Old 03-26-2013, 01:10 AM   #1861
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 2,152
Enjoying the beach
My EXC530 Adventure
My KTM690 Adventure
2008 250 Beta Rev3 - Trials with lots of errors
Night Falcon is offline   Reply With Quote
Old 03-26-2013, 06:26 AM   #1862
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 778
Originally Posted by SigPig View Post
Is there enough room in here for an SMC?
I like the stickers on your 200 Chris.
tattewell is offline   Reply With Quote
Old 03-26-2013, 07:20 AM   #1863
slidefighter
Gather it up, keep on...
slidefighter's Avatar
Oddometer: 336
Noyah: If you ever said where the (apparently) three different aluminum tanks in your pictures came from, I never saw it. Looks like they are all different. Were they fabricated locally? Looks like a great solution for adding range without width.
Thanks...
Lee...
Slidefighter
"Never adopt an ideology that masks a lack of courage"
slidefighter is offline   Reply With Quote
Old 03-26-2013, 09:05 AM   #1864
ramjet
ramjet's Avatar
Oddometer: 2,213
Thanks...
Lee...
Same question here, if it's generating interest, perhaps needs it's own thread:
http://www.advrider.com/forums/showp...postcount=7924
I'm especially curious as I know someone locally that is a fabricator for Al tanks for various race car applications.
Fundamentally transforming a KTM..
ramjet is offline   Reply With Quote
Old 03-26-2013, 09:14 AM   #1865
Lucifer666
Lucifer666's Avatar
Oddometer: 99
Originally Posted by dirtdreamer50 View Post
You were the one on the 690, I hope. Some of the riders were either under-experienced, over-biked, or both. It was fun to watch. The Enduro was made for that mess...
Yeah, I was the one filming on the 690 .
2012 KTM 690 Enduro R
2011 F800GS
www.lucifer4x4.com
Be Realistic, Demand The Impossible!
Lucifer666 is offline   Reply With Quote
Old 03-26-2013, 11:34 AM   #1866
Noyah
poser
Noyah's Avatar
Oddometer: 400
Its homemade :
I'm sure your local fabricator will be able to make one using stock airbox for messure.
I can post some numbers if it will help.
I'm about to make a few tanks to sell, I'm located in Sweden tho :)
KTM 690 Enduro R
--> My Movies <--
Noyah is offline   Reply With Quote
Old 03-26-2013, 12:48 PM   #1867
fossriver
Oddometer: 73
Got my 17's mounted !
fossriver is offline   Reply With Quote
Old 03-26-2013, 12:57 PM   #1868
ramjet
ramjet's Avatar
Oddometer: 2,213
Nice stealth look!
Old 03-26-2013, 01:35 PM   #1869
SigPig
SigPig's Avatar
Oddometer: 214
Thanks, designed it myself and had speedgraffix do them up.
2014 Beta Evo 250
2011 KTM 200 XCW
SigPig is offline   Reply With Quote
Old 03-26-2013, 02:38 PM   #1870
toomanykaws
Oddometer: 6
2013 690r
Just got a new one. Not sure how to upload or insert pics on here yet.
07 KTM 990
Too many Kaws...
toomanykaws is offline   Reply With Quote
Old 03-27-2013, 04:30 AM   #1871
slidefighter
Oddometer: 336
Noyah: Just needed to know if if your tank was locally made or not. Nice work, regardless! I've got access to some very good fabricators in my area (aviation company) so I think I'll just size up my air box and let them work it out. Not cheap I'm guessing, but a nice solution. Thanks for your help. Others may like to get your measurements or if anyone with the skills would like to fab up a few, I suspect there would be takers.
Question: Yours appears to feature fairly heavy wall thicknesses? Was that because they were easier to weld that way or because you thought you needed that much thickness for the structural integrity of the tank?
Regards,
Lee...
Slidefighter
Old 03-27-2013, 05:30 AM   #1872
sdd04
Location: The Ozarks....SW MO, NW AR-great place to play!
Oddometer: 798
Congratulations on the new ride! Pics are easy-
http://advrider.com/forums/showthread.php?t=919
sdd04 is offline   Reply With Quote
Old 03-27-2013, 06:46 AM   #1873
kareblak
Oddometer: 83
And very, very under-tired. Scorpions on mud... Yeah.
'07 KTM 990 ADV
kareblak is offline   Reply With Quote
Old 03-27-2013, 09:04 AM   #1874
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 977
Regards,
Lee...
I bought a very similar version (minus toolbox) from Bobzilla (he made a few of them) a while back and it looks like it started life as a section of 6" square aluminum box tube. It looks like it was just "pie cut" down the sides and then welded back together to follow the contour of the underside of the seat pan. Mine holds exactly 1.25 gallons. It appears to be .125" thick. There are aluminum tabs at each corner that have tapped holes so it can be bolted in in the same manner as the OEM airbox. Other than the filler neck, there is a threaded bung welded to the bottom right/rear corner that has a 90* barbed fitting with a hose that attaches to the rear fuel cap vent hose and allows it to pull a siphon as the rear tank fuel level drops. There is another threaded bung welded to the top front/ right with a 90* barbed fitting that acts as the vent for both tanks, I use a check valve in this section of hose to prevent fuel leaks/sloshing during hard riding and tipovers.
This setup has been working flawlessly for me for thousands of miles of heavy offroad use and general dualsporting. Any decent Fabricator should have no problems making their own version of this and it would probably be best for them to have a bike to fit it to as a jig so measurements ahead of time are not so important, that being said, what other measurements do you want?
The Letter J is offline   Reply With Quote
Old 03-27-2013, 04:15 PM   #1875
slidefighter
Oddometer: 336
J: That is a really sweet looking setup. It looks like it might be possible for the notoriously weak seat pan to ride on the top of your tank too. Is that what yours does? Is that a KTM filter your using? What about remapping? I have a Wings on the way and am running the Uni dual filter in the stock box and am hoping not to have to remap. With the Wings and the single filter and your tank, should I still expect not to have to remap?
Regards,
Lee...
10th day waiting on farkles...this is painful...weather is great!
Slidefighter
Times are GMT -7.   It's 01:22 PM.
