Old 09-22-2010, 12:04 AM   #1
Jud OP
Jud's Avatar
Oddometer: 2,542
Taller 5th gear for XR650L???
I used to do alot of 4wheeling. In that hobby there is a huge cottage industry that sells customers steeper gearing for their Xfer cases. That way you can have your cake and eat it too. Much lower gearing when "wheeling" and the ability to cruise at reasonable hwy speeds.
Apparently the Japanese can't get their heads outta their rump and offer a dualsport with a decent wide ratio tranny. Close ratio for the first four or so gears for trail performance and a tall OD top gear for the hwy ala Husky 610. So question is, does anyone offer a set of drop in taller gears for the XR650L?
Pics- http://s563.photobucket.com/albums/s...eon/?start=all
Places visited on two- http://s563.photobucket.com/albums/s...0two%20wheels/
Endeavor to Persevere
Blue Skies Coming
Jud is offline   Reply With Quote
Old 09-22-2010, 06:14 AM   #2
mcma111
mcma111's Avatar
Oddometer: 12,563
Gears
Not to my knowledge. You could search different models, XR, NX for the 5th gear tooth count but I don't know of anything like your request. Going 1 tooth up on the front will be to much, The engine gust doesn't have the beans to pull it. Going down 1 or 2 on the rear might work as long as your not trail riding the bike.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 09-22-2010, 06:30 AM   #3
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,332
Change out the second gear too close the 1st-2nd gap with an NX650 2nd gear (16teeth) and leave the final drive gearing at 15/45..........you can crawl through the woods in 1st and 2nd and fly down the highway at 65-70 with no probs..i`ve had mine with some engine mods up to 110 mph on my GPS and if i tucked down i`d get a little more.........can`t see me doing that again.................how fast do you think a dirtbike should go
B
techforlife is offline   Reply With Quote
Old 09-22-2010, 07:35 AM   #4
Jud OP
Jud's Avatar
Oddometer: 2,542
B
I would like to be able to keep up with traffic at around 80-85mph on the interstate while not revving the poo outta it. Then run rocks on OHV trails. Either a deeper 1st gear or a taller 5th will work.
Blue Skies Coming
Old 09-22-2010, 07:38 AM   #5
Jud OP
Jud's Avatar
Oddometer: 2,542
I don't care if the engine can't pull 5th to redline. I just want it running at a much more relaxed rpm while cruising on the hwy. My wifes Ascot can cruise all day at 80mph because of the tall 6th OD. Husky seems to get it with their tall 6th gear, how come the Japanese can't seem to figure this out? They did way back in 83 then forgot it apparently.
Blue Skies Coming
Old 09-22-2010, 08:03 AM   #6
mcma111
mcma111's Avatar
Oddometer: 12,563
I see a KLR in your future
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 09-22-2010, 08:09 AM   #7
BHW
BHW's Avatar
Oddometer: 4,141
Really?
Maybe as a commuter...then he could buy a dirtbike for the rocks.
2003 Aprilia Tuono
Alcohol, Tobacco and Firearms should be a convenience store, not a government agency!
BHW is offline   Reply With Quote
Old 09-22-2010, 12:56 PM   #8
Jud OP
Jud's Avatar
Oddometer: 2,542
No interest what-so-ever in a KLR. Already have a DR650 and it sucks everywhere, just not as bad as the KLR.
A cheaper, simpler Husky TE610 is what I want. The XR is cheap to buy and maintain. Cheap and easy to mod into exactly what you what as it arguably has the largest aftermarket support. It's air cooled. It's easy to maintain too but it has one problem, you can gear it low for fun or gear it high for the hwy but you can't have both like you can with the Husky. A tall top gear would fix that and why Honda nor Suzuki can do it is beyond my comprehension. Oh yea, did I mentien it's air cooled.
Blue Skies Coming
Old 09-22-2010, 01:04 PM   #9
Onederer
Crunch Nugget
Onederer's Avatar
Oddometer: 856
Then buy something else
I staired a whole thru the breaks until I remembered the carb prolly has a problem to and I'm gonna hafta work on em.
Onederer is offline   Reply With Quote
Old 09-22-2010, 01:10 PM   #10
LRPct
LRPct's Avatar
Oddometer: 489
Unfortunately it seems carrying and changing CS sprockets might be the best solution for you.. Some guys actually do it, and rather quickly even. Not this one.. I just enjoy my "not simple" 610..
LRPct is offline   Reply With Quote
Old 09-22-2010, 01:12 PM   #11
Jud OP
Jud's Avatar
Oddometer: 2,542
and that's what this thread is about.
If I can use the aftermarket or creative OEM swapping to fix what I see as the XR's main issue vs the Husky I'll get it. If not, I'll spend the extra money and get the Husky.
Blue Skies Coming
Old 09-22-2010, 01:14 PM   #12
Jud OP
Jud's Avatar
Oddometer: 2,542
That's what I have done a couple times on my DR650 {clip holding the front sprocket and no cover}. And yes, it looks like I might end up having a "not simple" and more costly 610.
Blue Skies Coming
Old 09-22-2010, 04:15 PM   #13
LILBIT
Ride you must.
LILBIT's Avatar
Oddometer: 1,675
Start shopping.
I eat my candy with the pork and beans-
LILBIT is offline   Reply With Quote
Old 08-27-2011, 03:35 AM   #14
Jud OP
Jud's Avatar
Oddometer: 2,542
Just wanted to update this thread with relevant info in case anyone finds this post during a search. Apparently Honda did make a taller 5th gear for the XR650L,,,,,,,,,,,,, it was installed in their FMX650 which was a Euro spec bike built between 05 and 09.
Getting it here will cost a bit due to shipping but I will be investigating it because from what I here, it's taller ratio is roughly equal to running a tooth less on the front or three teeth higher on the rear. If true, I could run a 14T front an a 48T rear and be fairly cool on the interstate.
Will also try to get a NX650 2nd gear to pop in while the cases are split. The NX650 is a bit lower than the OEM XR650L 2nd gear and helps quell the huge hole between 1st and 2nd.
Blue Skies Coming
Old 08-31-2011, 04:41 PM   #15
Lonestar2112
scatology expert
Lonestar2112's Avatar
Oddometer: 7,740
If you can get a part number, talk to some of our friends that traverse the pond and see if one is will to bring it home with them or willing to buy it and ship it to you.
If you do get a part number please post it!
http://share.findmespot.com/shared/f...SKgzdmS9ir0XK3
Wypierdalaj ty chuju jebany
F*CK CANCER
Lonestar2112 is offline   Reply With Quote
Times are GMT -7.   It's 01:49 AM.
