Old 09-29-2010, 11:49 AM   #1
Sniper X OP
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,325
Airhead oil change, what up with the scare on the white o ring?
Fill me in as I am about to do one on my R100RS with a new filter and premium oil. Can I use Mobile 1 or some total synthetic or should I even bother?
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 09-29-2010, 12:03 PM   #2
Mista Vern
Knows all - tells some.
Mista Vern's Avatar
Oddometer: 16,355
Look it up on Snowbum's site I sent ya - lots on the expensive O ring there. If you start running synthetic you may find that the bike starts to leak past various seals. A lot of guys run Rotella, as it contains higher zinc and other elements that protect the engine better than car oils do, plus it is cheap.
"The turd follows the fart as surely as the rain follows the plow."
Emily Bronte
Mista Vern is offline   Reply With Quote
Old 09-29-2010, 12:35 PM   #3
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,206
excellent write-up on the o-ring at Anton's site: http://www.largiader.com/tech/filters/
be sure to click on the linked words on that page.
too much fear & loathing over a task which requires some thought & finesse
Renner is online now   Reply With Quote
Old 09-29-2010, 12:48 PM   #4
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,625
Anton's O-ring writeup is excellent.
The "$2000 O-ring" may be much to do about nothing once you understand it, but a lot of people have bought a lot of expensive work over that Airhead quirk...
'73 R60/5 Toaster
Old 09-29-2010, 01:06 PM   #5
dduelin
Oh boy that was close
Oddometer: 1,451
I am not going to touch the "what oil" to use but I will share my reasoning for not running synthetics in my airhead. I do run API rating SG or SH 20w-50 oils for their higher concentrations of zinc which have been lowered in newer SL or SM rated oils. I change the oil at 2000 to 3000 miles and I believe there is little degradation of dino oil qualities in this short time to offset the higher cost of synthetics.
Triumph Tiger 800
Honda ST1300
Honda CH80
Dave
dduelin is online now   Reply With Quote
Old 09-29-2010, 01:25 PM   #6
Sniper X OP
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,325
Looks like a little common sense realy, plsu, since I am already running Rotella T I will continue to do so.
thanks!!!
Kevin
Old 09-29-2010, 03:32 PM   #7
ashrubbery
ashrubbery's Avatar
Oddometer: 79
mmm, im also not really sure about that O ring too. A mechanic I know has owned bmw airheads for decades, and hes never worried about the O ring, hes reguarily mantained his bikes and nothings really given him any trouble, no $2,000 rebuild... he doesnt quite get what the fuss is all about. Anyway, I changed my oil, and it turns out that the metal shim was all bent and messed up and was cutting that white O ring. Well, after discussing it and what not, I got a new O ring, threw away the metal shim, and well, didnt use a metal shim at all i dont think, when putting it back... Smeared a good amount of gasketting glue on all around there if I remember correctly. i dont really have the knowledge about bikes, or anything mechanical to disagree with someone whos been doing it the same way for all these years and not having experienced a problem... just hoping it will be ok!
im not disagreeing or anything, just telling a story
ashrubbery is offline   Reply With Quote
Old 09-29-2010, 05:01 PM   #8
P B G
Oddometer: 10,001
Anton's write up is clearer and has good diagrams.
This O ring thing is simple.
There are two types of canister, one w/ a rounded lip, and one w/ an unfinished/not rounded lip. If your bike's is rounded you only need shims if the measurement to that surface is too deep.
If its not rounded you need atleast 1 shim.
How many shims you need is a function of the measurement. Each shim is a certain thickness, and you're aiming for a certain range of o-ring compression.
There is a chart on his page, http://www.largiader.com/tech/filters/canister.html
The place where some people cause trouble, is that they will put in 1 shim and 1 gasket. As this is what the kit comes with. That gasket can prevent oil from leaking from the engine, but it will reduce o-ring compression, so in theory if your o-ring isn't compressed and you have a gasket there, your engine can be pushing the oil past the o-ring and therefore not having enough pressure to circulate it where it needs to go, even though the yellow light is not on. If you don't have the gasket, and the o-ring is leaking it will weap around the cover.
It is not at all scary, and I would wager most airheads w/ no cover gasket, 1 shim, and the o-ring are safe. So as long as your mechanic tosses that gasket in the trash, installs the 1 shim and bolts it up, the engine will probably do fine.
Personally I'm running 3 shims in mine, no gasket, measurement of depth yields 4.1mm, 3 shims compresses the o-ring to about 3.2, which gives me a warm feeling because I don't feel undercompressed. When I first got the bike however it had 1 shim and a slight weaping from around the cover. The o-ring was rather round when I removed it.
Old 09-29-2010, 05:10 PM   #9
Uncle Pollo
happy cachiporra
Uncle Pollo's Avatar
Oddometer: 47,780
Oh fucke ... where do I get the shims?
Uncle Pollo is offline   Reply With Quote
Old 09-29-2010, 05:14 PM   #10
P B G
Oddometer: 10,001
Come w/ oil filter kit, reusable.
Old 09-29-2010, 05:16 PM   #11
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,344
My non leaking "well broke in" (50k miles) R75/5 sprung 3 different leaks within 100 miles after going to semi-synthetic oil. Rebuilt top end ( up to 900cc), all gaskets and seals...no more synthetic blend oils for me....
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
Old 09-30-2010, 06:59 AM   #12
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,469
Whilst you're in there, check the $2000 oil bypass spring too.
boxerboy81 is offline   Reply With Quote
Old 09-30-2010, 09:09 AM   #13
Steptoe
steptoe
Steptoe's Avatar
Oddometer: 2,583
Pity you then proceed to complicate it even further with your reply
www.gsshop.biz
Steptoe is offline   Reply With Quote
Times are GMT -7.   It's 12:42 PM.
