, 07:12 PM   #211
MotoMind
Oddometer: 1,268
Originally Posted by bhd1223 View Post
Is that a scraper/chisel?
No, just a long screwdriver shot at a dramatic angle. It really is a PITA to get enough leverage in the small space to trigger the tensioner but much less painful than skipping timing a million times.
MotoMind is offline   Reply With Quote
Old 08-23-2011, 09:11 PM   #212
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,728
Yeah...I've tried to work that method out successfully, Motomind, but been unable. Do you push against the camchain or against the black plastic guide (screwdriver between camchain & guide)?
I know that would be the best (most logical) way, but I guess I wuss out before moving the tensioner shaft far enough to release the clip......afraid of screwing something up within the chain well.
How are you getting that "extra leverage"? In fact, how are you getting any leverage at all...? What are you "levering" against to pry the shaft back?
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 08-23-2011, 09:25 PM   #213
MotoMind
Oddometer: 1,268
I push directly against the cam chain.
I put the screwdriver down the cam chain tunnel so the tip resting against the cam chain right by the bore. Standing on the left side of the bike I put my left hand on the top of the handle and my right hand is wrapped around the grip. I then pull as hard as I can with my right hand while pushing with my left. Kinda like a canoe paddle I guess? It helps to yell loudly and put your back into it that that point.
It's really annoying but I'm not a strong or big guy so I'm sure some of you beefcakes could do it too.
Old 08-26-2011, 08:52 AM   #214
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,728
Friday morning....temp is 81 deg F, and climbing fast. R-squared is strapped to the Dyno and ready to roll the drum.
I've taken a stroll to the local Diner for some breakfast. The drama....the suspense....the delays....will soon be over. Then whatever will I do? Oh my....
HF.
Old 08-26-2011, 09:51 AM   #215
bobbed06
Cavalera Conspirator
Oddometer: 1,223
bobbed06 is offline   Reply With Quote
Old 08-26-2011, 10:51 AM   #216
SkidMarx
SkidMarx's Avatar
Oddometer: 1,963
Stroker Kit.
'90 XT350
'08 WR250R
GLDS
SkidMarx is online now   Reply With Quote
Old 08-26-2011, 11:00 AM   #217
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,728
And the result is.......................is....................... is..................
Headed to office to make a high quality scan of the chart.
HF
Old 08-26-2011, 11:05 AM   #218
reddirtjoe
thinning the herd.
reddirtjoe's Avatar
Location: Let's Ride some red dirt!!.... NorthCentOklahoma
Oddometer: 1,998
HF.
Get it all sorted out, then decide you want that new KTM !!
(sell me the little R2)
I used to be a dumbazz,
then a smartazz
this year,....just an azz
reddirtjoe is online now   Reply With Quote
Old 08-26-2011, 08:13 PM   #219
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,728
Drum roll please...............the results are in. And its surprisingly good, if I don't say so myself. Oops, I guess I said so.
Its kind of like this: and and all rolled into one.
My WRR - Dyno 3 run.
This chart shows a comparison of my last run (Line 1), which would be Dyno 2, compared to the run made today (Line 2). For reference, my two previous Dyno runs can be reviewed at www.WRRdualsport.com. But, as a brief reminder, the Dyno 2 run was made with the stock cylinder, an FMF exhaust, an FMF fuel programmer, and K&N airfilter with the airbox door wide open. That run max'd out at 26.7 HP and 16 ft-lbs Torque with an ambient temperature of 50.9 degrees F. Following that run, I went home and created my "Ultimate Airbox Mod" to let her breathe better.
Today's Dyno 3 run included my Athena 290 big bore, FMF exhaust, Dynojet PowerCommander V fuel programmer, TwinAir foam filter, airbox door closed (with Ultimate Airbox Mod in place), and ambient temperature af 87.8 degrees F. This run max'd out at 32.3 HP and 20 ft-lbs of torque.
What's it all mean. Correcting for ambient temperature differences, I've gained about 25% more power and torque (or so). The exact numbers are:
HP: 26.7 to 32.3 yields 21% gain.....measured when conditions were 37 degrees hotter (and considerably more humid). The Dynostar operator said to add about 5% more value for comparable ambient conditions. That would yield 34 HP (27% gain).
Torque: 16 to 20 yields 25% gain. Adjusting 5% value for ambient temperature comparison yields 21 (31% gain).
No matter how you compare, slice, adjust, compensate, calibrate, these are simply fantastic results! My butt dyno already new things were good. I've been downplaying it a bit, as I hate to overstate or inflate. It simply is what it is, whatever may be.
To be certain, this is the exact same Dyno machine being used for all three of my dyno runs, in the exact same shop, with even the exact same Operator (Jordan) running the test each time. Turns out they didn't lose the hard-drive after all, when they broke down a couple weeks ago. They had a bad "load cell" which was not allowing them to re-calibrate. So, we've got as good a comparative run here as we could possible get, with the exception of the ambient temperature. A 37 degree difference is HUGE....especially when its pushing 90 degrees in the mid-south compared to dry cold winter. For those who may not know, normally aspirated engines (air breathing for all you yankees) run a lot stronger (produce more HP & Torque) in cold, dry air versus hot, wet air. Its the nature of the internal combustion engine.
