Old 09-29-2010, 02:01 PM   #1
mfp4073 OP
mfp4073's Avatar
Oddometer: 2,488
What do your run your airhead tire pressure at?
Looked up the manual and didnt find anything. Tires say 42 max. Just got a new rear fender with factory stickers with MUCH lower numbers. So wanted to find out what the consensus was. This is for my 74 /6. Thanks!
1974 BMW R90/6 Bettie #1, 04 Triumph Bonneville
Originally Posted by Martin Blank
loner, lonegunman, get it. That’s the whole point. I like the lifestyle, the image. Look a the way I dress.
Originally Posted by bgoodsoil View Post
Cavemen must've designed them shortly after inventing the wheel.
mfp4073 is offline   Reply With Quote
Old 09-29-2010, 02:06 PM   #2
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,347
I have heard that modern tyres need their listed pressure, not what the bike calls for. Mine (stock) on my 1978 R100RS are listed on the dashboard, which is cool, but I think they are wrong. I am going to top them off tonight per the tyre sidewall.
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 09-29-2010, 02:11 PM   #3
blaine.hale
blaine.hale's Avatar
Oddometer: 3,194
My S fairing tells me 26/29psi (front/rear.) I don't trust that. I usually run 32 normal and 36 with a load on the rear tire. Keep in mind...I'm like a buck 25 at most in weight.
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is offline   Reply With Quote
Old 09-29-2010, 02:32 PM   #4
mfp4073 OP
mfp4073's Avatar
Oddometer: 2,488
Just to throw this in there, I am about 215 and tires (tyres) are metzler lasertech fronts and metzler perfect ME 77 rear.
Old 09-29-2010, 04:03 PM   #5
P B G
Oddometer: 10,001
I've kept my front at 30 and rear at 34 for awhile now. That just seems to handle best over all the rain grooved highway I'm forced to navigate. Least weave. I tried lower and higher front and rear, and this seemed to non-scientifically weave less.
Old 09-29-2010, 04:07 PM   #6
Uncle Pollo
happy cachiporra
Uncle Pollo's Avatar
Oddometer: 48,351
I am 220 full geared and run the same pressure.
Uncle Pollo is offline   Reply With Quote
Old 09-29-2010, 06:26 PM   #7
dduelin
Oh boy that was close
Oddometer: 1,585
32-34 F 36-38 R
Triumph Tiger 800
Honda ST1300
Honda CH80
Dave
dduelin is offline   Reply With Quote
Old 09-29-2010, 07:41 PM   #8
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,572
32/34. Minus 7 if i'm off road...
Old 09-29-2010, 08:29 PM   #9
El Hombre
Oddometer: 1,536
My S fairing didn't have the tire pressure decal and you can't, as far as I know, buy another. Lawyers and all that. 26/29 sounds about right for 35 year old specs. I run 33/38, but I'm a fat ass.
I used the 10% rule to get those. Reg Pridmore told me to run around 29 or 30 front and back if I was to take one of his schools. More grip according to him.
El Hombre is offline   Reply With Quote
Old 09-30-2010, 01:28 AM   #10
Max Headroom
lost in the '70s
Max Headroom's Avatar
Oddometer: 519
Haven't checked the availability lately, but I bought my "S" fairing stickers from Motobins some years ago without any difficulty.
'76 R90S silver smoke
'75 R90/6 hybrid
'Skills are learned, talent is ornate.' Billie
Max Headroom is offline   Reply With Quote
Old 09-30-2010, 03:02 AM   #11
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,590
I run 20 front and 25 rear with my K70's and love it.I used recommended pressures on the normal road tyres - 32 and 36.I fitted a Spitfire to the rear earlier this year and found my chicken strips went from 10mm to 20mm...it seems to be a rounder tyre.I'm not so confident on these tyres.
A couple of weeks ago after not riding the bike for several months,I went out,and after getting the feel of the bike again got into the zone and was pushing the bike hard,I felt the most confident on the bike with these tyres ever.Getting home I found I had no chicken strips at all,it was right down to the edge.I was suspicious,and checked the rear tyre pressure - 8psi !!!
It appears I'm very tolerant of low pressures...and high pressures feel greasy to me.Maybe riding trials bikes at 3 or 4 psi for 30 years has distorted my perception.
motu is online now   Reply With Quote
Old 09-30-2010, 05:53 AM   #12
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,604
R100RS
36fr
38r
..for over 20- years.
boxerboy81 is offline   Reply With Quote
Old 09-30-2010, 06:09 AM   #13
Beemerboff
Oddometer: 2,334
I ran my Macs on my /7 at 32/ 36, but the Lasertechs are fine 4/5 lbs less, and this is the pressures the suspension was designed to work with.
The Distanzas on the other bikes are fine at 26 /30 but that is a compromise for dual sport use, although the only real drawback is a little scalloping on the front - handling is great.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 09-30-2010, 06:18 AM   #14
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,477
I'm surprised at the wide range folks are running street tires at. I'm usually at 30-32 front 32-34 rear.
JT
www.northwoodsairheads.com
www.jefftrappwindsors.com
"Between two explanations, choose the clearest; between two forms,
the most elementary; between two expressions, the shortest."
Between two motorcycles the simplest (DW)
Eugeni d' Ors (1881-1954); Spanish writer.
jtwind is offline   Reply With Quote
Old 09-30-2010, 06:44 AM   #15
BrianK
F'in' half ass lookie boy
BrianK's Avatar
Oddometer: 858
Ditto, JT.
BrianK is offline   Reply With Quote
Times are GMT -7.   It's 03:33 AM.
