09-30-2010, 06:48 AM
#16 |
Guest
Oddometer: n/a
32f/34r on Lasertecs.
09-30-2010, 07:27 AM
#17 |
Old Enough To Know Better
Oddometer: 5,526
I'm usually at 30-32 fr and 32-34 rear. That seems to be the best compromise between best wear and best traction.
For offroad excursions on loose surfaces I air down to about 21-22 psi (no rimlocks, or I could go down to around 18 or so). I always have air with me to air back up when returning to pavement and minimize heat buildup at road speeds. Tip of the day: Locate your 12V receptacle and your pump where you can get to them without unpacking anything on the bike. DAMHIK. To the poster who intends to run the pressure listed on the tire: That is the max safe pressure for the max rated load. Tires inflated to the limit tend to give up a significant amount of traction as the contact patch is reduced at the higher pressures. Don't find out the hard way.
Mark J Merritt Island, FL When a person asks you for advice, they don't want advice. They want corroboration. |
09-30-2010, 11:22 AM
#18 |
Touchthewindrider
Oddometer: 13
Dunlop 220s front 27 rear 27
84' R80RT What kind of mileage are you getting on those 32/36 psi tires? |
09-30-2010, 01:39 PM
#19 |
Horizontally Opposed
Oddometer: 5,341
Bridgestone S11...front and rear. I got great mileage out of these tires. I run 'em 4 pounds less than max......
'65 R60/2 '68 R60US '74 MG Eldorado '95 R100M |
09-30-2010, 01:51 PM
#20 |
Oddometer: 111
BT45s front and rear 34 and 38
10-01-2010, 07:54 AM
#21 |
Oddometer: 947
1981 R100RT with BT45s. Front 34 Rear 38. this was after experimenting with lots of different pressures till I found what works best for me and my riding style.
10-01-2010, 09:51 AM
#22 | |
Motor Sickle Addict
Oddometer: 1,098
There may be some truth to because when i got my 72 Commando a few years ago it had the stock tires on it and i replaced them with the same Dunlop and the old tires had a lower pressure listed on it than the new ones. |
