09-24-2010, 03:14 AM
#91 |
Noob
Oddometer: 1,791
Rings
This may serve better than four hands to compress the rings
http://buy1.snapon.com/catalog/item....&group_ID=1593
Don't make the mistake of believing everything you think. |
09-24-2010, 07:58 AM
#92 |
Oddometer: 2,289
Great write up HF, the devil is in the details and you address them nicely.
thanks!
10Cup - WR250R - BMW R1200GS Trails of the West 2011 Moab/Western TAT 2010 Continental Divide Ride 09 Route 66 Ride SPOT Tracker SpearMotorSports, Inc. The cost of living's going up, and the chance of livin's going down. |
09-24-2010, 08:55 AM
#93 | |
Oddometer: 3,539
I'm sure you noticed in the pictures I was wearing my riding gear. I was going on a ride . . . which I postponed to stop in and help my good buddy HF. It's a good thing we're really good friends too, since we were both twisted up like a pretzel with four hands in the mix trying to get that wrist pin locked in place. Might have looked kind of funny if you didn't know what was going on ![]() Now . . . about that chicken
Loud Sucks! www.wrrdualsport.com www.designatedvaping.com <- for all your electronic cigarette needs |
09-24-2010, 10:15 AM
#94 |
Oddometer: 189
You might find it easier to install the piston into the cylinder before you put the piston on the rod if you do it again. That way you can install the rings on the bench and all you have to do on the bike is push the wristpin through.
09-24-2010, 11:08 AM
#95 | |
Oddometer: 359
Sometimes the obvious evades even the most experienced of us...LOL...HF, another..."Great Job" on that tensioner discussion!
the true tragedy of our times - human overpopulation is destroying the 2-stroke |
09-24-2010, 11:59 AM
#96 |
Oddometer: 3,539
FYI - we thought about that, but putting the wrist pin clip in was MUCH harder than sliding the cylinder down onto the piston. That little clip was a mother and trying to install it under the cylinder would have meant death for somebody.
09-24-2010, 01:16 PM
#97 |
Oddometer: 2,289
Yes, the cylinder would get in the way. One method that has helped me over the years is to use the wrist pin. First just push one of the circlips into the wrist pin bore with the opening positioned toward you and away from the piston, then insert the wrist pin from the opposite side thus squaring up the circlip and then gently push the wrist pin on through until the clip snaps into the grove. Hold your thumb over the wrist pin hole so that if you push too hard and it is forced back out it won't end up on the moon as HF says. This step can be done before even putting the piston on the rod.
Putting the last circlip requires a different technique but the wrist pin being in the bore helps a lot. I use a flat blade "putty knife" under the lower lip after putting the top of the circlip in the grove and then just gently lift up on the flat bladed putty knife while pushing in on the clip and it snaps right into place. Requires practice but works very nicely.
09-24-2010, 02:44 PM
#98 |
Riding Nomad™
Oddometer: 12,785
It's amazing how much similar the top-end is to the WR(F) series motor.. Well, then again, they are all pretty much the same :)
Learn to ride. Ride to learn. |
09-24-2010, 04:00 PM
#99 |
Bike-aholic
Oddometer: 2,103
Lots of interesting comments here. Keeps me thinking...
10cup, I follow what you're saying. I think its very similar to what we did, ex the putty knife. I've done other wrist pin clips before, too. Either my age is wearing on me, or it just takes....how shall I say.....el hombre mas macho, con huevos....for this one! Enough engine blood & guts for the moment. Oh, we're not done yet. Not by a long shot. There is much more excitement to come. But first, a little sneaky peaky at "Houston": ![]() "Houston" is about the same size as my FMF PP unit. Actually, its slightly thinner. But this Mission Control, is WAY more powerful in its capabilities: ![]() Especially when coupled to the AutoTuner, as I'm still learning. Here is where I tapped the Wideband O2 Sensor into my FMF pipe: ![]() Oh....are we ever gonna have fun playing with this gadget, together! Intermission over. Back to the regular scheduled programming... HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 BMW F800GS, '71 Honda CL70 Bergs Over the Rainbow Texas or Bust! BigDog/Highfive--Fall Colors in Missouri 2011 Athena Big Bore Project The Other Side of Nowhere Highfive Goes Dragon Hunting WRRDualsport.com |
09-24-2010, 04:35 PM
#100 | |
You obtain the size pad that would increase the gap to a distance greater than you desire. Get a near perfectly flat surface, like a piece of glass that you will not need in the future for optical clarity. Next gather a fine sanding surface similar to emery cloth. Add a little friction reducer, say in the form of sewing machine oil or even 3-in-1 oil and gently lap the pad down to the size you desire, checking the thickness frequently to ensure you don't go past your optimum thickness. This can be done with any shim.
That’s the thing about traveling. If you’re looking for something, you can almost never find it. But if you are just open to what is there, it’s almost always awesome - Neduro In spite of illness, In spite even of the archenemy sorrow, One can remain alive long past usual date of disintegration if one is unafraid of change, insatiable in intellectual curiosity, interested in big things and happy in small ways. - Edith Wharton Need a smugmug coupon? Well here you go z0g48s072w1kE PowerT screwed with this post 09-27-2010 at 12:59 AM |
09-24-2010, 06:01 PM
#101 |
Oddometer: 359
I can attest to this method. Being a cheap-skate, I've used this method more times than installing new shims - a figure 8 pattern as noted above does the trick nicely.
09-24-2010, 06:18 PM
#102 |
I see dumb people!
Oddometer: 1,129
Hey i've only read the header of this thread ,but i had an 06 CRF450 that i put a Vertex 490 kit in and it was an awesome bit of kit.
The mighty XR650R. The old trail bike that all modern trail bikes are judged by. It's funny cause it's true!. |
09-24-2010, 06:20 PM
#103 |
Oddometer: 66
Think of the guy that might come along after you and grind the number side of the shim if you choose to go that way...
09-24-2010, 08:14 PM
#104 |
Bike-aholic
Oddometer: 2,103
Do you actually used emory cloth, or some other ultra-fine type of sanding paper? Or maybe, some type of rubbing compound spread onto the glass?
I've wondered how that might affect the hardened (heat treating), if applicable. So, I never tried it before....but I've wanted to. HF
09-24-2010, 08:38 PM
#105 |
Potius Sero Quam Numquam
Oddometer: 4,406
I've done it too HF, on many bikes, because shims often don't come in enough sizes. I've never had any wear issues from this. I'm pretty sure those shims are hardened all the way through. I've used 600 or 800 grit wet'r'dry sandpaper (wet) on a glass surface or machine tool table and that works great. Polishing/rubbing compound I think would be too darn slow.
