Old 12-06-2010, 12:08 PM   #61
cyclewizard
cyclewizard's Avatar
Oddometer: 4,814
C-dub......
Powered by CW-Pistons/cams
Wizard manufacturing....
cyclewizard is offline   Reply With Quote
Old 12-06-2010, 12:08 PM   #62
cyclewizard
Oddometer: 4,814
C-dub......
Old 12-06-2010, 12:09 PM   #63
cyclewizard
Oddometer: 4,814
I made this too, EFI..
C-dub......
Old 12-06-2010, 12:42 PM   #64
boingk
boingk's Avatar
Oddometer: 339
Gearing is 15/47 right now. Chain is a top of the line DID O-ring. No chain oiler.
I ran 15/48 for a while, it was a hoot around town. I feel that the 14/40 is a lot better suited to the road though, and you still get mental pull off the line... perhaps better because of the longer gearing being more suited to the spin-up characteristics of the engine. If I were to gear the rear again I'd go a 41 or 42 though as 15/40 is slight overkill and 14/40 doesn't quite have enough legs for my liking.
I would definitely recommend a chain oiler, I've run my Tutoro for around 1000km now and can't speak highly enough of it. Simple, robust, easy to use, cheap to buy. Check out tutorochainoiler.com for more info, it'll double your chain life for about US$40.
Sprockets I'd recommend would be only steel, aluminium ones will shear... but then again you probably know more than me on this one. JT Sprockets are the ones I favour, I believe they are OEM gear on a lot of bikes.
Originally Posted by cyclewizard
EFI
Heresy! BURN HIM! BURN THEM ALL!
Cheers - boingk
'00 VTR1000F, '97 XR600R, '80 GS850G
boingk is offline   Reply With Quote
Old 12-06-2010, 01:12 PM   #65
XRider OP
Almost Lifelike
XRider's Avatar
Oddometer: 1,275
Originally Posted by cyclewizard View Post
Very nice job! I'm not sure I would have milled off the guides like that but the ports look good.
XR650R Plated Supermoto
XR628R Plated and highly modified
CR500R Still rips after all these beers
RZ350L Kenny Roberts Special
BMW R1200GS Adv Kind of a space ship
XRider is offline   Reply With Quote
Old 12-06-2010, 01:13 PM   #66
XRider OP
Almost Lifelike
XRider's Avatar
Oddometer: 1,275
What are you using for the ECU?
Old 12-06-2010, 01:23 PM   #67
cyclewizard
Oddometer: 4,814
It's a 54mm tb and I'm using a dynatek ecu that they custom made for me.
The motor is 727cc's with 12.5.1 comp, I'm going to make a custom 14.1 slug for it down the road.
I'm still working all the bugs out of it.
C-dub......
Old 12-06-2010, 09:45 PM   #68
windquest
windquest's Avatar
Oddometer: 574
Hey Wizard, when are you gunna do a write up on that monster of a motor and the efi conversion?? Im itchin to know more about it....
windquest is offline   Reply With Quote
Old 12-07-2010, 08:50 PM   #69
XRider OP
Almost Lifelike
XRider's Avatar
Oddometer: 1,275
I assume you'll be running race gas?
Old 01-27-2011, 07:59 PM   #70
artimious7@yahoo.com
Artimious7
Oddometer: 14
Xr6
Being a shameless show-off I thought I start a thread for one of my favorite bikes, it's a plated 1996 XR600R. As some of you have heard me say before about the Big 6, there's newer, there's lighter, and there's faster, but few are as much fun and none are more reliable. My goal with this project was to mod the engine to make monster power, have enough lights so it could be seen from space, run on pump gas (91 r+m/2), and not lose the legendary reliability. This is the result, 52 horse power and 170 watts pointing down the trail.
I have lots more pictures and I'm happy to share any of the details involved with building this bike. I did all of the work myself so everything will be a first hand account. I also have pictures of the head after porting and polishing if you guys would like to see them. I suppose I should start with a parts list.
Head:
Kibblewhite Black Diamond Valves
Mega-Cycles full race cam grind #173X12
Kibble racing valve springs w/h titanium retainers
Machined valve guides (required to accomodate .405" lift cam)
Intake runners ported and port matched, exhaust runners ported, matched, and polished.
3 Angle valve seats.
Intake:
41mm FCR pumper carb (cha-ching)
Uni-Filter and back-fire screen
9 filtered air box vents
Tossed the snorkle
Exhaust: It sets off car alarms and makes babies cry!
FMF SS PowerBomb header (wrapped)
FMF Ti4 Titanium muffler & mid-pipe
Cyl:
Re-Sleeved with an XRs Only sleeve (thicker)
JE 10.5:1 comp ratio 628cc piston
Electrical:
Baja Designs dual sport kit
Baja Designs 250 watt re-wound stator (it's the sh#t)
55/60 watt headlight
Dual 55 watt projector beam halogen off road lights shock mounted on a light bar of my design. They come on automaticly when the high beam is switched on.
I know I've left some stuff out but it's getting late and I need to call it a day. Thanks for checking out the thread, I'm pretty proud of how this bike turned out.
XRs Forever!
This bike is totally awsome. I am building a custom 1998 XR6 myself. I live in the Bay Area too (North Bay) and would like to hook up with you and check out your bike. I think you might like to see my bike too. Like you, I am very loyal to Honda. I would like to talk about some egine upgrades and electrical, Art
artimious7@yahoo.com is offline   Reply With Quote
Old 11-27-2011, 11:03 PM   #71
XRider OP
Almost Lifelike
XRider's Avatar
Oddometer: 1,275
Back from the dead.
I'd like to see your Big 6.
Old 11-28-2011, 05:05 AM   #72
cyclewizard
Oddometer: 4,814
Will big 742cc work????
C-dub......
Old 11-28-2011, 05:25 AM   #73
brucifer
brucifer's Avatar
Oddometer: 2,484
Back from the dead.
Where have you been?!
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-2001 Husaberg FE650E-2001 Yamaha WR250F-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F
brucifer is online now   Reply With Quote
Old 11-29-2011, 10:14 AM   #74
XRider OP
Almost Lifelike
XRider's Avatar
Oddometer: 1,275
Holy Shit!!!! That's a rippin' XR. So I've got questions. Where did you find a 742cc piston? Did you have to mill the cases to make it work? Nice USD coversion. What's the compression ratio? Dyno'd? Pump gas or race gas?
Really nice job on your XR. I knew I'd some day meet someone who spent more and did more on their Big 6 them I did. Well done. We need to go for a ride, the Santa Cruz mountains above my house have a lot to offer an XR pilot.
Old 11-29-2011, 10:20 AM   #75
XRider OP
Almost Lifelike
XRider's Avatar
Oddometer: 1,275
Well I crashed my XRR supermoto at 50+mph and was laid up for a while but I had some other health issues I had to deal with. However, I'm back now and at 100%.
Times are GMT -7.   It's 07:59 PM.