Now, let's compare where I am versus where I started in the beginning. Dyno 1 run was made on the original stock motor with only a few basic mods (AIS removed, Airbox Flapper removed, & exup valve removed from stock pipe) as a baseline. Ballpark, those results yielded about 22 HP and 14 ft-lbs of Torque, if I remember correctly. So, let's see what I've gained from that.
HP: 22 to 33 yields 50% gain
Torque: 14 to 21 yields 50% gain
There is the bottom line.....end result. Read it and weep! Tears of joy....pure joy.
This bike is FINALLY running like I felt it should.....like I new it could. The power to weight ratio is significantly improved, making it feel more nimble. Crank the throttle past halfway, and she just rips! Wheelies effortlessly in first gear, without any use of the clutch.....just crank the throttle.
Its got much better passing speed, and pulls 6th gear uphill with no effort, in fact, it accelerates uphill in 6th easily. Now, to the downside, it has definitely gained some vibration....particularly in the bars. Not so noticeable elsewhere. Its still a very comfortable ride for me down the slab. Especially since it doesn't take as long.
She's a real hoot and I'm still madly in love with this bike, even after spending the last 10 months predominately on my new F800GS. Sorry guys, she's not for sale. Maybe not ever!
HF
Old 08-27-2011, 07:24 AM   #220
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,728
Wow...over 300 views since I posted Dyno 3 last night, and not one single comment....?
Kind of leaves you speechless, I guess.
HF
Old 08-27-2011, 07:54 AM   #221
justlookin
Oddometer: 235
over 300 views
Thats because we are running to order our own 50% HP and Torque increase
Thanks High Five
justlookin is offline   Reply With Quote
Old 08-27-2011, 08:14 AM   #222
bhd1223
bhd1223's Avatar
Oddometer: 294
I didn't get a look until 2am so I was fairly tired. I am thoroughly impressed. It looks to really give that extra little punch in the low rpms that's missing and makes the top end scream even more. I would say the non corrected numbers are probably a little more accurate of just bolting on the kit in the same conditions since you did get in and do some extra work on it. Still very impressive and something I'd consider once I become a more skilled rider or blow the engine. To think, I have even more to do now than just the exhaust, airbox mod, and programmer.
Overall -->
It's to see the end of the journey though.
WR250R - perhaps the ideal motorcycle for myself
Throw in a passenger and I'm unsure of what I'd consider ideal. Maybe a Multi?
I am now for sure sold on the Dual Sport style bike.
Keeping the Vulcan for now. The ladies seem to love it.
bhd1223 is offline   Reply With Quote
Old 08-27-2011, 08:24 AM   #223
Drtyfun
Here and There
Drtyfun's Avatar
Oddometer: 1,376
Jealous was more what I was thinking.... Now all I need to do is upgrade my XT to a WR.
Drtyfun is offline   Reply With Quote
Old 08-27-2011, 08:49 AM   #224
bpg
Off Trail
bpg's Avatar
Location: Charlotte, NC (summer back home in western PA)
Oddometer: 565
HF
lol - you were one of those kids that needed/got a lot of attention, weren't ya??
Seriously, very impressive stuff - thanks for your meticulous record-keeping, pics, etc - definitely a great data set to review.
- Brendan
'08 Yamaha WR250R (sold)
'78 Honda XL250
'02 Honda CBR1100XX
bpg is offline   Reply With Quote
Old 08-27-2011, 11:19 AM   #225
montesa_vr
Legend in his own mind
montesa_vr's Avatar
Oddometer: 1,936
Wow...over 300 views since I posted Dyno 3 last night, and not one single comment....? HF
Sorry HighFive, I had been checking so often I finally gave up on you and decided to wait a while, so I didn't see the results until today. 20+% increase from the kit alone is a staggering gain for any performance modification short of a blower, so you should be proud of yourself.
I have to admit I cringed when I saw your head and port modifications. From what I've read, porting and combustion chamber shaping often requires more trial and error than theory. Some of the old gray-haired geniuses like Bob Braverman, Gordon Jennings, and Kevin Cameron have told from bitter experience about discarding cylinder heads after even the most obvious-seeming improvements turned out to be steps backwards. So I was relieved when I saw the big gains. If nothing else, you couldn't have screwed it up too much. And I was especially surprised at the gain in upper rpm horsepower, which is not a typical result of a bore increase. So maybe your porting had something to do with that.
You are to be commended for putting an incredible amount of time and money into sharing your experiment. Many of us have bought magazines for far less information. I don't expect anyone to step up and put the same amount of effort into documenting the stroker kit, but I hope at least you will get a chance to ride a stroked bike side by side with yours and offer some thoughts.
montesa_vr screwed with this post 08-27-2011 at 02:02 PM
montesa_vr is offline   Reply With Quote
Times are GMT -7.   It's 06:40 PM.
