Old 09-19-2010, 06:47 PM   #1
Dirt McGirt OP
Oddometer: 50
OHH MAN!?! DR650 header glowing red
Well I guess I should start by saying that I had been experimenting with which jets and mixture settings worked best for the old DR. This was while it was alot hotter and alot more humid here. I got it to where it seemed to be working about as good as I could get it.(pretty darned good)
Now the weather has changed and it is a whole lot cooler and less moisture in the air.
I have the 170 main jet, clip set at the #4 from the top of the needle slot. I had the mixture screw set at between 3/4 and 1 turn out.
The instuctions that came with my extended mixture screw from kientech said to set it between 3/4 and 1 1/8 turns out.
The paperwork that came with the dynojet kit says 2 1/2 turns out, which seems to be way too rich in everyone's opinion, including mine.
Now the issue, I just came out of my dad's house after letting the bike sit for over an hour. The bike was cold enough to need to be choked to idle.
After less than 2 minutes(of idling) the header was glowing red, never in 4 years have I seen this happen.
This made me real nervous, but once I fattened up the mixture it seemed to be back to normal.
Anybody had this happen before?
Is it semi-normal?
Is it easy to fry a motor this way?
Anything I should be worried about?
Anybody care to give me your thoughts on this? Thanks guys Dirt
Dirt McGirt screwed with this post 09-19-2010 at 07:03 PM
Dirt McGirt is offline   Reply With Quote
Old 09-19-2010, 07:07 PM   #2
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,477
take this over to thumpers and the dr650 thread and you'll have better luck with the right answers
JT
www.northwoodsairheads.com
www.jefftrappwindsors.com
"Between two explanations, choose the clearest; between two forms,
the most elementary; between two expressions, the shortest."
Between two motorcycles the simplest (DW)
Eugeni d' Ors (1881-1954); Spanish writer.
jtwind is offline   Reply With Quote
Old 09-19-2010, 07:45 PM   #3
MarylandStrom
Oddometer: 342
It happened all the time on my old Yamaha WR400 when I let it idle. I never liked the idea of it glowing, so I tried not to idle very long. But in my opinion it is pretty normal on big bore four strokes.
I think a lot of people don't notice that their thumpers are glowing red because they seldom ride at night. The glow can be seen in daylight but obviously not as easy as in the dark.
MarylandStrom is offline   Reply With Quote
Old 09-19-2010, 08:58 PM   #4
Bobthebiker
not normal
Oddometer: 493
I've seen the glowing exhaust thing. idling excessively does that. basically what it is, is that you have all that exhaust heat building up, and no airflow to help carry said heat off, so the pipe begins to heat up and glow.
doing this isnt GREAT for your engine, try if you can to keep air flowing over it. overheating it may cause damage you dont even want to realize can be done so easy.
Where does this road go? screw your maps! we're gonna find out the FUN way!
error 404: common sense not found.
Bobthebiker is offline   Reply With Quote
Old 09-19-2010, 10:01 PM   #5
Jrmobb
Jrmobb's Avatar
Oddometer: 217
glowing is normal no worries. Happens on all my bikes. Like stated previously, most people just never ride at night so they dont see it.
09 Te510
Bikes of the past:
02 rm125, 96 rmx250, 01 drz400E, 07 drz400sm
02 ktm 640, 06 ttr125
Jrmobb is offline   Reply With Quote
Old 09-20-2010, 07:38 AM   #6
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,332
+1 normal.....won`t hurt a thing,no airflow cooling the header.....mine will glow red when idling and the oil teperature is only 200 degrees,so the engine itself is not really hot..
B
techforlife is offline   Reply With Quote
Old 09-20-2010, 08:43 AM   #7
KneeKicker
KneeKicker's Avatar
Oddometer: 2,631
First time I saw the "glowing pipe" I freaked too I had a 98 YZ400f and thought something was wrong. MY DRZe will do it too if it idles too long but not as quick as the YZ did.
everything looks cool on motorcycle
"I got so drunk last night I woke this morning and someone had shit my pants" Ron White
KneeKicker is offline   Reply With Quote
Old 09-20-2010, 09:00 AM   #8
Flatulator
Oddometer: 733
pop open the hood on a 4 cyl car ... with a header exhaust (not a cast manifold) ... (at night) .. the exhaust is all glowing a dark red in there
looks kinda evil ... and cool
... and normal
you might not see it in daytime as well ... but at night you will
Flatulator is offline   Reply With Quote
Old 09-20-2010, 01:17 PM   #9
Dirt McGirt OP
Oddometer: 50
Thanks for the replies guys, I feel a little better now.
I have 13k on this bike and just less than half of the miles have been at night. I have never seen this happen.
I think that I had it running extra lean and this contributed to the glow.
Once I richened the mixture it went away immediately.
Seems to be alright. Runs still, that's always a good thing .
Thanks again for chiming in guys, Dirt
Old 09-20-2010, 01:33 PM   #10
gplassm
gplassm's Avatar
Oddometer: 588
Don't worry, unless the color starts approaching *white*.
Street bikes for the street. Dirt bikes for the dirt. Let's keep it that way.
gplassm is offline   Reply With Quote
Old 09-20-2010, 06:59 PM   #11
rallyhound
Macho stud guy
rallyhound's Avatar
Oddometer: 871
HMM INTERESTING.
Just went for a 30 mile ride, came home and let the bike idle for 30 minutes.
Exhaust header didn't glow a bit.
When it's all said and done, More will be said.
You dont have to wish me luck for me to know that I need it.
rallyhound is offline   Reply With Quote
Old 09-20-2010, 08:53 PM   #12
Motomantra
Registered Lurker
Motomantra's Avatar
Oddometer: 1,364
Originally Posted by rallyhound
HMM INTERESTING.
Yea, Some of these guys are lost.
No, it shouldn't be glowing. On the other hand, an air cooled engine needs air flow. Don't let it idle for long.
For those that fight for it, freedom has a flavor the protected will never know.
Motomantra is offline   Reply With Quote
Old 09-21-2010, 01:27 AM   #13
JensEskildsen
Oddometer: 1,057
Why would you let a aircooled engine idle for 30 minutes?
Do you run it without oil aswell, to check for knocking sounds?
Headers CAN glow red, they do get awfully warm very fast, some do, some dont glow.
Run a low rpm/throttle sparkplugcheck, it the plug is white or gray, adjust the CO screw, that could help.
JensEskildsen is online now   Reply With Quote
Old 09-30-2010, 03:13 AM   #14
diesel critter
Oddometer: 33
fuel air ratio, spark and/or valve timing can affect how hot the exaust gets. Even cast iron manifolds can glow red, they shouldn't, often its a timing problem, or perhaps in the case of some mcycles, the timing at idle isnt really what it should be for optimal idling, cuz thats not what motor bikes are for!
diesel critter is offline   Reply With Quote
Old 09-30-2010, 03:24 AM   #15
Brendan J
ONE HACK AT A TIME
Brendan J's Avatar
Oddometer: 1,563
Did it look anything like this ???? And this is in the daytime.
Brendan J is offline   Reply With Quote
Times are GMT -7.   It's 12:57 PM.
