Old 09-28-2010, 10:45 AM   #16
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,613
This should be stickied. GadgetBoy, you listening?
-Scott- MotoGearGrinder.com
Semper Fi
YetiGS is offline   Reply With Quote
Old 09-28-2010, 02:11 PM   #17
Simonf8gs
Oddometer: 31
Good job Cory!
___________________________________________
Currently ridding to Tiera del Fuego, Argentina
http://aventuresdesimon.blogspot.com/
08 BMW F800GS
04 Yamaha YZ250 2 strokes
Simonf8gs is offline   Reply With Quote
Old 09-28-2010, 02:21 PM   #18
EnderTheX
Drunken Squirrel
EnderTheX's Avatar
Oddometer: 2,772
Awesome stuff! Doesn't look as bad as I thought it would be.
The puny shims will soon quiver at the might of my DIY mechanic skills!
EnderTheX is offline   Reply With Quote
Old 09-28-2010, 03:35 PM   #19
L.B.S.
Oddometer: 1,435
Good show! Many thanks for the time and effort to post up the pics and detailed info!
L.B.S. is offline   Reply With Quote
Old 11-01-2010, 08:24 AM   #20
Mollygrubber
Eschew obfuscation
Mollygrubber's Avatar
Oddometer: 1,405
That was really good, thanks from another Canucklehead.
"What you damn kids need is a right good war" - my father
Mollygrubber is offline   Reply With Quote
Old 11-02-2010, 01:40 PM   #21
gapek
gapek's Avatar
Oddometer: 9
Originally Posted by GNP77
BMW has a special tool that you thread into this hole and it locks the crank in place to insure it doesn't move from TDC #1 cylinder while you perform your valve adjust. I don't have the BMW tool but made something similar by tapering an M6x 1.25 allen head bolt with the bench grinder.
GNP77 are you sure that this should be an M6 bolt ?! I've just tried to lock the crank, but M6 bolt is too small... I think that this should be an M8!
gapek is offline   Reply With Quote
Old 11-02-2010, 06:39 PM   #22
Camel ADV OP
aka Oso Blanco
Camel ADV's Avatar
Oddometer: 1,501
Umm, not sure. I wrote that at 4am so I very well could have made a mistake on the size. It should be the same size as the handle bar clamp bolt so yeah, likely an M8.
Edit: Yeah just double checked it and it is an M8. Sorry for the misinformation.
Cory
Camel Tank auxiliary fuel tanks for KTM 1050/1190/1290 and F-series BMW twins. www.Camel-ADV.com
Camel ADV screwed with this post 11-02-2010 at 06:45 PM
Camel ADV is offline   Reply With Quote
Old 11-03-2010, 01:39 AM   #23
gapek
gapek's Avatar
Oddometer: 9
Cory
Thanks for the info, I'm doing the valve adjustments right now and your posts are like a Bible to me ;)
I noticed one thing, in the BMW DVD service manual is stated that to measure TDC on cylinder #2, you have to rotate 360 degrees… it does not make sense, because after full 360 rotation you’re back in TCD #1 position. I did like you have posted: 180 degree rotation, IN and EX marks and in the same level but pointing in opposite directions – front and rear of the bike.
I’ll post some more info when job will be finished.
Old 11-03-2010, 09:02 AM   #24
itsatdm
itsatdm's Avatar
Oddometer: 4,980
I am not sure, I understand what you did or you understand what the manual meant to say. The cams move at half the speed/distance of the crank. 1 360 degree rotation of the crank puts the valves TDC on the compression stroke on #2, but the cams have only moved 180 degrees.
In a 360 degree twin like the 800, the pistons rise and fall together, but fire alternately. It is a 4 stroke so it requires 2 revolutions of the crank for the cylinders to complete the cycle, ie 720 degrees. On the timing marks on #1 for both cam and crank, you are on TDC for the compression stroke, cam lobes fore and aft. Turn the crank 360 degrees, ditto for #2. Another complete revolution of the crank, back to #1.
Sounds like you did it right, based on the location of the cams fore and aft, when you took the measurements. The marks on the cam faced away and not inward.
itsatdm is online now   Reply With Quote
Old 11-03-2010, 09:16 AM   #25
Camel ADV OP
aka Oso Blanco
Camel ADV's Avatar
Oddometer: 1,501
I'll go back and clarify that point. Because you (or I did anyway) rotate the motor with rear wheel, it's tough to watch the timing mark on the crank and turn the tire at the same time so I was watching the cams, which as itsatdm said rotate 1/2 as much as the crank. The BMW manual is correct stating that the crank should rotate 360 degrees for the #2 cylinder check.
Old 11-03-2010, 09:25 AM   #26
Camel ADV OP
aka Oso Blanco
Camel ADV's Avatar
Oddometer: 1,501
Originally Posted by Anorak
Does BMW want you to use something like this for the cam retainer on the twins?
I assume those big nuts are BMW tools to ensure even pressure is applied before tightening the outer fasteners? If that's the case, there's no mention of it in the shop manual (on my DVD anyway).
Old 11-25-2010, 01:47 PM   #27
KWE
F800GS
KWE's Avatar
Oddometer: 3
Hello my name is Klaus and I'm new here.
This is a very good description but please take care that you are using the correct measuring instrument.
Even if you're using a TESA caliper, the accuracy only is +/-0.02mm
If you are want to measure a dimension of x.05mm you should use a micrometer like that:
http://pdf.directindustry.com/pdf/te...90828-_45.html
Kind regards
Klaus
KWE screwed with this post 11-25-2010 at 01:52 PM
KWE is offline   Reply With Quote
Old 11-25-2010, 01:50 PM   #28
KWE
F800GS
KWE's Avatar
Oddometer: 3
Sorry I'm from Germany but a caliper is not accurate enough for this measurement.
KWE screwed with this post 11-25-2010 at 01:59 PM
Old 11-25-2010, 09:12 PM   #29
Camel ADV OP
aka Oso Blanco
Camel ADV's Avatar
Oddometer: 1,501
I didn't actually use them for measuring the shim thickness. I had them out to show how small the shims are.
The sizes are stamped on the side of the shim so no measuring is required.
Old 11-25-2010, 09:23 PM   #30
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,263
Oh German perfectionist n00B... Welcome to ADV, but might I say you should sit back and learn a few things from people that have their shit together before you speak.
Lost Rider screwed with this post 11-25-2010 at 09:29 PM
Lost Rider is offline   Reply With Quote
Times are GMT -7.   It's 09:57 PM.
