Old 09-21-2010, 07:40 PM   #16
spartanman OP
regret minimizer
spartanman's Avatar
Oddometer: 1,104
Originally Posted by pommie john
Motobins do a heavy duty clutch spring.
http://www.motobins.co.uk/bmw-parts....20valve%20Twin
Thank you. Good to know.
spartanman is offline   Reply With Quote
Old 09-22-2010, 11:44 AM   #17
spartanman OP
regret minimizer
spartanman's Avatar
Oddometer: 1,104
Update: The clutch slipped again this morning under high loads in top gear. I have to remove the trans to fix a notchy shift cam roller and replace the pawl spring (pre-emptive maintenance).
Just ordered one of these from Motobins:
CLUTCH DIAPHRAGM SPRING-HEAVY DUTY TWINS 1955-80 *RECOMMENDED FOR ALL 1000cc*
(NOT R45/65 1978-80)
Part No. 32000
I'll let you all know how it works.
Old 09-22-2010, 12:21 PM   #18
supershaft
because I can
Oddometer: 9,116
Part No. 32000
I have found that new pawl springs are just as likely to break as old ones. I don't change them unless someone insists and have never had any problems for it. I have seen a couple of rollers split but I don't remember ever seeing one get a flat spot. Personally, I don't like the feel of a metal roller. It makes my bike feel like a K bike. At least to my toes. IMO, even that is not good.
I have always adjusted clutches by the book and never had a problem for it. Normally, cable free play isn't reduced by the bike getting hot, it is reduced by revs. Centrifugal force somehow forces the spring out just a tad. Lightly take out the cable play with your fingers at the lever and rev the engine. You can feel the spring moving back and forth.
I forgot to add that shift quality can be effected by the one shifter cam coming loose from the cam's gear. Check and make sure there is no slop there. The setup works loose and makes for notchy shifting. I lot of people forget to check that.
supershaft screwed with this post 09-22-2010 at 12:26 PM
Old 09-22-2010, 12:46 PM   #19
spartanman OP
regret minimizer
spartanman's Avatar
Oddometer: 1,104
Thanks for the tip on the shifter cam. Disagree on thermal effects. Consider how idle speed increases when the engine warms up if there is insufficient cable slack. Parts of different materials thermally grow at different rates. Agreed, a new spring can fail too, though statistically, the one with the more stress cycles will fail first, all other things equal. And blasmephous as it sounds, I'm replacing the plastic roller with a k-bike steel equivalent. I find the k-bike shifter action to be less vague than the airheads.
Old 09-22-2010, 03:38 PM   #20
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Part No. 32000
Just so you know that is no different than the BMW HD spring available at any US dealer for the same amount of money $58.87 U.S.
The spring was introduced on all big twins after the R100 debuted in late 1976.
(The /5 spring is still available and has a lighter clutch feel. part # 21211250288 same price.)
Part number for the R100 spring you just bought in ENGLAND is probably 21211234035, $58.87, same as here in the US.
Check in your home country first, it'll save some aggravation and shipping $$$
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 09-22-2010, 03:56 PM   #21
spartanman OP
regret minimizer
spartanman's Avatar
Oddometer: 1,104
Thanks for the history lesson. Where were you yesterday?
Old 09-22-2010, 05:35 PM   #22
pommie john
pommie john's Avatar
Oddometer: 1,486
If your local BM dealer is anything like mine here in Oz, you're better off going to Motobins.
My local dealer told me there was only one spring available, and when I fitted it, the clutch slipped. I called Motobins, told them the part number that was on it and they said it was the weaker spring, sent me the new one, bingo no more clutch slip. Well worth an international phone call.
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt.
Bertrand Russell
pommie john is offline   Reply With Quote
Old 09-22-2010, 06:20 PM   #23
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
I'm always here. Always watching.
Most of the time anyway.
www.wirewerkes.com
Old 09-22-2010, 06:24 PM   #24
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Wish it wasn't so bad for you blokes over/down under there!
Here in the states there are still a few dealers who know what the fuck they are talking about with airheads, (one less guy since I retired) but they are out there.
I do free consultations too.
Too old to give a flying fuck anymore. ( never did anyway, but now it seems more acceptable!)
Good on ya P.J. for piping up when ya did.
Robert
www.wirewerkes.com
Old 09-22-2010, 06:54 PM   #25
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,651
I've got the heavy duty clutch spring in my R75/6. I never really noticed a difference with anything.
But, the spring came to me below the suggested minimum relaxed height in the Clymer. I was told that the Clymers number is for the lighter duty spring.
So, what's the service limit of the heavy duty spring?
crazydrummerdude is offline   Reply With Quote
Old 09-22-2010, 10:57 PM   #26
supershaft
because I can
Oddometer: 9,116
Thermal effects on idle speed is almost entirely do to increased combustion efficiency, not a change in cable pull. You are mixing an entire different can of worms into pot. Nevertheless, adjusting the clutch cable by the book does work and centrifugal force does reduce clutch cable pull at the very least a lot more than differences in temp.
Since we are making up statistics, I think statistically speaking a spring with a metallurgical flaw is the spring that will fail first. I think a good way to test for such a flaw is to put it through many stress cycles. If it has survived thousands, chances are it will survive thousands more. I have seen too many recently installed springs fail to think that new ones are any better than ones that have lasted quite some time. They might even be worse. That has been my experience so far.
Old 09-22-2010, 11:39 PM   #27
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,884
+1 on that. I have one in my 78RS no problem with the clutch at all.
Rob Farmer is offline   Reply With Quote
Old 09-23-2010, 04:38 AM   #28
spartanman OP
regret minimizer
spartanman's Avatar
Oddometer: 1,104
I emailed Motobins. You're correct. Their heavy-duty spring is BMW 21211234035. I cancelled the order. Thank you.
Old 09-23-2010, 04:44 AM   #29
spartanman OP
regret minimizer
spartanman's Avatar
Oddometer: 1,104
Originally Posted by mymindsok
If you want to throw your $$$ away, Motoren Israel can probably help. They manufacture good stuff for racers and the high performance crowd but the prices are insane. Look em up via Google and rest easy in the knowledge that they take credit cards.
You can easily shim your spring to get more pressure and then add an 'easy clutch' system but you'd better keep an eye of the ancillary parts.
The late model clutch is the way to go.
So I assume you shim behind the diaphragm spring? Any idea how thick?
Poked around on Snowbum's site as suggested above. Sounds like a .050" donut shim will do it.
spartanman screwed with this post 09-23-2010 at 01:46 PM
Old 09-19-2014, 01:05 PM   #30
AndrewSJC
Oddometer: 53
Can anyone tell me where to get the "donut shim" mentioned above? I looked on Snowbum's site and it says:
"Bring spring closer to the pressure plate. Place a .035"-.065" hard steel donut ring shim between the flywheel and the spring base. Such large transmission and differential 'shims' are available from such as RingPower heavy equipment shops; or, see any competent local mechanic's junk box of old shimming items."
I haven't been able to find any place called "RingPower". I don't know what the shim looks like, so I don't know what to ask for at my local mechanic's.
Any photos of such a shim, and where it is placed, would be greatly appreciated.
AndrewSJC screwed with this post 09-19-2014 at 01:12 PM
AndrewSJC is offline   Reply With Quote
Times are GMT -7.   It's 01:47 AM.
