Old 11-29-2011, 11:09 AM   #76
Dr LC8
...soon or later
Dr LC8's Avatar
Oddometer: 965
Originally Posted by cyclewizard View Post
Will big 742cc work????
That is a 650l, isn't it?
Well I love your bikes guys and I would love to be able to squizee some hp out of my XRL
So far I have:
Complete FMF system
Uniair filter and jetting
XR 600 sprokets
Renthal handlebar
Raiser for handlebar
Clark 4.7 gallon tank
As you do guys I love this bike. It is like an old sexy lady.
I would love to be able to increase it's performance though without loosing it reliability. So I was thinking not to touch the engine but maybe only cams +\- carb. What do you think about it?
Cheers
Nic
Explore Alps Off Road: www.over2000riders.com
2012 Ducati Multistrada 1200
2008 KTM LC8 990 ADV S
2003 KTM LC8 950 ADV
Trips:Europe,Africa,Asia
Dr LC8 is offline   Reply With Quote
Old 11-29-2011, 12:55 PM   #77
mcma111
mcma111's Avatar
Oddometer: 12,410
Power = displacement + compression ratio.
A cam on a stock engine is like lipstick on a hog.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-29-2011, 03:53 PM   #78
Dr LC8
...soon or later
Dr LC8's Avatar
Oddometer: 965
Won't this combination need an increase of fueling?
Is there any chance to maintain Honda original reliability?
Nic
Old 11-30-2011, 07:58 AM   #79
XRider OP
Almost Lifelike
XRider's Avatar
Oddometer: 1,275
So far I have:
Complete FMF system
XR 600 sprokets
Renthal handlebar
Cheers
Nic
If you don't want to touch the engine then you've gone about as far as you can go with the exhaust, Uni filter, and jetting. I'd replace the piston with a high compression Wiseco or XRs Only piston. The stock compression ratio on the XRL is very low, 8.9:1. The motor will still be rock solid and it's the best bang for your buck. Don't mess around with cams until you've replaced the stock piston, and for god's sake don't put a Hot Cam in it or your reliability will go out the window.
XR650R Plated Supermoto
XR628R Plated and highly modified
CR500R Still rips after all these beers
RZ350L Kenny Roberts Special
BMW R1200GS Adv Kind of a space ship
XRider is offline   Reply With Quote
Old 11-30-2011, 04:52 PM   #80
Dr LC8
...soon or later
Dr LC8's Avatar
Oddometer: 965
Hi,
So which ratio of compression you would go for?
Would I need a different carburettor?
Nic
Old 11-30-2011, 06:57 PM   #81
XRider OP
Almost Lifelike
XRider's Avatar
Oddometer: 1,275
Hi,
Nic
C/R of 11:1 will give a good boost in power while still alowing you to run pump gas. Stock carb will work fine, in fact you may not even need to change the jetting.
Old 12-03-2011, 12:51 AM   #82
XRider OP
Almost Lifelike
XRider's Avatar
Oddometer: 1,275
Hi,
Nic
'94 Dominator?
Old 12-03-2011, 01:16 AM   #83
Dr LC8
...soon or later
Dr LC8's Avatar
Oddometer: 965
'94 Dominator?
NX650 Dominator...European bike.
Look at my dedicated Thread (pag 3?) and my Lybia 2009 thread. Link in the signature.
Ciao
Nic
Old 03-15-2012, 10:50 AM   #84
XRider OP
Almost Lifelike
XRider's Avatar
Oddometer: 1,275
So, as some of you know I've been healing up from a rescent surgery. To all the people who relayed their best wishes, thanks! It meant a lot.
Now it's time to get back to one of the loves of my life, my XR600. So here's what's next, I'm going to replace the 125x2w stator for a 200w single output stator and switch the off-road lights to HID.
Pictures and diagrams to follow.
Old 11-02-2012, 01:22 PM   #85
Scampi6000
Scampi6000's Avatar
Oddometer: 24
That machine is only savage. Savage I say. Savage meaning 'friggin hell it's awesome!'.
Have been following you on a number of threads over the past couple of years XRider, borrowed a lot of ideas, and have been helped a lot!! Bit tricky getting the parts at the right price over here on the other side of the atlantic but, im getting there.
I have been rebuilding my '96 XR600 from scratch and am at the electrics stage. Adding all the lights and aux power needed that my recently bought ricky stator 200W dual output stator and new reg/rec - 100W to bike, 100W to a pair of uprated headlights from a 250 Baja. Any ideas on how to rig up what goes where wiring wise through a stock XR switch on the 100W lighting cct?
Scamp
______________________
'96 XR600
'98 Africa Twin RD07
Scampi6000 is offline   Reply With Quote
Old 11-02-2012, 02:49 PM   #86
XRider OP
Almost Lifelike
XRider's Avatar
Oddometer: 1,275
I've got your back Scamp, I'm assuming you are going for a dual voltage system, i.e. AC/DC. I'll draw up the wiring diagram and post it as soon as I can.
Thanks for the props!
XRider
P.S. Need pics of the Twin.
XRider screwed with this post 11-02-2012 at 02:55 PM
Old 11-02-2012, 02:57 PM   #87
Scampi6000
Scampi6000's Avatar
Oddometer: 24
Cheers man.
Yup. Was planning on leaving the stock AC reg in for the headlights with 100w and then the other 100w via a reg/rec for running lights, vapor, gps, heated grips etc. If there is an easier, more straight forward way, i'm all ears!
'96 XR600
Old 11-02-2012, 04:09 PM   #88
XRider OP
Almost Lifelike
XRider's Avatar
Oddometer: 1,275
And the pics of the Africa Twin?
Old 11-02-2012, 04:12 PM   #89
Scampi6000
Scampi6000's Avatar
Oddometer: 24
As requested!
Couple of shots of the Twin on tour this year around Ireland. I would say the twin is a rare enough site over there yeah?
Resting after a heavy lunch in Roundstone, County Galway
Just about to summit Healy Pass in Kerry
Back home all washed up.
Current project...
'96 XR600
Scampi6000 screwed with this post 11-02-2012 at 04:47 PM
Old 11-02-2012, 09:06 PM   #90
XRider OP
Almost Lifelike
XRider's Avatar
Oddometer: 1,275
Very, very cool!
Times are GMT -7.   It's 08:24 AM.
